M
| MAALK | Micro / macro stand, complete | ? | - |
| MAARP | Leicameter-M, with a selenium booster cell | ? | - |
| MACCA | Leicameter-M, with a selenium booster cell | 19?? | - |
| MACROTAR | Early name of close-up attachment for R-Lenses, see ELPRO | 1965 | - |
| MADAX | Leicameter-M, with a selenium cell for 9x12cm | 1937 | - |
| MADHA | Micro / macro stand with holder for Leica with micro Visoflex, etc. . | 19??-19?? | - |
| MAKAM | Leicameter-M, with a selenium cell (also microscope camera per WestLicht 17/lot 238) | ca.1958 | Forum discussion |
| MAKRO | 94-400 mm - f8 /32 Lens for microscope use with RMS mount | 19??-19?? | - |
| MARDIX | Binoculars 10 x 50 | 1932-1962 | see also Sport Optics |
| MARDIXIT | Binoculars 10 x 50 - CF | 1932-1962 | see also Sport Optics |
| MARDOCE | Binoculars 12 x 60 | ca.1939-1962 | see also Sport Optics |
| MARDOCIT | Binoculars 12 x 60 - CF | ca.1939-1962 | see also Sport Optics |
| MARINODOCE | Binoculars 12 x 60 Marine version Porro-prism | 1915 | see also Sport Optics |
| MAROCTO | Binoculars 8 x 60 | 1932-1962 | see also Sport Optics |
| MAROCTIT | Binoculars 8 x 60 - CF | 1932-1962 | see also Sport Optics |
| MARSEPT | Binoculars 7 x 50 - IF Porro-prism | 1932-1962 | see also Sport Optics |
| MARSEPTIT | Binoculars 7 x 50 - CF | 1932-1962 | see also Sport Optics |
| MBOOC | Selenium cell for Leicameter-MC | 1958-19?? | JCB's a little...M3 |
| MBOOW | Selenium cell for Leicameter for METRA | 1955-19?? | JCB's a little...M3 |
| MBOOW-C | Selenium booster cell for Leicameter-MC | 1951-19?? | JCB's a little...M3 |
| MBOOWT | Selenium booster cell for Leicameter 2 | 1951-19?? | - |
| MBROO | Water-resistant aluminum case for all models up to Leica IIIf | 1950-1961 | - |
| METER | Leicameter NY version, similar to Metrawatt MF/LC 60 | 1951 | - |
| METNBC | METWMT + MBOOWT | 1954 | NY item |
| METNBD | METWMT + MBOOWT | 1956-1957 | NY item |
| METMBG | METWMT + MBOOWT, with an expanded ASA-scale | ? | NY item |
| METRA | First Leicameter-M (1955) then Leicameter-MC (1957 #14200) with a selenium booster cell Forum discussion | 1955-1960s | JCB's a little...M3 |
| METRPC | Carrying chain with bracket for METNBC and METWMT | ? | - |
| METTNC | Metrawatt Leicameter Model 3, NY version | 1956 | - |
| METWMT | Metrawatt Leicameter Model 2, NY version | 1954 | JCB's a little...IIf |
| MIBAC | For MIKAS, ½ x reducer lens | 1950 | - |
| MIBAC-M | For MIKAS, ½ x reducer lens with bayonet | 1958-1959 | - |
| MICCA | Micro camera equipment with MACCA, 4.5 x 6 cm format | 1923-1924 | - |
| MICCO | M3 sync connector for CHICO flash | ? | 15524 |
| MICCS | Like MICCO for external flash units with the same connection | ? | - |
| MICCX | M3 sync connector for CHICO flash, longer version | 1956 | - |
| MICCZ | M3 sync connector for CHICO flash, more stable version | 1958 | - |
| Micro-Isbo | see MIKAS | 1933-1960s | - |
| MIDAP | Conical adapter for MIKAS | 1930's | - |
| MIFCA | Micro 1/3x attachment with shutter for connecting to microscope body MIFILMCA | 1926-1933 | - |
| MIFOANSA | Back for MIFCA, CAFOT, etc. | ? | - |
| MIKAS | Micro attachment with lateral focusing for connecting screw Leica to a microscope Forum discussion | 1933-1950s | Forum discussion |
| MIKAS-M | Micro attachment with lateral focusing for connecting bayonet Leica to microscope | 1959-1960s | - |
| MILAR | 20-100 mm f4.5 /4.8 Lens for microscopic camera use with Aristophot system or UXOOR, Bellows II with a special, circular adapter plate | 19??-19?? | - |
| MIOOP | Camera Adapter for Microscope | 1938 | - |
| MIOOT | Camera Adapter for Microscope | 1951-1952 | - |
| MKHOO | Masking frame used on Focomator II has an automatic margin adjustment and a paper ejector Fontenelle archive | late 1950s | - |
| MONLA | Microscope lamp | 1933-19?? | - |
| MONODAL | 6 x 21 | 1908-1919 | see also Sport Optics |
| MONOT | 6 x 30 - IF | 1912-ca.1926 | see also Sport Optics |
| MOMON | 8 x 24 | 1913 | see also Sport Optics |
| MONOFOREST | 6 x 42 | 1927-1939 | see also Sport Optics |
| MONOFORSTA | 8 x 42 | 1927-1939 | see also Sport Optics |
| MONMAR | 7 x 50 | 1932-1962 | see also Sport Optics |
| MONDIX | 10 x 50 | 1932-1962 | see also Sport Optics |
| MONOCHT | 8 x 60 | 1932-1962 | see also Sport Optics |
| MONDUCE | 12 x 60 | ca.1939-1962 | see also Sport Optics |
| MOOBG | Microscope extension tube M-1:2, 16 mm | 1936-19?? | LEICA CAMERAS HISTORICA |
| MOODH | Microscope extension tube M-1:1.5, 24.5mm | 1936-19?? | LEICA CAMERAS HISTORICA |
| MOOGW | Microscope extension tube M1:1, 41mm | 1936-19?? | LEICA CAMERAS HISTORICA |
| MOOLY | Spring driven "Leica-Motor" 1st version for Leica IIIa (model G) and Leica IIIb | 1938 | JCB's a little...IIIa |
| MOOLY-C | Spring driven "Leica-Motor" 2nd version for Leica IIIc and Leica IIId | 1940-1949 | less than 200 manufactured |
| MOONZ | M3 sync connector for CEYOO flash | 1954-1960s | 15521 |
| MOOSP | Close focus tube for Telyt 20 cm lenses; 15 x 45 mm diam.; chrome or black Forum discussion Just-a-little . . . | 1935-1984 | 14020 |
| MQUOO | Mouth release Forum discussion | 19??-19?? | - |
