U
Revision as of 14:53, 10 March 2011 by Admin (talk | contribs)
UASKU 18 x 24 mm format VIIIs slide projector 1936-1951 -
UBAFE Picture slides for projectors with 5 x 5cm frame format 1932-1936 -
UBAHO Slide attachment for small VIIIb projector with picture slide and 8 cm lens milar and condensor 1932-1936 -
UBAZU 19??-19?? -
UBEAF 30 volt / 100 watt Cinema lamp plug-in socket for slide projectors VIIIa and VIIIb ca.1935 -
UBEBC 19??-19?? -
UBECD 22 mm extension tube for Focoslide and also for UDIMO enlarger using 5 cm Elmar 1936-1940 NY item
UBEHU 19??-19?? -
UBELA Small projector with UDIMO film UKEDO intent with semi-automatic film guides and threaded socket for Leica lenses ca.1935 -
UBELABIKU 19??-19?? -
UBELADOKO 19??-19?? -
UBEMI 100 watt lamp for Cinema use with slide projectors VIIIa and VIIIb 1932-19?? -
UBENO Slide projector lamp housing for projector VIIIb with film intent UKEFI including lens milar 1932-1936 -
UBEOL 19??-19?? -
UBEPU 19??-19?? -
UBFKU 19??-19?? -
UBIKU Projector VIIIa for lenses from 12 to 15 cm 1932-1936 -
UBILADAKI 19??-19?? -
UBIRN Mirrored special 500 W bulb for 100 to 130 volts in 5 volt steps usd with IVb slide projector 19??-1932 -
UBMWU Extra heat protection filter with 250 v socket for Prado slide projectors ca.1955 -
UBODI Slide projector VIIIb with lamp housing and picture slide intent UBAHO including lens milar 1932-1936 -
UBODIMAX 19??-19?? -
UBRGU 19??-19?? -
UBSIU 19??-19?? -
UBTLU 19??-19?? -
UCDEU 19??-19?? -
UCEGU Pradovit I slide projector with Dimaron 2.8/100mm 1960 -
UCFIU 19??-19?? -
UCFKU Pradovit I slide projector with Colorplan 2.5/90mm 1960 -
UCHRU Protective metal hood for Pradovit I slide projector 1960 -
UCMVU 19??-19?? -
UCNXU Pradovit f slide projector with Dimaron 2.8/100mm 1960 -
UCPBU 19??-19?? -
UCPLU Pradovit f slide projector with Colorplan 2.5/90mm 1960 -
UCSHU Remote control 4 m cable 1960 -
UCWQU 1960 -
UDAKI Slide projector VIIIa to VIIIs for lenses 7.3, 8, 8.5 and 9 cm 1932-1936 -
UDALU Image slide for 24 x 36 mm slides between 3.5 x 12 cm glass plates for type VIII slide projectors 1932-19?? -
UDAMY Leica-film unit for Leica lenses on the non-Leica projectors with take-up spool, fire drums and film guide for 24 x 36 mm film slides 1932-1936 -
UDANO VIIIa projector housing, similar to UDIMO, with UBAFE 19??-19?? -
UDANOBIKU 19??-19?? -
UDANODAKI 19??-19?? -
UDANODOKO 19??-19?? -
UDAOB Projection milar f = 8 cm for VIIIa and similar slide projectors 1932-1936 -
UDAPA Cassette with a circular cutout for 5 x 5 cm lantern slides for VIIIa and other slide projectors 1932-19?? -
UDAPTA 19??-19?? -
UDAVI 19??-19?? -
UDCBU Pradovit f slide projector with Dimaron 2.8/150mm 1960 -
UDEJO Small slide projector UDIMO (VIIIa) with UBAFE and UDAMY removable cassettes 1932-1936 -
UDGKU Plywood case for projector plus accessories and 150mm lenses 1960 -
UDIAS Diavorsatz with Lens Dimar 250mm and two alternating frames made of wood for 8.5 x 8.5, 8.5 x 10, 9 x 12 slides for the IVb L. slide projector 1932-19?? -
UDIMO VIIIa slide projector, lamp housing with 100-watt lamp for mains cinema, reflector and cassette 1932-1936 -
UDKQU Second heat protection filter, including 500-watt lamp 1960 -
UDLSU 1960 -
UDOKO Condenser for small VIIIa projector including Elmar and Hektor 5 cm lenses ca.1955 -
UDOYU Prado 250 complete with 10 cm Dimaron projector lens ca.1955 -
UDOZU Front assembly for VIIIa and others slide projectors 1932-1936 -
UDREU 10 cm Hector lens for Prado 250 projector 19??-1955 -
UDRUK Pressure switch for short connection cord to slide projector 1932-19?? -
UDUHS 19??-19?? -
UDWPU Transparent container for 2 slide magazines 1960 -
UDXRU Transparent containers with 2 magazines 1960 -
UEOOK Adaptor ring for UZEOO 36 mm front lens mount 19??-19?? 16568
UEOXU Slide magazine for 30 slides 1960 -
UEPOO Adaptor ring for UZEOO 42 mm front lens mount 19??-19?? 16566
UFBXU 5 magazine cassette 1960 -
