F
| FARBA | ELW Afgacolor filter 301 for "taking" lens used with Hektor f= 7.3 cm 1:1.9 and Summar f= 5 cm 1:2 | 1934-1935 | - |
| FARLY | FARUX Scale ring for Elmar 13.5 cm or Hektor f= 7.3 cm 1:1.9 | ca.1933 | - |
| FAROS | FARUX Scale ring for Elmar (I) f= 5 cm 1:3.5 | ca.1933 | |
| FARPU | ELW Afgacolor filter 351 for projection lens used with Hektor f= 7.3 cm 1:1.9 and Summar f= 5 cm 1:2 | 1934-1935 | - |
| FARUX | Panoramic tripod head | 1933-1936 | JCB's a little...Standard |
| FASKI | FARUX Scale ring for Elmar f= 10.5 cm 1:6.3 | ca.1933 | |
| FAVOO | No. 2 medium yellow filter; screw-on type H | ca.1935 | - |
| FAWAG | FARUX Scale ring for Hektor f= 7.3 cm 1:1.9 | ca.1933 | |
| FAXIS | FARUX Scale ring for Elmar (I) f= 9 cm 1:4 | ca.1933 | |
| FAZOY | No. 3 dense yellow filter; screw-on type H; superseded by OBOOE in 1939 | ca.1933-1938 | NY item |
| FBOOK | UVa filter; screw-on type H | ca.1935 | - |
| FBXOO | Panchromatic green no. 1 filter; screw-on type H | ca.1935 | - |
| FCKOO | Single film holder for Ic, IIc, IIf, IIIc, IIIf to sn. 590681 | 1951-1960 | - |
| FCOOI | No. 2 medium infra-red filter; screw-on type H | ca.1935 | - |
| FCZOO | No. 1 light infra-red filter; screw-on type F | ca.1931 | - |
| FDOOH | No. 3 dark infra-red filter; screw-on type G | ca.1935 | - |
| FEARM | Copy arm used with FESSA base and FEHUN column | 1931-19?? | - |
| FEDOO | No. 1 light infra-red filter; slip-on type A36 | ca.1931-1950's | 13040 |
| FEFFU | Copy base and column, used with FILUM arm and STALI lighting = FEPRO | 1931-19?? | - |
| FEHUN | Column support used with FESSA base and FEARM | 1931-19?? | - |
| FEOOG | No. 3 dark infra-red filter; slip-on type A36 | ca.1935-1950's | 13050 |
| FEPRO | Copy stand with FEFFU base, column, FILUM arm and STALI lighting | 1931-19?? | used with front lenses 2 & 3, WICAP and WINKO |
| FESSA | Copy base used with FEHUN column and FEARM | 1931-19?? | - |
| FESTO | Copy stand with FESSA or FEHUN column and FEARM with STALLI lighting | 1931-19?? | used with front lenses 1, 2 or 3, WICAP and WINKO |
| FGHOO | Replacement hood for Hektor f= 7.3 cm 1:1.9 | 1936-1946 | - |
| FGOOE | No. 1 light infra-red filter; screw-on type I | ca.1933 | - |
| FHKOO | Single film holder for I, II, III, IIIa, IIIb1 | 1935-1960 | - |
| FHOOD | No. 3 dark infra-red filter; screw-on type I | ca.1935 | - |
| FIAKU | Small ball and socket tripod head; nickel plated until 1936; earliest had dished camera support plate | 1926-19?? | JCB's a little...IIIa |
| FIALT | Holder for film handling during the development process | 1930's | - |
| FIAMA | Panoramic tripod head for 5 cm lens Forum discussion | 1926-1930 | - |
| FIARO | Stereoly slide bar 75 mm long | 1926-1926 | - |
| FIATE | Stereoly slide bar 150 mm long; early version had center tripod bush; later versions with off-center tripod bush | 1926-1940 | - |
| FIAVI | Angle bracket to support camera on panorama head | 1929-19?? | - |
| FIBLA | Small canister spirit level for camera top shoe or on FIAVI for vertical pictures; replaced by DOOLU in 1936 | 1929-1935 | - |
| FIBOB | No. 2 medium infra-red filter; screw-on type G | ca.1933 | - |
| FIBOS | Leather neck strap with metal snap hooks for cameras with side lugs | 1936-ca.1950 | - |
