Black and White Slide and Print Film
Revision as of 02:08, 30 August 2012 by Admin (talk | contribs) (→BLACK & WHITE "35 mm" NEGATIVE FILM)
The following tables are adapted from Photon Detector courtesy of Nicolai Morrisson.
Brand Name | Trade Name | ISO | Other Available Film Sizes |
Largest Sheet Size |
Mfgr Data |
ADOX | Bluefire Police | 80-100 | 2010 | ||
CMS 20 Forum discussion | 6-25 | 2010 | |||
Pan 400 Forum discussion | 400 | 110 - 120 | 8 x 10 in | 2010 | |
AGFA | Agfapan APX 100 | 100 | 9.5 - 120 | 18 x 24 cm | 2003 |
Agfapan APX 400 Forum discussion [1] | 400 | 9.5 - 120 | 2003 | ||
BERGGER | BPF / BRF 200 | 200 | 120 | 20 x 24 in | 2006 |
BPF / BRF 400 | 400 | 120 | 20 x 24 in | ||
CLASSIC | Classic Pan 100 eco | 100 | 120 | ||
Classic Pan 200 | 200 | 120 | 8 x 10 in | 2010 (de) | |
Classic Pan 400 | 400 | 120 | 8 x 10 in | 2010 (de) | |
EFKE | efke KB25 Forum discussion [2] | 25 | 100 ft roll | 2010 | |
efke KB50 | 50 | 100 ft roll | 2010 | ||
efke KB100 | 100 | 100 ft roll | 2010 | ||
efke KB400 | 400 | 100 ft roll | 2010 | ||
efke IR820 | 100 | 120 - 127 | 8 x 10 in | 2010 | |
FOMA | Fomapan 100 Classic Arista.EDU Ultra 100 Forum discussion |
100 | 120 | 18 x 24 cm | 2009 |
Fomapan 400 Action Forum discussion | 125 | 120 | 2009 | ||
Fomapan 400 NIR 730 (Infrared) |
400 | 2004 | |||
FUJIFILM | Neopan 100 Acros Forum discussion | 100 | 120 | 4 x 5 in | 2001 |
Film Range PDF | Neopan 400 Professional Forum discussion [3] [4] | 400 | 120 | 1995 | |
Neopan 1600 Professional Forum discussion [5] [6] | 1600 | 100 ft roll | 1995 | ||
GIGIBITFILM | 135 / 36 | 40 | 2004 | ||
Sheet Film | 25 | 4 x 5 in | 2002 | ||
ILFORD | Delta 100 Professional Forum discussion [7] | 100 | 9.5 - 120 - 30.5 m roll | 13 x 18 cm | 2010 |
Delta 400 Professional | 400 | 120 - 30.5 m roll | 2010 | ||
Delta 3200 Professional Forum discussion | 1200 | 120 | 2010 | ||
FP4 Plus Survey Results | 125 | 120 - 30.5 m roll | 20 x 24 in | 2010 | |
HP5 Plus Forum discussion | 400 | 120 | 20 x 24 in | 2010 | |
Pan F Plus Forum discussion [8] [9] | 50 | 120 - 30.5 m roll | 2004 | ||
SFX 200 (Infrared) | 200 | 120 | 2007 | ||
KODAK | Professional Tri-X 320 and 400 Forum discussion [10] [11] | 320 | 120 - 220 | 35 & 70mm rolls | 2007 |
Professional Plus-X 125 | 125 | 120 - 220 | 2007 | ||
Professional Tmax 100 Forum discussion | 100 | 120 | 8 x 10 in | 2007 | |
Professional Tmax 400 Erwin Puts | 400 | 120 | 2007 | ||
Professional Tmax 3200 Forum discussion (Discontinued) | 1000 | 120 | 2007 | ||
KONICA | Infrared 750 | 120 | 2001 | ||
LUCKY | SHD 100 | 100 | 120 | 2010 | |
SHD 400 | 400 | 2010 | |||
MACO | Rollei Pan 25 Forum discussion | 400 | 120 - 30.5 m roll | 8 x 10 in | 2005 |
Rollei ATP 1.1 | 32 | 120 - 30.5 m roll | 2007 | ||
Rollei Infrared 400 Forum discussion | 400 | 120 - 115 m roll | 4 x 5 in | 2005 | |
Rollei Ortho 25 | 25 | 120 - 40 m roll | 8 x 10 in | 2009 | |
Rollei Superpan 200 | 200 | 120 - 30.5 m roll | 2004 | ||
Rollei Retro 80S | 25 | 120/ 7 - 30.5 m roll | 2004 | ||
Rollei Retro 100 Forum discussion [12] | 100 | 30.5 m roll | 2008 | ||
Rollei Retro 400S | 400 | 120 - 30.5 m roll | 2008 | ||
ULTRAFINE | Ultrafine B & W Plus 100 | 100 | 120 - 100 ft roll | 2010 | |
Ultrafine B & W Plus 400 | 400 | 120 - 100 ft roll | 2010 | ||
UltraMax T-Grain 400 | 400 | 100 ft roll | 2010 |
BLACK & WHITE "35 mm" C-41 PROCESS FILM
Mfgr Data |
ILFORD | XP2 Super Forum discussion [13] [14] [15] [16] | 400 | 120 - 30.5 m roll | 2001 | |
KODAK | BW400CN Forum discussion [17] [18] [19] | 100 - 200 | 120 | 2004 | |
C-41 Black & White | 400 | 2003 |
BLACK & WHITE "35 mm" SLIDE FILM
Mfgr Data |
AGFA | Scalla 200x | 200 | 120 | 2003 | |
FOMA | Fomapan R | 100 | 620 | 2009 | |
MACO | Rollei Slide Direct | 10 | 4 x 5 in | 2010 |
NOTES
- Data is for "35 mm" = 135 mm (width) camera film.
- Other film formats are listed (if available): 9.5 mm sub-miniature film - 120 mm - 127 mm - 220 mm - 640 mm - roll = bulk film (longest available length is shown).
- If the largest available film roll or sheet size is listed smaller sizes may be purchased - check with the manufacturer.
- Latest year of manufacturer's data is shown in English language (if available) or otherwise noted in German (de).
- [20] [21] [22] [23]
- Test shots
