M Monochrom
- Production era - July 2012-current
- Serial nos. - -4341315-
- Camera type - Compact digital rangefinder system camera with a dedicated black-and -white image sensor [JPG toning options: Sepia, Cold and Selenium- Weak or Strong] -js
- Image sensor - CCD active area approx. 23.9 x 35.8 mm, 5212 x 3468 pixels (18 megapixels). Infrared blocking filter for invisible light with wavelengths longer than 700 nm, no low-pass filter
- File type - RAW, JPG, RAW + JPG
- Color spaces - sRGB hardwired
- Exposure metering - Exposure metering through the lens (TTL), center-weighted at working aperture - Center-weighted TTL-metering for flash with system-compatible SCA-3000/2 standard flash units
- Flash exposure control
- Flash metering - Control by center-weighted, TTL pre-flash metering (with SCA-3501/3502 adapters or SCA-3000 standard
- Viewfinder
- Long-base rangefinder - Bright rectangular spot (RF spot) with coincident and superimposed fields in the center of the *viewfinder image
- Read-out
- Monitor - 2.5″ monitor display (color TFT-LCD) with 230,000 pixels and brightness adjustment
- Shutter /shutter release
- Camera body
Current Digital-M Camera Accessories
- 14 408 - Motor-M
- 14 438 - Black lacquered
- 14 488 - SF-58 Flash
- 14 489 - SF-58 diffuser
- 14 444 - SF 24D - Black /silver Flash
- 12531 - ANGLEFINDER M
- Neoprene Case M - with short front part 14867 - with long fromt part 14868
- 14 110 - Ball Head
- 14 409 - MACRO-ADAPTER-M
- 14 400 - HAND GRIP M9 - steel-gray paint
- 14 464 - Battery
- 14 463 - Standard charger
- 14 470 - Compact charger
