21mm f/3.4 ASPH Super-Elmar-M
- Production era - 2011-current
- Angle of view (diagonal, horizontal, vertical)
- for 35mm (24 x 36 mm) - 91°, 80°, 59°
- for M8 (18 x 27 mm) - 74°, 64°, 46° (Equivalent focal length : approx. 28 mm)
- Optical design
- Number of lenses/groups - 8 / 7 - Aspherical surfaces: 2
- Position of entrance pupil - 15.6 mm (related to the first lens surface in light direction)
- Distance setting
- Focus range - 0.7 m - ∞
- Smallest object field - 706 mm x 1059 mm (35mm) / 530 mm x 795 mm (for M8)
- Largest reproduction ratio - 1 : 29.4
- Aperture
- Setting/Function - With click-stops, half values available, 9-blade manual diaphragm
- Lowest value - f /16
- Bayonet - Leica M quick-change bayonet with 6 bit lens identification bar code for digital M models
- Filter mount/Lens hood
- Hood 12465
- Non-rotating
- Female thread - for screw-on filters E46
- Male thread - with stop for lens hood (included in delivery)
- Dimension and weight
- Length - ca. 43 /55 mm (with /without Lens hood)
- Largest diameter - approx. 53mm
- Weight - approx. 279 g
- Inscription - LEICA SUPER-ELMAR-M 21mm 1 : 3.4 / 21 APSH. E46 4XXXXXX
- Source - Manufacturer's Technical Data 21 Jun 2011
- From Erwin Puts Blog "I am asked quite often what three or four lenses I would select that best represent the Leica philosophy. For this moment in time I would propose the following set:
- Super-Elmar-M 3.4/21mm ASPH
- Summilux-M 1.4/35 mm ASPH (latest version)
- Summicron-M 2/75 ASPH
- Here are the arguments: . . ."
21mm f/3.4 ASPH Super-Elmar-M Serial Numbers
Serial numbers compiled from known lensesSN Start | SN End | Product | Year | Total |
-4108622 | 4108934- | Super-Elmar-M ASPH f= 21mm 1:3.4 | 2011 | 313+ |
-4121216 | unknown | Super-Elmar-M ASPH f= 21mm 1:3.4 | 2011 | unknown |
TOTAL | ASSIGNED | SERIAL NUMBERS | 2011- | unknown |
