50mm f/1.4 Summilux-M II
Revision as of 17:14, 28 February 2012 by Admin (talk | contribs) (→50mm f/1.4 Summilux-M II Serial Numbers)
- Leica Order No. - 11 113-black - 11 100-black - 11 114-chrom+black LLC - 127
- Production era - 1961-1991 < 43,505 lenses
- Variants - Black, chrome, knurled (KFR, as shown) and un-knurled (UFR) focusing rings and 1913-1983 anniversary versions
- F stop range - f/1.4-f/16 with full click-stops > 2028001 < half click-stops
- Diaphragm setting /type - 12-blade
- Filter type - E43
- Accessories - Hood: - XOOIM - 12521 - 12586
- Materials - Black anodized aluminum or chrome plated brass
- Dimensions (length x diameter) - 54.5 x 47.7 mm /
- Weight - 275 g aluminum, 380 g chrome
- Inscription - LEITZ WETZLAR SUMMILUX 1:1.4/50 E46 388XXXX
- Designer - Walter Mandler
- On the street - $US 1,150 in 2010
Serial numbers compiled from Puts Pocket Pod.* Lens 2992238 is Summilux-M 35 mm f/1.4
.** Lens 3156855 is Leica Apo - Telyt - R 3,4 / 180
^ Lens 2198417 is a screw mount (chrome)
1844001 | 1846000 | Summilux f= 5 cm 1:1.4 (M+S-chrom) | 1961 | 2000 |
1883001 | 1884000 | Summilux f= 5 cm 1:1.4 (chrom) | 1961 | 1000 |
1884101 | 1885000 | Summilux f= 5 cm 1:1.4 | 1961 | 900 |
1897001 | 1899000 | Summilux f= 5 cm 1:1.4 (chrom) | 1961 | 2000 |
1927001 | 1929000 | Summilux f= 5 cm 1:1.4 (chrom) | 1962 | 2000 |
1945001 | 1947000 | Summilux f= 5 cm 1:1.4 (chrom) | 1962 | 2000 |
1999999 | 2000001 | Summilux f= 5 cm 1:1.4 | 1963 | 3 |
2028001 | 2029000 | Summilux f= 5 cm 1:1.4 (black+chrom) | 1964 | 1000 |
2039701 | 2040700 | Summilux f= 5 cm 1:1.4 (black) | 1964 | 1000 |
2048501 | 2049500 | Summilux f= 5 cm 1:1.4 (chrom-KFR) | 1964 | 1000 |
2071501 | 2073500 | Summilux f= 5 cm 1:1.4 (black+chrom) | 1964 | 2000 |
2198101 ^ | 2199100 | Summilux f= 5 cm 1:1.4 (black+chrom) | 1966 | 1000 |
2220201 | 2221200 | Summilux f= 5 cm 1:1.4 (chrom-UFR) | 1967 | 1000 |
2308251 | 2309750 | Summilux f= 5 cm 1:1.4 (black-UFR) | 1968 | 1500 |
2345301 | 2347300 | Summilux f= 5 cm 1:1.4 (black-KFR+UFR) | 1969 | 2000 |
2418201 | 2420200 | Summilux f= 5 cm 1:1.4 (black-UFR) | 1970 | 2000 |
2503101 | 2505100 | Summilux f= 5 cm 1:1.4 (black) | 1972 | 2000 |
2568551 | 2570550 | Summilux f= 5 cm 1:1.4 (black-UFR) | 1973 | 2000 |
2624601 | 2625600 | Summilux f= 5 cm 1:1.4 (black-UFR) | 1973 | 1000 |
2628051 | 2629600 | Summilux f= 5 cm 1:1.4 | 1973 | 1550 |
2821351 | 2822350 | Summilux f= 5 cm 1:1.4 | 1977 | 1000 |
2848051 | 2849050 | Summilux f= 5 cm 1:1.4 (11 114+gold) | 1977 | 1000 |
2980551 | 2981000 | Summilux f= 5 cm 1:1.4 | 1979 | 450 |
2991701 | *2992700 | Summilux-M f= 5 cm 1:1.4 | 1979 | 1000 |
3033901 | 3034400 | Summilux f= 5 cm 1:1.4 | 1980 | 500 |
3076301 | 3076800 | Summilux-M f= 5 cm 1:1.4 (black-11100) | 1980 | 500 |
3156501** | 3158500 | Summilux f= 5 cm 1:1.4 (black+13-83) | 1981 | 2000 |
3251101 | 3252100 | Summilux-M f= 5 cm 1:1.4 (black-UFR) | 1983 | 1000 |
3340201 | 3341200 | Summilux-M f= 5 cm 1:1.4 (black) | 1984 | 1000 |
3415891 | 3416890 | Summilux-M f= 5 cm 1:1.4 (black) | 1986 | 1000 |
3444901 | 3445900 | Summilux-M f= 5 cm 1:1.4 (black-UFR) | 1987 | 1000 |
3481901 | 3482900 | Summilux f= 5 cm 1:1.4 | 1989 | 1000 |
3483501 | 3484600 | Summilux f= 5 cm 1:1.4 (platinum.150 yr+black-11114) | 1989 | 1100 |
3493301 | 3495300 | Summilux f= 5 cm 1:1.4 (black) | 1989 | 2000 |
3500000 | 3500000 | Summilux-M f= 5 cm 1:1.4 | 1989 | 1 |
3500150 | 3500150 | Summilux-M f= 5 cm 1:1.4 | 1989 | 1 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1961-1989 | 43,505 |
Lens superseded by 50mm f/1.4 Summilux-M III
