Leica M
- Production era - February 2013-
- Order no. - 10 770 black - 10 771 silver
- Camera type - Compact digital view- and rangefinder system still and video camera (Type 240).
- Lens system - Leica M lenses, Leica R lenses with optional Leica R Adapter M
- Materials - All-metal case made of die-cast magnesium; synthetic leather covering.
- Cap and base plate - made of brass
- Top Cover - Milled brass top cover with integrated thumb rest
- Available finishes - black paint and silver chrome
- Image Sensor - LEICA MAX 24 MP CMOS Sensor
- Number of effective Pixels - 24 Million Pixels
- Sensitivity range - ISO 200 – ISO 6400, Pull 100 available, Auto ISO
- Imaging Platform - Integrated imaging circuit with Leica Maestro® Image processor
- LCD Monitor - 3 inch TFT Display with 920.000 Pixels, scratch resistant cover glass (Corning®Gorilla®Glass)
- Electronic Viewfinder - Optional available, can be used for Live View and Play functionality
- Shutter - Dual type focal plane shutter for classic image exposure and Live view
- Shutter Speed - 1 /4000s – 60s (in Bulb), 1 /180s flash synchronization
- Burst rate - 3 fps
- Self timer - 2 s / 12 s
- Storage Media - SD / SDHC / SDXC Memory Cards
- Imaging functions
- Image File Format - DNG™ (RAW data uncompressed or lossless compressed), JPEG
- File Size - DNG approx. 20 Mbyte – approx. 30 Mbyte (compressed)/ 48,2 MByte (uncompressed), JPEG:
- Resolution and image content
- Available JPG Resolutions
- 5952px x 3976px (24 MP), 4256px x 2832px (12 MP) /2976px x 1984px (6 MP) / 1600px x 1080px (1.7 MP)
- Color Spaces - sRGB / Adobe®RGB
- White Balance - Auto / Daylight / Cloudy / Shadow / Tungsten /Fluorescent warm /Fluorescent cool / Flash / Manual (Greycard) / Kelvin 2000-13100
- Other functions - Film Modes, Saturation, Contrast, Sharpening
- Movie recording
- Movie Recording - Single frame video compression (Motion JPG), Quicktime format (mov)
- Movie resolution - 1080p, 720p, 640 x 480 (VGA)
- Movie sampling rate - 25 fps, 24 fps, 30 fps (VGA only)
- Microphone - Mono, stereo microphone adapter optional available Audio recording: Auto level adjustment, manual level adjustment (available while recording), concert preset
- Exposure Control
- Exposure Metering - In classic viewfinder mode: Through the Lens (TTL) metering, center weighted with variable aperture.
- In Live View and advanced viewfinder mode - Through the Lens (TTL) metering, center weighted, spot or multifield measuring.
- Center-weighted TTL metering - for flash exposure with system conformant SCA-3000/2 standard flash units.
- Exposure setting - Manual shutter speed setting with direct dial, A-Mode with direct dial
- Exposure Modes - Automatic shutter speed (A-Mode), Manual Exposure (M-Mode)
- Exposure
- Compensation . -3 EV to +3 EV, 1/3 f-stops
- Exposure Bracketing - 3 /5 frames, 0.5 / 1 / 2 / 3 f-stops
- Flash exposure Control
- Flash exposure metering - Control with center-weighted TTL pre-flash metering (with SCA-3501/3502 adapter, or SCA-3000 standard flash unit such as Leica SF 24D /Leica SF-58).
- Hot shoe - SCA-3502 compatible hot shoe, with center contact
- Flash Synchronization - Optional triggered at first or second shutter curtain
- Flash Synch time - 1 /180s
- Viewfinder / Focusing
- Focusing Methods - Manual focus with optical rangefinder, Live View, 100% Live View Zoom, Live View focus peaking
- Optical Viewfinder - Large, light bright-line rangefinder with automatic parallax compensation, LED illuminated frame lines.
- Optical Viewfinder frame lines - Framelines size matches image sensor size at 2m focusing distance
- Optical Viewfinder correction - Eyepiece adjusted to -0.5 dpt. Corrective lenses from -3 to +3 dpt. available (optional)
- Optical Viewfinder Magnification - 0.68 x
- Optical Viewfinder Displays - In the viewfinder LED symbol for flash status (at bottom).
