18753
- Code names - 18753 - Electronic Viso-Flex viewfinder EVF2
- Leica description - ". . . high-resolution electronic accessory viewfinder for attachment to the accessory shoe of the Leica M and X2 has a display resolution of 1.4 MP and can be rotated by 90°. When mounted on the camera, it displays all significant exposure parameters and allows precise control of composition, particularly in very bright light. In combination with the R-Adapter M, R-Lenses and the viewfinder, the Leica M can be used independently from its monitor in the same way as an SLR camera. "
- Manufacturer - Olympus Imaging Corp.
- Specifications - (per Olympus VF-2)
- Eyepoint - approx. 18mm
- Field of view - 100%
- Magnification - approx. 1.15x
- Diopter adjustment - -3.0 - +1
- Frame rate - 60 fps
- EVF - brightness and color temperature adjustment via camera menu
- Resolution - Approx. 1,440,000 pixels
- Dimensions - W x H x D - 1.15 x 1.9 x 1.82 in / 29.21 x 48.26 x 46.23 mm
- Weight - Approx. 1.2 oz / 32 g without cover
- Variants - VF-2 is available in silver or black – EVF2 in black only
- Accessories – DP-9 Detachable eye-cup for the VF-2
- Usage – for Leica M, X2 and can also used with Olympus E-P2, E-PL1, E-PM1, E-M5, and Ricoh GXR Digital Cameras
- Designer – Yasuo Funakoshi 21 Dec 2009 (Olympus Imaging Corp.)