| FICAT | No. 1 light yellow filter; screw-on type F | ca.1930 | - |
| FICFA | Kodachrome type A flash filter; ADFIK 34 mm mount | ca.1949-1950's | - |
| FICHR | Kodachrome flash filter; slip-on type A36 | ca.1949-1950's | - |
| FICOM | No. 2 medium yellow filter; screw-on type F | ca.1930 | - |
| FICOR | Panchromatic green no. 2 filter; slip-on type A36 | ca.1945 | NY item |
| FICUR | No. 3 dense yellow filter; screw-on type F; | ca.1930 | - |
| FIDAY | Kodachrome type F filter; screw-on type L | ca.1959- | - |
| FIDAYMI | Kodachrome type A filter; screw-on type E39 | ca.1949- | NY item |
| FIDRI | Shutter release cable, 10 feet long Fontenelle archive | 1931-19?? | - |
| FIEKT | Polarising filter; swing-out, slip-on type C with clamping screw | ca.1939 | NY item |
| FIFLO | Kodachrome photo-flood filter; screw-on type L | ca.1949-1950's | NY item |
| FIFLOMI | Kodachrome photo-flood filter; screw-on type E39 | ca.1949- | NY item |
| FIGAM | No. 2 medium yellow filter; slip-on type A36 Forum discussion | ca.1931-1950's | - |
| FIGDA | Panchromatic green no. 2 filter; ADFIK 34 mm mount | ca.1945 | NY item |
| FIGIL | Graduated Yellow filter; slip-on type C | ca.1931 | - |
| FIGON | Adaptor for FISUM polarising filter on Contax | 1949-1950's | NY item |
| FIGRO | No. 1 light yellow filter; slip-on type A36 | ca.1931-1950's | 13005 |
| FIGUN | No. 1 light yellow filter; ADFIK 34 mm mount | ca.1945-1950's | NY item |
| FIHAZ | Kodachrome haze filter; screw-on type L | ca.1949-1950's | NY item |
| FIHEL | No. 0 very light yellow filter; slip-on type A36 | ca.1933 | 13000 |
| FIIRL | No. 1 light infra-red filter; ADFIK 34 mm mount | ca.1949-1950's | NY item |
| FIKAT | Kodachrome type A filter; slip-on type A36 | ca.1949- | NY item |
| FIKHA | Kodachrome haze filter; ADFIK 34 mm mount | ca.1949-1950's | NY item |
| FIKLO | Kodachrome photo-flood filter; slip-on type A36 | ca.1949-1950's | NY item |
| FIKOZ | Kodachrome haze filter; slip-on type A36 | ca.1949-1950's | NY item |
| FIKUS | Extendable hood for 4 focal lengths: 3.5-13.5; early black & nickel; later black & chrome; NY all chrome version | 1933-1965 | 12530 JCB's a little...II |
| FIKYB | No. 2 medium infra-red filter; slip-on type A36 | ca.1933-1950's | - |
| FILAR | Early wood box enlarger, up to postal card size, per WestLicht auction 17/239 | ca.1925-1926 | - |
| FILBY | No. 1 light yellow filter; slip-on type A | ca.1926 | - |
| FILCA | Film cassette originally for Leica I (model A) only; center spool with locking device introduced in 1939; postwar with shiny brown finish | 1925-1954 | JCB's a little...I |
| FILES | Enlarger used with FILUM arm, FEFFU base and column with lenses 2 & 3 | 1931-19?? | - |
| FILGE | No. 2 medium yellow filter; slip-on type A Forum discussion | ca.1925 | - |
| FILOY | Enlarger used with FILUM arm, FEFFU base and column with front lenses 2 & 3 | 1931-19?? | - |
| FILPO | Polarising filter; swing-out, slip-on type A36 with clamping screw | ca.1939 | NY item |
| FILSO | No. 1 light yellow filter; slip-on type C | ca.1933 | - |
| FILTU | No. 3 dense yellow filter; slip-on type A | ca.1925-1926 | - |
| FILUM | Copy arm (camera bracket) used with FEFFU base and column and STALI lighting = FEPRO | 1931-19?? | - |
| FILXA | No. 3 dense yellow filter; screw-on type I | ca.1933 | - |
