135mm f/2.8 Elmarit-M III
Revision as of 12:23, 7 June 2011 by Admin (talk | contribs) (→135mm f/2.8 Elmarit-M III Serial Numbers)
- Leica Order No. - 11 829 LLC - 184
- Production era - 1976-1996 < 9,850 lenses
- Variants -
- Number of lenses /groups - 5 /3
- F stop range - f/2.8-f/32
- Closest focusing distance - 1.5 m /4.92 ft
- Diaphragm setting /type -
- Filter type - E55
- Accessories -
- Dimensions length x diameter - 114 x 66 mm / 4.49 x 2.60 in
- Weight - 780 g /1.72 lb
- Inscription - ELMARIT-M 1:2.8/135 LEITZ CANADA 3XXXXXX
- On the street - €EU 960 in 2007 - $US 430 in 2010
Serial numbers compiled from Puts Pocket Pod.* Lens 2728702 is Tele-Elmarit-M 2.8/90mm
.** Lens 3178214 & 3178688 are 135mm f/2.8 Elmarit-M
.^ Lens 3104870 & 3375938 are 135mm f/2.8 Elmarit-M
| 2726921 | *2728920 | *135mm f/2.8 Tele-Elmarit | 1974 | 1000 |
| 2771201 | 2773200 | 135mm f/2.8 Elmarit | 1976 | 2000 |
| 2788651 | 2789650 | 135mm f/2.8 Elmarit-M | 1976 | 1000 |
| 2849551 | 2850050 | 135mm f/2.8 Elmarit-M | 1977 | 500 |
| 2872601 | 2873100 | 135mm f/2.8 Elmarit | 1977 | 500 |
| 2997001 | 2998000 | 135mm f/2.8 Elmarit-M | 1979 | 1000 |
| 3104001^ | 3105000 | 135mm f/2.8^ Elmarit-R | 1981 | [1000] |
| 3178201 | **3179200 | 135mm f/2.8 Elmarit-R** | 1982 | [1000] |
| 3294401 | 3294900 | 135mm f/2.8 Elmarit-M | 1983 | 500 |
| 3375501^ | 3376000 | 135mm f/2.8^ Elmarit-R | 1985 | [500] |
| 3486701 | 3487200 | 135mm f/2.8 Elmarit-M | 1989 | 500 |
| 3536768 | 3537467 | 135mm f/2.8 Elmarit-M | 1990 | 700 |
| 3608020 | 3608119 | 135mm f/2.8 Elmarit-M | 1992 | 100 |
| 3615430 | 3615579 | 135mm f/2.8 Elmarit-M | 1993 | 150 |
| 3641826 | 3642125 | 135mm f/2.8 Elmarit-M | 1993 | 300 |
| 3686631 | 3687030 | 135mm f/2.8 Elmarit-M | 1995 | 400 |
| 3720303 | 3720502 | 135mm f/2.8 Elmarit-M | 1995 | 200 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1974-1995 | 9,850 |
