Magnus 2.4 - 16 x 56
Revision as of 22:28, 11 December 2012 by Admin (talk | contribs)
  • Production era - 2011-Current
  • Order no. per Reticle - 54 0XX - 18 variations
  • Name and Type - Magnus 2.4 - 16 x 56
  • Front lens diameter - 56 mm
  • Magnification - 2.4 - 16 x
  • Zoom factor - 6.7
  • Field of View at max. magnification - 2.8 yds /2.6 m
  • Field of View at min. magnification - 18.6 yds /17 m
  • Eye Relief - 3.5 in /90 mm
  • Exit pupil - 12.4 - 3.5 mm
  • Parallax - adjustable, 54 yds /50 m – ∞
  • Diopter Compensation - -4 / +3
  • Transmission - ~ 91 %
  • Mounting options - 30 mm tube /Zeiss internal track
  • Impact point correction - 1 click - 0.39 in/10 yds (1/3 MOA), 59 in × 55 in/150 × 140 cm
  • Weight - 1.7 lb /785 g
  • Length - 141.7 in / 360 mm
  • Waterproof to Depth - 4 m / 13.1 ft
  • Automatic switch-off - 3 min
  • Automatic switch-on - activated by position and /or movement
  • Materials - nitrogen filled aluminum
    • See manufacturer's technical data for complete specifications