| FILYT | Enlarger or copying device used with FEARM arm, FESSA or FEHUN base and column with front lenses 2 & 3 | 1931-19?? | - |
| FIMAN | Glass drum developer Fontenelle archive | 1931-19?? | - |
| FIMOO | No. 0 very light yellow filter; screw-on type H | ca.1935 | - |
| FINAL | Shutter release cable for Leica I (model A) | ca.1925 | - |
| FINON | Polarising filter; swing-out, screw-on type E41 with clamping screw | ca.1939-1950's | NY item |
| FINOT | Shutter release cable, 10 inches long Fontenelle archive | 1931-19?? | - |
| FINOW | Shutter release cable, 10 inches long; metal sheathed | 1939-19?? | NY item |
| FINUS | No. 3 dense yellow filter; screw-on type G | ca.1931 | NY item |
| FIOKO | UVa filter; screw-on type F | ca.1931 | - |
| FIOLA | UVa filter; slip-on type A36 | ca.1931 | 13055 |
| FIOMU | No. 2 medium infra-red filter; slip-on type C | ca.1933 | - |
| FIONA | Orange filter; ADFIK 34 mm mount | ca.1945-1950's | NY item |
| FIOOC | No. 1 light yellow filter; screw-on type H | ca.1935 | - |
| FIOPY | No. 0 very light yellow filter; slip-on type C | ca.1933 | - |
| FIORE | UVa filter; screw-on type G | ca.1931 | - |
| FIOSI | UVa filter; slip-on type C | ca.1933 | - |
| FIOUX | FSEOO Orange filter; slip-on type A36 | ca.1939 | NY item |
| FIPAN | Panchromatic green no. 1 filter; ADFIK 34 mm mount | ca.1945-1950's | NY item |
| FIPHO | Kodachrome photoflood filter; ADFIK 34 mm mount | ca.1949-1950's | NY item |
| FIPLO | No. 2 medium infra-red filter; screw-on type I | ca.1933 | - |
| FIPOS | Panchromatic green no. 1 filter; slip-on type A36 | ca.1933-1950's | 13015 |
| FIPPA | No. 2 medium yellow filter; slip-on type C | ca.1933 | - |
| FIQUX | Orange filter; slip-on type A36 | ca.1939-1950's | NY item |
| FIRAD | Graduated Yellow filter; slip-on type A36 | ca.1931 | - |
| FIRCO | Intermediate collar for using a slip-on filter for Compur Leica (model B) | 1931-19?? | - |
| FIREG | No. 1 light yellow filter; screw-on type I | ca.1933 | - |
| FIRGI | Intermediate collar for using a slip-on filter in conjunction with supplementary lenses | 1931-19?? | - |
| FIRHE | No. 1 light yellow filter; screw-on type G | ca.1931 | 13001 JCB's a little...IIIa |
| FIRHU | Rear dust cover for screw lenses | 1939-ca.1954 | - |
| FIRMY | No. 2 medium yellow filter; screw-on type G | ca.1931 | - |
| FIROL | Adaptor for FILPO polarising filter on Rolleiflex or Rolleicord | 1949-1950's | NY item |
| FIRYX | Panchromatic green no. 1 filter; screw-on type I | ca.1933 | - |
| FISAP | Panchromatic green no. 1 filter; slip-on type C | ca.1933 | - |
| FISEX | Shutter release cable, 20 feet long | 1931-19?? | - |
| FISKF | Kodachrome skylight filter; slip-on A36 mount | ca.1954- | NY item |
| FISON | Hood for 5 cm ELMAR; black cylinder with rectangular aperture until 1933 when changed to round aperture; last version was chrome with set screw | 1925-1963 | 12510 JCB's a little...IIIa |
| FISUM | Polarising filter; swing-out, screw-on type L with clamping screw | ca.1939 | NY item |
| FISUMMI | Polarising filter; swing-out, screw-on type E39 with clamping screw | ca.1939 | NY item |
| FITAF | Kodachrome type A filter; ADFIK 34 mm mount | ca.1949- | NY item |
| FITWO | No. 2 yellow filter; ADFIK 34 mm mount | ca.1945-1950's | NY item |
