35mm–70mm f/3.5 Vario-Elmar-R
Revision as of 22:02, 5 April 2012 by Admin (talk | contribs) (→35mm–70mm f/3.5 Vario-Elmar-R Serial Numbers)
- Leica Order No. - 11 244 - 11 248
- Production era - 1983-1996 < 31,610 lenses
- Manufacturer - E60 Minolta - E67 ELW
- Variants - E60 (shown), E67 after no. 3393301 in 1986
- Number of lenses /groups - 8 / 7
- F stop range - f/3.5-f/22
- Closest focusing distance - 1 m / 3.28 ft
- Smallest object field - 632 x 947 and 338 x 507 mm
- Diaphragm setting /type - 7-blade
- Angle of view diagonal - 64 - 35 degrees
- Filter type - E60, E67 after no. 3393301
- Accessories -
- Dimensions length x diameter - 64.5 x 72 mm / 2.54 x 2.83 in
- Weight - 420 g /0.93 lb, 450 g /0.99 lb after no. 3393301
- Inscription - LEITZ VARIO-ELMAR-R 1:3.5/35-70 E60 3XXXXXX
LEICA VARIO-ELMAR-R 1:3.5/35-70 E 67 3XXXXXX
| 3171001 | 3175000 | 35mm–70mm f/3.5 Vario-Elmar-R | 1982 | 4000 |
| 3241701 | 3245100 | 35mm–70mm f/3.5 Vario-Elmar-R (3-cam) | 1982 | 3400 |
| 3284401 | 3288400 | 35mm–70mm f/3.5 Vario-Elmar-R (3-cam) | 1983 | 4000 |
| 3308201 | 3308700 | 35mm–70mm f/3.5 Vario-Elmar-R | 1984 | 500 |
| 3317701 | 3322200 | 35mm–70mm f/3.5 Vario-Elmar-R | 1984 | 4500 |
| 3346201 | 3349800 | 35mm–70mm f/3.5 Vario-Elmar-R | 1985 | 3600 |
| E60 | ABOVE | BELOW | E67 | |
| 3393301 | 3394600 | 35mm–70mm f/3.5 Vario-Elmar-R | 1986 | 1300 |
| 3418891 | 3420890 | 35mm–70mm f/3.5 Vario-Elmar-R | 1986 | 2000 |
| 3489341 | 3491400 | 35mm–70mm f/3.5 Vario-Elmar-R | 1989 | 2060 |
| 3538468 | 3540467 | 35mm–70mm f/3.5 Vario-Elmar-R | 1990 | 2000 |
| 3623801 | 3624800 | 35mm–70mm f/3.5 Vario-Elmar-R | 1993 | 1000 |
| 3652421 | 3653420 | 35mm–70mm f/3.5 Vario-Elmar-R | 1994 | 1000 |
| 3661831 | 3662830 | 35mm–70mm f/3.5 Vario-Elmar-R | 1994 | 1000 |
| 3733301 | 3734300 | 35mm–70mm f/3.5 Vario-Elmar-R | 1996 | 1000 |
| 3790260 | 3790509 | 35mm–70mm f/3.5 Vario-Elmar-R | 1997 | 250 |
| unknown | 3832945- | 35mm–70mm f/3.5 Vario-Elmar-R | 1997 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1982-1997 | 31,610 |
