C
CABSO | Focusing attachment with 2 shutters and holding collar for microscope eyepiece | ? | - |
CABSU | Focusing attachment with 1 shutter and holding collar for microscope eyepiece | ? | - |
CAFAM | Micro Camera Case for 9 x 12 cm plates | ? | - |
CAFOT | Micro Camera Case for 4.5 x 6 cm plates | ? | - |
CALOS | Shutter release for MIKAS | 1939 | - |
Camcraft N-5 | Motor drive for M1, M2 and MP | 1958-? | Lager, Vol. III, p. 67 |
CAMIAN | Rewind crank for M1, M2, M3 and MP, chrome, USA version | 1950-1960s | Lager, Vol.III, p. 77 |
CAREU | Used with LUCCA camera mount for stereo microscope, without magnification marker | ? | - |
CAREX | Used with LUCCA camera mount for stereo microscope, with magnification marker | ? | - |
CARTY | Self-timer | 1932 | Lager, Vol.III, p. 10c |
CAVOO | Flash unit similar to CEYOO with various AF settings | 1951-1953 | - |
CAMPAR | Binoculars – 10 x 40 – 7.3 deg | 1932-1959 | - |
CAMPARIT | Binoculars – 10 x 40 – 7.3 deg – CF type | 1932-1959 | - |
CAMPOFORT | Binoculars – 15 x 60 – 4.6 deg – IF type | 1932-1962 | - |
CAMPOFORTIT | Binoculars – 15 x 60 – 4.6 deg – CF type | 1932-1962 | - |
CAMPOMAR | Binoculars – 12 x 50 – 5.7 deg | 1932-1949+ | - |
CAMPOMARIT | Binoculars – 12 x 50 – 5.7 deg – CF type | 1932-1949+ | - |
CANOE | - | ||
CARIR | - | ||
CARTY | - | ||
CASAU | - | ||
CBOOD | Slip-in mask 18 x 24 mm for Focomat Model II, VYBOO and VYOOS | pre 1937 | - |
CBUUD | - | ||
CDEOO | Slip-in mask 24 x 36 mm for Focomat Model II, VYBOO and VYOOS | pre 1937 | - |
CDOOB | Slip-in mask 30 x 40 mm for Focomat Model II, VYBOO and VYOOS | pre 1937 | - |
CENTO | Light shield for VALOY enlarger | pre 1937 | - |
CEYAL | New code word for CEYOO-PARAL flash unit | 1959 | 15506 |
CEYAT | Flash device CEYAL without rectifier | ? | - |
CEYOO | Flash device with f-sync | 1950-1959 | - |
CEYOT | Flash device without f-sync | ? | - |
CEYOO-PARAL | Flash unit CEYOO for simultaneous triggering of multiple flash units | 1952-1958 | - |
CFIOO | Slip-in mask 40 x 40 mm for Focomat Model II, VYBOO and VYOOS | pre 1937 | - |
CFOOZ | Slip-in mask 40 x 65 mm for Focomat Model II, VYBOO and VYOOS | pre 1937 | - |
CGLOO | Slip-in mask 45 x 60 mm for Focomat Model II, VYBOO and VYOOS | pre 1937 | - |
CGOOY | Slip-in mask 60 x 60 mm for Focomat Model II, VYBOO and VYOOS | pre 1937 | - |
CHICO | Flash unit for Leica IIIf also known as DEOOC | 1954-1959 | - |
CHNOO | Slip-in mask 65 x 90 mm for Focomat model II | pre 1937 | - |
CHOOX | Slip-in mask 60 x 90 mm for Focomat model II | pre 1937 | - |
CHROM | Special filters in chrome, with 34 mm adapter for Wratten filter E 32 mm | ? | - |
CHROM-WH | Special filters for military use | ? | - |
CINLE | Adapter for Leica lenses on 16 mm cameras with C-Mount | ? | - |
CINPY | Adapter for Leica lenses on 16 mm cameras; for example Howell 70 mm cine cameras | ? | USA catalog |
CKOOV | Negative mask for 24 x 24 mm frame size | Leica Catalog for 1955/58 p. 53 | |
CLIPP | Rangefinder | - | |
CMEET-XCEES | Copy stand with vertical and horizontal adjustment | ? | - |
CMEET-XCEET | Copy stand with vertical adjustment | ? | - |
CMVOO | Vacuum Synchronizer Dial "B" - speeds 20-1, 30, 40, 60, 100, 200, 500, 1000 for CAVOO, COOIF, etc. | ? | - |
CNOOS | Sync cable for CHICO flash unit except for M3, | ? | 15520 |
CNXOO | Connector plug for double flash CEYOO | ? | 15538 |
CODRO | Small Correx developing tank with "circulation" | 1952-1955 | - |
CODRORF | Correx film unit for 120 and 620 roll film | ? | - |
COOAB | Short Einstellschnecke for Hektor f= 7.3 cm 1:1.9 | ? | - |
COOAS | As above, but for Mountain Elmar | ? | - |
COODQ | Turning knob for CORUN Correx tank | ? | - |
COODX | Turning knob for CORUN Correx tank | ? | - |
COOED | Short Einstellschnecke for Elmar (I) f= 9 cm 1:4 Fontenelle archive | ? | - |
COOEL | Adapter for Elmar (I) f= 9 cm 1:4 with COOMI | ? | - |
COOFR | Correx band 12 ft. long, molded on one side, for simultaneous development of two Leica films in CORUN tank | pre 1937 | - |
