35mm f/1.4 ASPH.2 Summilux-M
Revision as of 15:36, 21 February 2012 by Admin (talk | contribs) (→35mm f/1.4 ASPH.2 Summilux-M Serial Numbers)
- Leica Order No. - 11 663-black - -titanium
- Production era - 2010-Current
- Angle of view (diagonal, horizontal, vertical) For 35 mm format (24 x 36 mm): 63°, 54°, 37°, for M8 & M8.2 (18 x 27 mm): 49°, 42°, 28°, equivalent to approx. 47 mm for 35 mm format
- Optical design
- Number of lenses/groups - 9 /5
- Focal length - 35.6 mm
- Aspherical surfaces - 1
- Position of entrance pupil - 16.6 mm from the apex of the first lens element
- Distance settings
- Focusing range - 0.7 m to ∞
- Smallest object field/ Largest reproduction ratio - For 35 mm format: approx. 418 × 626 mm /1:17.4 (for M8 approx. 313 × 470 mm /1:17.4)
- Aperture
- Setting/function - f/1.4-16 with click-stops, half values available / 9-blade
- Mount - Leica M quick-change bayonet with 6-bit bar-coding for digital M-models
- Filter - Inner threading for E46 screw-in filters, non-rotating front element
- Accessories - Hood: Full-metal, rectangular, screw-mount hood (supplied with the lens)
- Dimensions and weight
- Length to bayonet flange - Approx. 46 /58 mm (with /without lens hood)
- Largest diameter - Approx. 56 mm
- Weight - Approx. 320 g
- Data from - May 17, 2010 Leica press release
Serial numbers compiled from known lenses| SN Start | SN End | Product | Year | Total |
| -4080624 | 4095807- | Super-Elmar-M f= 18mm 1:3.8 | 2010 | 15,184+ |
| -4099573 | 4123627- | Super-Elmar-M f= 18mm 1:3.8 | 2010 | 24,055+ |
| -4139472 | 4139630- | Super-Elmar-M f= 18mm 1:3.8 | 2011 | 159+ |
| -414XXXXX | unknown | Super-Elmar-M f= 18mm 1:3.8 | 2011 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2010- | unknown |