| FIUNS | No. 0 very light yellow filter; slip-on type A | ca.1933 | - |
| FIVPL | Complete unit for surgical operation photography with cast iron base and rack and pinion movement | 1939-19?? | |
| FIWAS | No. 0 very light yellow filter; screw-on type I | ca.1933 | - |
| FIWET | UVa filter; screw-on type I | ca.1933 | - |
| FIWIG | No. 2 medium yellow filter; screw-on type I | ca.1933 | - |
| FIXIO | Panchromatic green no. 1 filter; screw-on type G | ca.1933 | - |
| FIXTA | No. 0 very light yellow filter; screw-on type G Forum discussion | ca.1933 | - |
| FIZEN | Slip-on Bakelite hood for Elmar f= 10.5 cm 1:6.3 "The Mountain Elmar" | 1932-1937 | - |
| FKDELM | Kodachrome type F filter; slip-on type A36 | ca.1959- | - |
| FKDSAX | Kodachrome type F filter; screw-on type E58 | ca.1959- | - |
| FKDSMI | Kodachrome type F filter; screw-on type E39 | ca.1959- | - |
| FKDSMT | Kodachrome type F filter; screw-on type E41 | ca.1959- | - |
| FKDTEL | Kodachrome type F filter; screw-on type E48 | ca.1959- | - |
| FLASH | Horizontal mounted flash unit (like SYNCO) for Standard Leica (model E) | ca.1938 | - |
| FLECT | Dull surfaced flash reflector for portraits | ca.1938 | - |
| FLOOA | UV light copying device with ELMAR | 1939-19xx | - |
| FLOTH | Plumbbob for copy stand use with U-shaped or angular harness for ELMAR; FLOTH + STARE = STAOT copy stand | 1931-19?? | - |
| FLQOO | Hood for 35 mm Elmar; black or chrome; superseded by FOOKH | 1936-1950 | also chrome NY version |
| FMOOZ | No. 1 light infra-red filter; slip-on type C | ca.1933 | - |
| FMSOO | No. 3 dark infra-red filter; slip-on type C | ca.1935 | - |
| FNOOY | No. 1 light infra-red filter; screw-on type H | ca.1935 | - |
| FNUOO | No. 3 dark infra-red filter; screw-on type H | ca.1935 | - |
| Focomat | Enlarging device used with Visoflex II & III - Models Ia, Ib, Ic, IIa, IIb, IIc & V35 Forum discussion | 1963-1995 | Glennview - V35 |
| Focometer | Timing and adjustment module for Focomat | 1963-19?? | Forum discussion [1] [2] |
| Focorapid | See 14112 - 14113 - 14114, Focorapid | - | |
| Focoslide | See FULDY and FULEC | - | |
| Focotar | Leitz enlarger lenses: 50 mm (3 types) for the Focomat Ic & II, and Leitz Enlarger lenses see | 1949-1983 | Forum discussion |
| FODIS | Longbase rangefinder with leather case to measure distance from film plane to object; metric and feet versions | 1925-1929 | 2.15 cm wheel |
| FODUA | Longbase rangefinder (without leather case) to measure distance from film plane to object; metric and feet versions | 1925-1929 | 2.15 cm wheel |
| FOFER | Longbase rangefinder with leather case to measure distance from film plane to object; metric and feet versions with fixing clip; Nagel version has N on the wheel | 1925-1939 | 3.5 cm wheel |
| FOKAL | Hinged bracket for attaching FOKIN to camera | 19xx-19xx | - |
| FOKIN | Longbase rangefinder for cine cameras | 1926-1940 | 3.5 cm wheel |
| FOKOS | Short black & nickel, black & chrome or all chrome rangefinder with 7.5 cm base; after 1949 - chrome only version with 6.2 cm base | 1933-1966 | - |
| FOKUX | Ball and socket joint for longbase rangefinder | 19??-1940 | - |
| FONOR | Longbase rangefinder for 6x9 to 10x15 cm; metric and feet versions | 19??-1940 | - |
| FONOT | Shutter release cable, 10 inches long with set screw | 1955-19?? | 14067 |