COOHO | Adapter for Hektor f= 13.5 cm 1:4.5 with COOMI | ? | - |
COOHS | Short Einstellschnecke for Hektor f= 13.5 cm 1:4.5 | ? | - |
COOIF | Spare Synch for vacuum or CAVOO with lightning and electrical cables | ? | - |
COOIS | As above, but with a different voltage | ? | - |
COOKT | Extension cable CNOOS or MOONZ for flash CEYOO | ? | 15543 |
COOLG | Case for "Sports" viewfinder SAIOO, SEROO or SYEOO | ? | - |
COOMI | Verlängerungstubus with micrometer adjustment, adjustable, black / chrome | ? | - |
COONS | Sync cable for Leica M3, except for flash CHICO | ? | 15523 |
COONT | Sync / CAVOO substitute for electrical and lightning | ? | - |
COONY | Adapter socket for Velostigmat 4.5 / 9 cm lens | ? | - |
COOPI | - | ||
COOSE | Adapter for Velostigmat 4.5 / 12.7 cm lens | ? | - |
COOSD | - | ||
COOSX | Sync cable for connecting CEYOO to external cameras | ? | 15522 |
COOTL | Short mount for Thambar f= 9 cm 1:2.2 | ? | - |
COOUY | Replacement condenser for CEYOO, CAVOO or CEYAL | ? | - |
COOWQ | - | ||
COOYA | Case for SBOOI viewfinder | JCB's a little...IIf | |
COPIN | FocaSlide, calibrated glass strip focusing screen Forum discussion | 1939- | - |
COSIN | FocaSlide, calibrated glass strip focusing screen | ? | - |
CORAX | Double Correx band for CODRO | 1950 | - |
CORBA | Correx band with bracket for CORDO | ? | - |
CORBAS | As above, but for 120 roll film | ? | - |
CORBAT | As above, but for 620 film | ? | - |
CORBAX | ? | - | |
CORBARF | Replacement for 120/620 film Correx band, New York version | ? | - |
CORCF | Correx tank lid only | ? | - |
CORDO | Developing tank made of metal, 350 ml, complete with spool | 1933-1939 | - |
CORET | Small thermometer for Correx tank | pre 1932 | - |
CORFR | - | ||
CORID | Inner spool for Correx Tank | pre 1932 | - |
CORIDCJ | Replacement film spool | ? | - |
CORLE | Container with lid for CORDO | ? | - |
COROL | Correx tank, cover and knob | pre 1932 | - |
COROS | Correx tank, cover without knob | ? | - |
CORPE | - | ||
CORSO | Replacement spool for CORDO | ? | - |
CORSOL | Replacement spool for CORDO, revised version | ? | - |
CORSORF | Replacement film spool | ? | - |
CORDRF | Replacement film spool 120 film | ? | - |
CORSU | Inner spool CORDO | ? | - |
CORUN | Large Correx tank with 500 ml capacity | 1931-1955 | - |
CORUNT | Large Correx tank with 500 ml capacity, revised version | ? | - |
CORUNCJ | Large Correx tank with 500 ml capacity, revised version | ? | - |
CORYB | Celluloid Correx band with clip and without bracket | pre 1932 | - |
CORYBCJ | - | ||
CORYBCL | Replacement celluloid Correx band | ? | - |
COSLA | Visoflex focusing stage, like FULET, with calibrated glass holder | ? | New York version |
COSLAD | Visoflex focusing stage | ? | - |
COSTI | Spool winding knob for Correx tank | ? | - |
COSTID | Spool winding knob for Correx tank | ? | - |
CPBOO | Case for SVGOO viewfinder | ca.1951-1960 | JCB's a little...IIf |
CSOON | Flash connection cable for CEYOO except for M3 | ? | - |
CTKOO | Flash connection cable for M3 to Braun-Hobby flash unit | ? | - |
CTOOM | Adjustable flash bracket, plastic, and later metal | pre 1955 | JCB's a little...19 |
CTOON | Adjustable flash bracket, black painted metal | ? | - |
CUMOO | Connection piece for cable as part of CNOOS / MOONZ | ? | - |
CUMOS | Connection piece for cable as part of CNOOS / MOONZ | ? | - |
CUMOT | ? | - | |
CUOOL | Connecting sync cable for Leica cameras for CHICO flash unit except for M3 | ca.1959 | - |
CUOOK | Connecting sync cable for Leica cameras for CHICO flash unit except for M3 | ca.1959 | - |
CVOOK | CHICO flash unit with connecting sync cable for M3 | 1954-1959 | - |
CVOOX | CHICO flash unit with connecting sync cable for M2 | ca.1959 | - |
CVOOZ | CHICO flash unit with connecting sync cable for M1 | ca.1959 | - |
CWOOI | - | ||
CXOOH | - | ||
CXSOO | - | ||
CYOOG | - | ||
CYUOO | - | ||
CZOOF | - | ||
CZWOO | - |
