M Monochrom
- Production era - 2012-current
- Camera type - Compact digital rangefinder system camera with a dedicated black-and -white image sensor
- Image sensor - Active area approx. 23.9 x 35.8 mm, 5212 x 3468 pixels (18 megapixels). Infrared blocking filter for invisible light with wavelengths longer than 700 nm, no low-pass filter
- Colour spaces - sRGB hardwired
- Exposure metering - Exposure metering through the lens (TTL), centre-weighted at working aperture
Centre-weighted TTL-metering for flash with system-compatible SCA-3000/2 standard flash units
- Metering range - at f/1.0 / ISO 320/26°: EV 1 to 21.
The left triangular LED in the viewfinder blinks when light levels are outside the lower metering range ISO sensitivity range: ISO 320/26° to ISO 10000/41°, selectable in 1/3-ISO increments with aperture priority metering(A) and manual exposure settings, choice of automatic control or manual setting. ISO 160 also available as a pull-function Exposure modes: Aperture priority (A) / Manual(M)
- Flash exposure control
- Flash connection - Hot shoe with centre and control contacts.
- Flash metering - Control by centre-weighted, TTL pre-flash metering (with SCA-3501/3502 adapters or SCA-3000 standard
- flash units - SF 24D / SF 58
- Flash exposure correction - ±3 1/3 EV in 1/3 EV increments, adjustable on SCA-3501/3502 adapter
Settings in computer mode for LEICA SF 24D, ±3 EV in 1/3 EV increments, or from 0 to –3 EV in 1 EV increments / adjustable in all modes for LEICA SF 58, ±3 EV in 1/3 EV increments Displays in flash mode: Flash ready: constant illumination of flash symbol LED in the viewfinder, flash confirmation: Constant illumination or rapid flashing of the LED after exposure, underexposure indicated by temporarily extinguished LED
- Viewfinder
Image field framing: By projection of two bright-line frames with each lens attached: for 35 and 135 mm, or for 28 and 90 mm, or 50 and 75 mm. Automatically displayed when lens mount locks. Any of the pairs of bright-line frames can be displayed by moving the frame selection lever
- Correspondence between the viewfinder and the actual image - At a focusing distance of 1 metre, the bright-line frame size corresponds precisely to that of a sensor size of 23.9 x 35.8 mm
At infinity, and depending on the focal length of the lens in use, more of the sensor is covered than the bright-line frame actually shows, the opposite is the case for focusing distances of less than 1 metre, i.e. somewhat less
- Long-base rangefinder - Bright rectangular spot (RF spot) with coincident and superimposed fields in the centre of the *viewfinder image
- Read-out
- Displays on the back - 2.5″ monitor (colour TFT-LCD) with 230,000 pixels
- Shutter/shutter release
Continuous shooting - approx. 2 fps, ≥ 8 frames in sequence
- Self-timer - Countdown 2 s (in aperture priority mode and manual exposure mode) or 12 s, menu setting option, countdown is indicated by a flashing LED on the front of the camera and a corresponding display on the monitor
Camera power on / power off Main switch located on the top deck, optional sleep mode for camera electronics after 2 / 5 / 10 minutes, reactivation by slight pressure to shutter release button
- Camera body
