H
Revision as of 18:48, 27 May 2012 by Admin (talk | contribs)
HAKOSYN Flash synchronization attachment for an unmodified M3 19??-19?? -
HEBOO Slow speed shutter release for 1, 1/2, 1/4, 1/8 s in nickel or later chrome 1935-1969 -
HEFAM Hektor f= 13.5 cm 1:4.5 black M-mount 1954-1960 HEFAR-M
HEFAM-CHROM Hektor f= 13.5 cm 1:4.5 chrome M-mount 1954-1960 -
HEFAM-KUP Hektor f= 13.5 cm 1:4.5 nickel 1933 -
HEFAR Hektor f= 13.5 cm 1:4.5 chrome 1933-1959 -
HEGRA Hektor f= 7.3 cm 1:1.9 black lacquer & chrome 1934-1946 -
HEKON Hektor f= 7.3 cm 1:1.9 black lacquer & nickel 1931-1933 -
HEKTO Hektor f= 5 cm 1:2.5 nickel or chrome 1930-1936 -
HEPET Close-up supplementary front lens no. 3 for Hektor 5 cm 1928-1950's -
HEPIK Close-up supplementary front lens no. 2 for Hektor 5 cm 1928-1950's -
HEPRO Close-up supplementary front lens no. 1 for Hektor 5 cm 1928-1950's -
HFOOK Short-base clip-on rangefinder for Leica models A, B & C 1920's-ca.1936 -
HGOOI Rear cap for f = 12.5 cm 1:2.5 Hektor - with front cap ORPNO it became a container for the lens JCB's a little...If 1930's-1960's 14053
HIIBE Stand for photographing small objects; with adjusment by rack and pinion; with rotation and tilt 1939-19?? -
HIKOO f = 12.5 cm 1:2.5 Hektor Visoflex lens 1954-1963 JCB's a little...If
HKMOO Hood for f = 12.5 cm 1:2.5 Hektor- with front cap ORPNO and rear cap HGOOI was a container for the lens
JCB's a little...If
1954-1963 12532
HMOOD Hood for 90 mm f/2 Summicron 1957-19?? -
HOOAR Yellow no. 0 very light filter; screw-on type E39 ca.1955 13081
HOOBE Yellow no. 1 light filter; screw-on type E39 ca.1955 13086
HOOCS Infra-red no. 1 light filter; screw-on type E39 ca.1955 -
HOODF Infra-red no. 2 medium filter; screw-on type E39 ca.1955 -
HOOET Infra-red no. 3 dark filter; screw-on type E39 Mario Cavina ca.1955 -
HOOFG Panchromatic filter; screw-on type E39 ca.1955 -
HOOGU Orange filter; screw-on type E39 ca.1955 13101
HOOIV UVa filter; screw-on type E39 ca.1955 13131 13132
HOOKI Blue filter; screw-on type E39 ca.1955 13098
HOOPY Hektor f= 2.8 cm 1:6.3 nickel 1935-1936 -
HOOPY-CHROM Hektor f= 2.8 cm 1:6.3 chrome 1936-1955 -
HOOSN Complete Endo-Visoflex without adapter for screw-mount 19??-19?? -
HOOSN-M Complete Endo-Visoflex without adapter for M-mount 19??-19?? -
HOOTA Endo-Visoflex housing for screw-mount 19??-19?? -
HOOTA-M Endo-Visoflex housing for M-mount 19??-19?? -
HOOVB Ground glass screen in Endo-Visoflex mount 19??-19?? -
HOOWP Plain glass screen in Endo-Visoflex mount 19??-19?? -
HOOXC 4 x right-angle Endo-Visoflex magnifier 19??-19?? -
HOOYQ Lens mount with revolving disc for Endo-Visoflex 19??-19?? -
HOOZD Interchangeable lens for Endo-Visoflex 19??-19?? -
HPOOA Empty Endo-Visoflex mount for additional lenses or filters 19??-19?? -
HPWOO Correction lenses for Endo-Visoflex -1, -2, +4 & +6 diopters 19??-19?? -
HQYOO Adapter for Endo-Visoflex by Storz, Tuttlingen DE 19??-19?? -
HQYOO Adapter for Endo-Visoflex by Wolf, Knittlingen DE 19??-19?? -
HROOY Interchangeable infrared disc for Endo-Visoflex 19??-19?? -
HSCOO Adapter for Endo-Visoflex by Deutsch Endoscopbau Ges. Sass; Wolf & Co.m.b.H Berlin 19??-19?? -
HSOOX Polished wooden storage box for Endo-Visoflex 19??-19?? -
HUGY Underwater camera enclosure 19?? -