- Four-digit seven-segment LED digital display, brightness adapted to ambient conditions, for - warning in case of exposure correction; display of automatic shutter speed in automatic mode - advisory indicating use of metering memory lock LED exposure monitor with two triangular and one central circular LED with manual exposure setting
- Rangefinder - Split or superimposed image range finder shown as a bright field in the center of the viewfinder image
- Rangefinder effective metering basis - 47.1 mm (mechanical metering basis 69.25 mm x viewfinder magnification 0.68 times)
- Other features
- Start up time - < 1s
- Power Supply - Li-ion battery (included), 7.4V, 1800 mAh
- Horizon - Yes
- User Profiles - 4 Profiles, exportable
- Sensor cleaning - Dust detection, manual cleaning function
- Tripod Thread - A 1 /4 (1 /4") DIN made of stainless steel in base plate
- Dimensions - approx. 139 x 42 x 80 mm (5.5 x 1.7 x 3.1 in.)
- Weight - 680 g (23.9 oz)
- Operating Temperature - 0°C – 40°C
- Menu languages - English, German, French, Italian, Spanish, Russian, Japanese, Traditional Chinese, Simplified Chinese
- Accessories Included - Battery, Charger with power cables for EU and USA (different in some export markets), 12V charging cable, Carrying strap, Accessory port cover, Body cap - Software licenses supplied - Adobe® Lightroom®
- Manufacturer's data as of September 2012
Accessories
- Current Digital-M Camera Accessories
- Film Advance
- 14 408 - Motor-M
- 14 009 - Leicavit-M - Black lacquered - 14 450 Black chrome-plated - 14 008 Silver chrome-plated
- 14 437 - Rewind crank-MP - Silver chrome-plated - 14 438 Black lacquered
- Flash Units
- Viewfinder Accessories
- LEICA VIEWFINDER-M
- 12022 - 18 mm / black paint finish - 12023 silver-chrome
- 12024 - 21 mm / black paint finish - 12025 silver-chrome
- 12026 - 24 mm / black paint finish - 12027 silver-chrome
- 12531 - ANGLEFINDER M
- Cases and Straps
- à la Carte Carrying Straps - 14453, 14469, 14457, 14458, 14454, 14456, 14468, 14465, 14466, 14467
- 14 455 - Wide Carrying Strap
- Neoprene Case M - with short front part 14867 - with long fromt part 14868
- Tripod Accessories
- 14 110 - Ball Head
- Close-up Accessories
- 14 409 - MACRO-ADAPTER-M
- OUFRO - Macro extension ring for all M-lenses per Overgaard review [2] below
- Ergonomics
- 14 400 - HAND GRIP M9 - steel-gray paint
- Film Advance
- New Digital-M Camera Accessories
- 18753 - Electronic Viewfinder (EVF-2)
- Ergonomics
- 14495 - Multi-functional Handgrip-M (shown) with SCA Adapter Set and Power Adapter (not shown)
- 14496 - Handgrip-M
- 14646 - Finger loop Size S - 14647 Size M - 14648 Size L (shown)
- Video Accessories
- 14634 - Leica Microphone Adapter Set (shown)
- Adapters
- 14624 - Leica R-Adapter M
- Cases and Straps
- 14872 - Ever-Ready Case M
- Power Supply - see DIGITAL-M POWER SUPPLY
- 14 499 - Li-ion Battery BP-SCL2
- 14 494 - Charger-M BC-SCL2
- Firmware - M-240
- 1.1.0.0
- 1.1.0.2 - 01 Mar 2013
- On the street - EU€ 6,200 - US$ 6,950 2013
- Vimeo videos
M-240 Serial Numbers
Serial numbers compiled from known M-240 cameras| SN Start | SN End | Product | Year | Total |
| -4444000 | 4444550- | M-240 (black) | 2013 | unknown |
| -unknown | unknown- | M-240 (silver) | 2013 | unknown |
| -unknown | 4699927- | M-240 (black) | 2013 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2013- | unknown |
