Visoflex III
Revision as of 17:34, 23 October 2012 by Admin (talk | contribs)
  • Production era - 1963-1992
  • Code names
    • 16457 - Viso III housing (for bayonet only)
    • 16498 - Viso III with OTXBO
    • OTXBO 16499 - 4 x 90 degree magnifier without step (shown ghosted)
    • 14112 - 14113 - 14114, Focorapid for Viso II /III w/ 3 distance pre-selection
  • Type - Mirror reflex housing, similar in appearance to Visoflex II, but offering three possibilities of mirror operation set by three positions on the knob: yellow dot - fast mirror breakaway-and-return for rapid action; black dot - slow, gentle mirror rise and fall for long exposures; red dot - mirror lock-up out of light path for vibration-free close-ups and photomicrographs. . . A thumb-activated mounting lever enables the unit complete with OTXBO to be quickly mounted on Leica-M without having to remove the OTXBO first - Laney
  • Optical depth - 40 mm
  • Variants
    • Finish - Black crackle (standard) and gray hammertone (military) versions
    • Motor-M Coupled Version - Upward movement of the arm caused Motor-M to advance the film - NY item, mid 60s, never cataloged - Laney
    • Pellicle - modified Visoflex II /III by Goldberg (or JPL) with fixed half-silvered prism, eliminating mirror vibration and black-out - Laney (see Westlicht 12/292)
  • Included cable releases (see also FINOT OPKOM OZWTO OZWTO-M GIIFT)
    • OZTOM 16491 - Double cable release, bayonet cameras
  • Available Viso III magnifiers
    • OTXBO 16499 - 90 degree 4 x eyepiece
    • OTVXO 16461 - Straight (chimney) 5 x eyepiece
  • Other Visoflex Accessories
  • Serial nos. - Viso II /III did not have serial numbers!
  • Source
Preseded by Visoflex II
