50mm f/2 Summicron-R II
Revision as of 14:37, 30 January 2012 by Admin (talk | contribs)
  • Leica Order No. - 11 215-R.only - 11 216-R.only - 11 345-ROM - 11 217-R.only.Safari LLC - 123
  • Production era 1976-2009, 99,736+ lenses
  • Lens mount - LEICA R-bayonet for LEICA R3 to LEICA R9 with mechanical, and, for LEICA R8/R9, additional electronic exposure control
  • Variants - Black, Safari green, R-only and 3-cam versions
  • Number of lenses/groups - 6 / 4
  • Focusing range - 0.5 m / 19.7 in < ∞
  • Aperture range - f/2-f/16 - Preset diaphragm with clickstops (including half values), 6-blade fully automatic diaphragm
  • Smallest object field/Largest reproduction ratio - 180 mm x 270 mm / 1:7.5
  • Angle of view (diagonal, horizontal, vertical) - 47°, 40°, 27°
  • Position of entrance pupil - 20.2 mm / 0.8 in (related to the first lens surface in light direction)
  • Filter mount/Lens hood - Internal thread for screw-in type filters E 55 / Built-in, telescopic
  • Accessories - ELPRO close focusing attachments type 1 and 2
  • Viewfinder - Camera viewfinder
  • Materials - Anodized aluminum and optical glass
  • Focal length - 52.5 mm / 2.07 in
  • Length to bayonet flange - 41 mm / 1.6 in
  • Largest diameter - 66 mm / 2.6 in
  • Weight - 290 g / 10.2 oz
  • Inscriptions - LEICA SUMMICRON-R 1:2/50 E 55 3XXXXXX
    LEITZ SUMMICRON-R 1:2/50 3XXXXXX
    SUMMICRON-R 1:2/50 LEITZ CANADA 3XXXXXX
  • On the street - $US 1,495 in 2008 - 600 (3-cam) - 790 (ROM) in 2010
  • Reviews
50mm f/2 Summicron-R II Serial Numbers
.* Lens 2925638 is Summicron-R 11215 2/50mm R.only
.** Lens 3082026 is Summicron-R 2/50mm R.only
^ Lens 2822922 is Summicron-R 2/50mm (2-cam)
2777651 2781650 50mm f/2 Summicron-R (11 215) 1976 4000
2800401 2801400 50mm f/2 Summicron-R 1976 1000
2816351 2816850 50mm f/2 Summicron-R 1977 500
2822351^ 2826350 50mm f/2 Summicron-M^ 1978 [4000]
2834801 2838800 50mm f/2 Summicron-R (11 215) 1977 4000
2862801 2866800 50mm f/2 Summicron-R 1977 4000
2876201 2880200 50mm f/2 Summicron-R 1977 4000
2889401 2893400 50mm f/2 Summicron-R (11 217) 1978 4000
2922901* 2926900 50mm f/2 Summicron-M* 1978 [4000]
2941701 2945700 50mm f/2 Summicron-R 1978 4000
2955501 2959500 50mm f/2 Summicron-R (11 217) 1978 4000
2969251 2973250 50mm f/2 Summicron-R 1979 4000
3009651 3013650 50mm f/2 Summicron-R 1979 4000
3082001** 3084000 50mm f/2 Summicron-M** 1981 [2000]
3089001 3093000 50mm f/2 Summicron-R 1981 4000
3096501 3098500 50mm f/2 Summicron-R 1981 2000
3109001 3114000 50mm f/2 Summicron-R 1981 5000
3161001 3163000 50mm f/2 Summicron-R 1982 2000
3179201 3181200 50mm f/2 Summicron-R 1982 2000
3203801 3205800 50mm f/2 Summicron-R 1982 2000
3227301 3229300 50mm f/2 Summicron-R 1982 2000
3233301 3234300 50mm f/2 Summicron-R 1982 1000
3296201 3298200 50mm f/2 Summicron-R 1984 2000
3302201 3306200 50mm f/2 Summicron-R 1984 4000
3310701 3312700 50mm f/2 Summicron-R 1984 2000
3322201 3323200 50mm f/2 Summicron-R 1984 1000
3337201 3340200 50mm f/2 Summicron-R 1984 3000
3351801 3353800 50mm f/2 Summicron-R 1985 2000
3353801 3354800 50mm f/2 Summicron-R 1985 1000
3379001 3380500 50mm f/2 Summicron-R 1985 1500
3391801 3392800 50mm f/2 Summicron-R 1986 1000
3411891 3412890 50mm f/2 Summicron-R (11 216) 1986 1000
3437501 3438500 50mm f/2 Summicron-R 1987 1000
3441001 3442400 50mm f/2 Summicron-R 1987 1400
3479101 3480600 50mm f/2 Summicron-R 1988 1500
3488791 3489190 50mm f/2 Summicron-R 1989 400
3495301 3495660 50mm f/2 Summicron-R 1989 360
3507846 3507995 50mm f/2 Summicron-R 1990 150
3510796 3512795 50mm f/2 Summicron-R (11 215) 1990 2000
3534768 3536767 50mm f/2 Summicron-R 1990 2000
3567473 3569472 50mm f/2 Summicron-R 1991 2000
3573133 3573133 50mm f/2 Summicron-R 1991 1
3586940 3586959 50mm f/2 Summicron-R 1992 20
3617080 3617879 50mm f/2 Summicron-R 1993 800
3619133 3620132 50mm f/2 Summicron-R 1993 1000
3628901 3630000 50mm f/2 Summicron-R 1993 1100
3632401 3633400 50mm f/2 Summicron-R 1993 1000
3655826 3655830 50mm f/2 Summicron-R 1994 5
3667031 3668030 50mm f/2 Summicron-R 1994 1000
3677031 3678030 50mm f/2 Summicron-R 1995 1000
3735701 3736700 50mm f/2 Summicron-R 1996 1000
3764800 3765799 50mm f/2 Summicron-R 1996 1000
3784330 3785329 50mm f/2 Summicron-R 1997 1000
3818625 3819624 50mm f/2 Summicron-R (11 345) 1998 1000
3840500 3841499 50mm f/2 Summicron-R 1998 1000
3868617 3869616 50mm f/2 Summicron-R 1999 1000
3916023 3917022 50mm f/2 Summicron-R (11 345) 2001 1000
unknown unknown 50mm f/2 Summicron-R 2006-2009 unknown
TOTAL ASSIGNED SERIAL NUMBERS 1976-2001 99,736
