21mm f3.4 Super-Angulon
Revision as of 12:27, 7 June 2011 by Admin (talk | contribs) (→21mm f/3.4 Super-Angulon Serial Numbers)
- Leica Order No. - 11 103 LLC - 138
- Production era - 1963-1976 < 5,970 lenses
- Manufacturer - Schneider-Kreuznach
- Variants - Chrome until 1967 then all black; cutout version to fit M5 and CL from SN 2473251.
- Lens mount - Leica Screw-thread & M-bayonet
- Compatibility - Can be used on M8 or M9 cameras (without exposure metering).
- Number of lenses /groups - 8 /4
- F stop range - f/3.4-f/22
- Closest focusing distance - 0.7 m - 1 m (M3)
- Smallest object field - 380 x 570 mm
- Diaphragm setting /type - 4-blade
- Angle of view diagonal - 92 degrees
- Filter type - Series VII, E48 - A52.5
- Accessories - Hood: 12501 - Viewfinders: SBKOO - 12012 - 12002
- Materials -
- Dimensions length x diameter - 51 x 52.5 mm / 2.01 x 2.07 in
- Weight - 301 g /10.62 oz
- Inscription - LEITZ WETZLAR SUPER-ANGULON 1:3.4/21 2XXXXXX
- On the street - $1,000 in 2010
Serial numbers compiled from Puts Pocket Pod.* Note: JCB has 1967101 as the first batch f= 2.1 cm 1:3.4 lens - see Forum discussion [1] above - Puts has this batch with the 1:4 lens
^ Lenses 1967952, 2027728, 2035381, 2054276, 2917100, 2917150, are 1:3.4 not 1:4 as listed
^^ Lens 2783716 is 21mm f/3.4 Super-Angulon
| 1967101* | 1968100 | Super-Angulon f= 2.1 cm 1:4*(M-chrom) | 1962 | 1000 |
| 2027501^ | 2028000 | Super-Angulon f= 2.1 cm 1:4^ (M+S-chrom) | 1964 | 500 |
| 2035001^ | 2036000 | Super-Angulon f= 2.1 cm 1:4^ (M+S-chrom) | 1964 | 1000 |
| 2054001^ | 2056000 | Super-Angulon f= 2.1 cm 1:4^ (M+S-chrom+M-black) | 1964 | 2000 |
| 2247151 | 2247650 | 21mm f/3.4 Super-Angulon (M+S-black) | 1967 | 500 |
| 2292051 | 2292800 | 21mm f/3.4 Super-Angulon (M+S-black) | 1968 | 750 |
| 2327801 | 2328300 | 21mm f/3.4 Super-Angulon (M-black) | 1969 | 500 |
| 2372301 | 2372800 | 21mm f/3.4 Super-Angulon (M+S-black) | 1969 | 500 |
| 2417201 | 2417700 | 21mm f/3.4 Super-Angulon | 1970 | 500 |
| LENSES | BELOW | HAVE CUTOUT FOR USE WITH | M5 + | CL |
| 2473251 | 2473750 | 21mm f/3.4 Super-Angulon (M-black) | 1971 | 500 |
| 2522501 | 2522800 | 21mm f/3.4 Super-Angulon (M-black) | 1972 | 300 |
| 2583001 | 2583500 | 21mm f/3.4 Super-Angulon (M-black) | 1973 | 500 |
| 2672701 | 2673200 | 21mm f/3.4 Super-Angulon (black) | 1974 | 500 |
| 2750631 | 2750750 | 21mm f/3.4 Super-Angulon . | 1975 | 120 |
| 2783351 | 2783650 | 21mm f/3.4 Super-Angulon . | 1976 | 300 |
| 2783651^^ | 2785650 | ^^ Elmarit-R 28mm f/2.8 ^^ | 1976 | [2000] |
| 2917001 | ^ 2917150 | 21mm f/4 ^ Super-Angulon-R ^ | 1978 | [150] |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1967-1975 | 5,970 |