| FOOBD | Graduated Green filter; slip-on type A36 | ca.1938 | - |
| FOOCR | Graduated Green filter; slip-on type C | ca.1938 | - |
| FOODE | Focotar 1:4.5 / 95 mm | 1949-1959 | - |
| FOOKH | Hood for 3.5 cm Summaron & Elmar | 1951-1966 | 12505 |
| FOOLY | 5cm/3.5 Elmar enlarging lens Forum discussion | 19??-19?? | - |
| FOOMI | Short, chrome ball and socket tripod head | 1938-1960 | 14104 (3/8") and 14105 |
| FOONW | FARUX Scale ring for Hektor 2.8 cm | ca.1936 | |
| FOOQL | FARUX Scale ring for Telyt 20 cm | ca.1936 | |
| FOOSM | Afga-color filter for "taking" lens used with Summar f= 5 cm 1:2 showing red, green & blue banding | ca.1934 | - |
| FOOVA | Tank for loading film cassettes in daylight | 1939-1950's | - |
| FOOXB | Filter holder; slip-on type A36 | ca.1951 | 13365 |
| FOOXC | Filter holder; screw-on type L | ca.1951 | - |
| FOOXD | Filter holder; screw-on type E41 | ca.1951 | 13375 |
| FOOXE | Filter holder; screw-on type E58 | ca.1951 | 13380 |
| FOOXF | Filter holder; screw-on type E48 | ca.1951 | 13385 |
| FOOXH | Filter holder; screw-on type E39 Forum discussion | ca.1955 | 13371 |
| FOOXK | Filter holder; screw-on type E43 | ca.1959 | 13384 |
| FOREST | Binocular 6 x 42 - CF | 1927-1939 | see Sport Optics |
| FORESTON | Binocular 6 x 42 | 1927-1939 | see Sport Optics |
| FORESTONA | Binocular 8 x 42 | 1927-1939 | see Sport Optics |
| FORSTA | Binocular 8 x 42 - CF | 1927-1939 | see Sport Optics |
| FOSAR | Angular bracket for holding ground glass housing VEHIG | ca.1933 | - |
| FPKELM | Kodachrome type FP filter; slip-on type A36 | ca.1959- | - |
| FPKSAX | Kodachrome type FP filter; screw-on type E58 | ca.1959- | - |
| FPKSMI | Kodachrome type FP filter; screw-on type E39 | ca.1959- | - |
| FPKSMT | Kodachrome type FP filter; screw-on type E41 | ca.1959- | - |
| FPLTEL | Kodachrome type FP filter; screw-on type E48 | ca.1959- | - |
| FPOOW | Orange filter; screw-on type G | ca.1939 | - |
| FQOOV | Orange filter; screw-on type H | ca.1939 | - |
| FRCOO | Orange filter; screw-on type I | ca.1939 | - |
| FSEOO | Orange filter; slip-on type C | ca.1939-1950 | - |
| FTGOO | Orange filter; slip-on type A36 | ca.1939 | 13025 |
| FUECD | Complete extension tube set for FULDY; also for OORES | 1936-1939 | - |
| FUFIF | 15 mm extension tube for FULDY | 1936-1939 | NY item |
| FUFOR | 45 mm extension tube for FULDY | 1936-1939 | NY item |
| FULDY | Sliding focusing stage using Leica screw thread to hold camera (later know as "Focoslide") in 4 types for various screw-thread cameras to sn. 400000; superseded by FULEC Forum discussion | 1930-1951 | [3]Fontenelle archive |
| FULEC | Sliding focusing stage using Leica screw thread to hold camera for screw-thread cameras after sn. 400000 | 1948-1951 | - |
| FULET | Like FULDY without sliding camera attachment | ca.1939 | NY item |
| FULFO | 30 mm extension tube for FULDY | 1936-1950's | NY item |
| FULGX | 60 mm extension tube for FULDY | 1936-1950's | NY item |
| FULHI | 90 mm extension tube for FULDY | 1936-1950's | NY item |
| FULOR | 12 mm extension tube for FULDY | 1936-1939 | NY item |
| FUSEV | 7 mm extension tube for FULDY | 1936-1939 | NY item |
| FVOOQ | 15 mm extension tube for ZWTOO-HESUM Summar focusing mount | ca.1949-1950's | - |
