75mm f/2 ASPH Apo-Summicron-M
Revision as of 13:58, 5 November 2012 by Admin (talk | contribs) (→75mm f/2 ASPH Apo-Summicron-M Serial Numbers)
- Leica Order No. - 11 637
- Production era - 2005-Current < 1,653+ lenses
- Manufacturer - Schneider
- Number of lenses/groups - 7 /5
- F stop range - f/2-f/16
- Entrance Pupil position - 30.1 mm (related to the first lens surface in light direction)
- Closest focusing distance - 0.7 m / 2.3 ft
- Smallest object field - 169 x 254 mm
- Maximum magnification - 1:7
- Diaphragm setting / type - Preset 9-blade, with click-stops, half values available
- Angle of view diagonal, horizontal, vertical - 32°, 27°, 18°
- Filter type - Internal thread for screw-on filters size E49, non-rotating
- Lens hood - Built-in, telescopic, lockable
- Accessories - UVa Filter E49 13328, Universal Polarizing Filter 13356, Polarizing Filter 14418, Leica M Viewfinder Magnifiers 1.25x & 1.4x 12004 - 12006
- Materials - Anodized aluminum, brass, and optical glass
- Dimensions Length x Diameter - 66.8 x 58 mm / 2.6 x 2.3 in
- Weight - 430 g / 15.2 oz
- Inscription - APO-SUMMICRON-M 1:2/75 ASPH. E49
- On the street - $US 3,295 in 2008 - 2,225 in 2010
- From Erwin Puts Blog "I am asked quite often what three or four lenses I would select that best represent the Leica philosophy. For this moment in time I would propose the following set:
- Super-Elmar-M 3.4/21mm ASPH
- Summilux-M 1.4/35 mm ASPH (latest version)
- Summicron-M 2/75 ASPH
- Here are the arguments: . . ."
| 3983051 | 3983073 | 75mm f/2 ASPH Apo-Summicron-M | 2004 | 25 |
| 3986034 | 3986433 | 75mm f/2 ASPH Apo-Summicron-M | 2004 | 400 |
| 3986584 | 3986843 | 75mm f/2 ASPH Apo-Summicron-M | 2005 | 260 |
| 3988144 | 3988493 | 75mm f/2 ASPH Apo-Summicron-M | 2005 | 350 |
| 3989219 | 3989365 | 75mm f/2 ASPH Apo-Summicron-M | 2005 | 150 |
| -3993946 | 4007331- | 75mm f/2 ASPH Apo-Summicron-M | 2006 | 13,386+ |
| -4044657 | 4045124- | 75mm f/2 ASPH Apo-Summicron-M | 2007-2008 | 468+ |
| -4122527 | 4122572- | 75mm f/2 ASPH Apo-Summicron-M | 2009-2010 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2004-2005 | 1,653+ |
