35mm f/1.4 ASPH.fle Summilux-M
Revision as of 15:24, 23 September 2012 by Admin (talk | contribs) (→35mm f/1.4 ASPH.fle Summilux-M Serial Numbers)
- Leica Order No. - 11 663-black - -titanium
- Production era - 2010-Current
- Known as - FLE (floating element)
- Angle of view (diagonal, horizontal, vertical) - For 35 mm format (24 x 36 mm): 63°, 54°, 37°, for M8 & M8.2 (18 x 27 mm): 49°, 42°, 28°, equivalent to approx. 47 mm for 35 mm format
- Optical design
- Number of lenses/groups - 9 /5
- Focal length - 35.6 mm
- Aspherical surfaces - 1
- Position of entrance pupil - 16.6 mm from the apex of the first lens element
- Distance settings
- Focusing range - 0.7 m to ∞
- Smallest object field/ Largest reproduction ratio - For 35 mm format: approx. 418 × 626 mm /1:17.4 (for M8 approx. 313 × 470 mm /1:17.4)
- Aperture
- Setting/function - f/1.4-16 with click-stops, half values available / 9-blade
- Mount - Leica M quick-change bayonet with 6-bit bar-coding for digital M-models
- Filter - Inner threading for E46 screw-in filters, non-rotating front element
- Accessories - Hood: 12465 Full-metal, rectangular, screw-mount hood (supplied with the lens)
- Dimensions and weight
- Length to bayonet flange - Approx. 46 /58 mm (with /without lens hood)
- Largest diameter - Approx. 56 mm
- Weight - Approx. 320 g
- Data from - May 17, 2010 Leica press release
- Manufacturer's technical data - Leica PDF
- From Erwin Puts Blog "I am asked quite often what three or four lenses I would select that best represent the Leica philosophy. For this moment in time I would propose the following set:
- Super-Elmar-M 3.4/21mm ASPH
- Summilux-M 1.4/35 mm ASPH (latest version)
- Summicron-M 2/75 ASPH
- Here are the arguments: . . ."
Serial numbers compiled from known lenses| SN Start | SN End | Product | Year | Total |
| -4006688 | unknown- | Summilux-M 35mm f/1.4 ASPH. | 2010 | unknown |
| -4067334 | 4095807- | Summilux-M 35mm f/1.4 ASPH. | 2010 | 28,474+ |
| -4101424 | 4123668- | Summilux-M 35mm f/1.4 ASPH. | 2010 | 22,245+ |
| -4139358 | 4139630- | Summilux-M 35mm f/1.4 ASPH. | 2011 | 219+ |
| -414XXXXX | 4152171- | Summilux-M 35mm f/1.4 ASPH. | 2011 | unknown |
| -unknown | 4162079- | Summilux-M 35mm f/1.4 ASPH. | 2012 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2010- | unknown |