UFTGU 2 slide magazines for 50 slides incl. cardboard 1960 -
UGPXU Remote control cable 10m long 1960 -
UGQZU Remote control cable 15m long 1960 -
UGRBU Remote control cable 20m long 1960 -
UHPWU Multiple connector for tape device and cable 1960 -
UKGDU Synchronous circuit with tape 1960 -
UMHDU Pradovit f with Dimaron 2.8/100mm, at 60Hz switchable 1960 -
UMIQU Pradovit f with Colorplan 2.5/90mm, at 60 Hz. switchable 1960 -
UMKHU Pradovit f with Hektor 2.5/120mm, at 60 Hz. switchable 1960 -
UMLKU Pradovit f with Dimaron 2.8/150mm, at 60 Hz. switchable 1960 -
UMNOU Pradovit f with Hektor 2.5/150mm, at 60 Hz. switchable 1960 -
UNOOB Carrying arm with lens holder and variable bellows, known as the lower stage of the universal reproduction apparatus for Elmar (I) f= 5 cm 1:3.5 1934-19?? -
UNOOB-YSMOO Carrying arm with lens holder and variable bellows, known as the lower stage of the universal reproduction apparatus for Summar f= 5 cm 1:2 1937-19?? -
UOOND Adapter ring used to mount Leica M lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used to mount M lens on screw mount extension tube or copy device like Focoslide for close-up work. The screw mount version is UUOYW 1956-19?? 16596
UOOPE Spannungsreduzierer with voltmeter to extend the life of AKTOO projector bulb ? -
UOORE Believed to be a typo for UOORF Forum discussion ? -
UOORF Adapter ring for the lens head of the rigid Summicron 50 with SOOKY or SOMKY; also for Bellows I /II Forum discussion [1] 1960 17672 (bayonet) - 16508 16469 (screw)
UOOST UOOYW + UOOVH ? -
UOOVH Lens adapter ring for the head of Hector and Elmar 135mm and extension tube for HEFAR lens head ? 16580
UOOWV Lens Adapter Ring for heads and the Elmarit 90mm Elmar ? 16585
UOOXI Adapter Ring for the head of the 125mm Hektor with Bellows I /II 1958 16572
UOOYW Bellows connecting ring for I and II Fontenelle archive ? 16590 N
UOOZK Adapter ring for the head of the Summicron 90 mm with Bellows I /II Forum discussion 1960 16598
UOSWU Horizontal slider for Prado S and SM ? -
UPOOZ Yellow very light no. 0 filter; screw-on type E58 ca.1951 13235
UQMOO Yellow light no. 1 filter; screw-on type E58 ca.1951 13235
UQOOY Yellow medium no. 2 filter; screw-on type E58 ca.1951 -
UROOX Panchromatic green filter; screw-on type E58 ca.1951 13245
USFLA Kodachrome flash filter; type E58 1949-19?? NY item
USOAY Kodachrome type A filter; type E58 1949-19?? NY item
USOOW Orange filter; screw-on type E58 ca.1951 13250
USQOO Infra-red light no. 1 filter; screw-on type E58 ca.1951 13255
USSKY Kodachrome skylight filter; type E58 1954-19?? NY item
UTOOV Infra-red medium no. 2 filter; screw-on type E58 ca.1951 -
UTSOO Infra-red dark no. 3 filter; screw-on type E58 ca.1951 13265
UUOYW Adapter ring used to mount screw-mount lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used for mounting extension tube or copy device like Focoslide for close-up work. The M-mount version is UUOND 1956-19?? -
UVOOF UVa filter; screw-on type E58 ca.1951 13270
UVWOO 4-way lamp socket with cable and plug 1951-19?? 16760
UWOOS Arm connector for copy stand Focoslide 19??-19?? 16601
UWYOO Adaptor plate for using focusing bellows on carrying arms ROONP and ROOFU 1951-19?? 16600
UXOOR Universal focusing bellows; early version had smaller diameter thread for the lens mount and was supplied with an adaptor ring UOOYW and tube UOOVH for Hektor f= 13.5 cm 1:4.5 ; later version has thread for universal focusing bellows II with interchangable adaptor rings Forum discussion Fontenelle archive 1951-19?? 16555
[2]
UYOOC Interchangeable bayonet adapter for 50mm f3.5 Elmar for use with Bellows I /II Forum discussion 1951-1960 -
UYOOQ Fiber case with Visoflex I, bellows and accessories ? -
UZEOO Large extending bellows lens hood with changeover mask frame for upright and horizontal shots for 36 mm front lens mount Forum discussion 1951-19?? 16565
UZEOO-M Bellows lens hood for 42 mm front lens mount 1960-19?? 16567
