P
| PAMOO | Ploot right angle 5x eyepiece; early version with mirror; later with prism; PAMOO + PROON = ODULO later used on Visoflex I | 1940-1962 | JCB's a little...If |
| PBOOC | Light-tight wooden box Fontenelle archive | 1930s | - |
| PCOOB | Yellow filter no. 0 very light; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PEGOO | Visoflex I 45 degree 4x eyepiece; black with rubber eyepiece JCB's a little...If Fontenelle archive | 1951-1962 | 16487 |
| PEOOZ | Yellow filter no. 1 light; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt | ca.1935 | - |
| PFOOY | Yellow filter no. 2 medium; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt | ca.1935 | - |
| PHOTAR | Micro lens system for close-up work. See PHOTAR-ADAPTER-R | 1930s-2009 | - |
| PGOOX | Graduated yellow filter; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt | ca.1935 | - |
| PGYOO | Graduated green filter; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt | ca.1935 | - |
| PHOOW | UVa filter; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt | ca.1935 | - |
| PIOOV | Panchromatic filter no. 1 ; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt | ca.1935 | - |
| PKOOU | Infra-red filter no. 1; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt | ca.1935 | - |
| PLGOO | Orange filter; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt | ca.1935 | - |
| PLOOT | Mirror reflex housing with flared eyepiece and double cable release | 1935-1951 | JCB's a little...11 |
| PMOOS | Infra-red filter no. 2; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt | ca.1935 | - |
| PNOOR | Infra-red filter no. 3; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt | ca.1935 | - |
| POFLA | Kodachrome flash filter; screw-on type E48 | ca.1949 | NY item |
| POLAR | Stereo transparency equipment to add to Leitz VII projector for viewing stereo projections | 1938-19?? | NY item |
| POOAH | Yellow filter no. 0 very light; screw-on type E48 | ca.1935 | 13290 |
| POOAY | Kodachrome filter type A; screw-on type E48 | ca.1949 | NY item |
| POOBV | Yellow filter no. 1 light; screw-on type E48 | ca.1935 | 13295 |
| POOCI | Yellow filter no. 2 medium; screw-on type E48 | ca.1935 | - |
| POOCQ | Blue filter; screw-on type E48 | ca.1955 | 13307 |
| POODW | Panchromatic filter no. 1; screw-on type E48 | ca.1935 | 13305 |
| POOEK | Infra-red filter no. 2; screw-on type E48 | ca.1935 | - |
| POOEL | Polarising filter; graduated, slip-on type A36 Pier Paolo Ghisetti | ca.1939 | 13350 |
| POOFX | UVa filter; screw-on type E48 | ca.1935 | 13330 |
| POOGL | Infra-red filter no. 1; screw-on type E48 | ca.1935 | 13315 |
| POOHY | Infra-red filter no. 3; screw-on type E48 | ca.1935 | 13325 |
| POOIM | Chimney 5x flared eyepiece with swing-in 30x magnifier for Ploot | 1935-1951 | - |
| POOKZ | Orange filter; screw-on type E48 | ca.1935 | 13310 |
| POOLN | Polarising filter; swing-out, slip-on type A36 with clamping screw | ca.1939 | - |
| POORE | Polarising filter; graduated, screw-on type L for Summitar f= 5 cm 1:2 | ca.1949 | 13362 |
| POORQ | Double cable release for Ploot mirror reflex housing | 1936-19?? | - |
| POOTR | Polarising filter; graduated, screw-in mount E39 | ca.1939 | 13362 |
| POSKY | Kodachrome skylight filter; screw-on type E48 | ca.1949 | NY item |
| PRADO Pradovit |
Leica slide projector (series) - see Leicawiki.DE [1] | 1946-1984 | - |
| Prismor | Close-focus addaptor for Leica IIIc and IIc equiped with the 5 cm Elmar (36 mm front ring diameter) Fontenelle archive | 1950- | - |
| PROON | Ploot mirror reflex housing; used with PAMOO = ODULO; used with POOIM = PLOOT | 1940-1950 | - |
