U
| UASKU | 18 x 24 mm format VIIIs slide projector | 1936-1951 | - |
| UBAFE | Picture slides for projectors with 5 x 5cm frame format | 1932-1936 | - |
| UBAHO | Slide attachment for small VIIIb projector with picture slide and 8 cm lens milar and condensor | 1932-1936 | - |
| UBAZU | 19??-19?? | - | |
| UBEAF | 30 volt / 100 watt Cinema lamp plug-in socket for slide projectors VIIIa and VIIIb | ca.1935 | - |
| UBEBC | 19??-19?? | - | |
| UBECD | 22 mm extension tube for Focoslide and also for UDIMO enlarger using 5 cm Elmar | 1936-1940 | NY item |
| UBEHU | 19??-19?? | - | |
| UBELA | Small projector with UDIMO film UKEDO intent with semi-automatic film guides and threaded socket for Leica lenses | ca.1935 | see Westlicht 22/247 |
| UBELABIKU | 19??-19?? | - | |
| UBELADOKO | 19??-19?? | - | |
| UBEMI | 100 watt lamp for Cinema use with slide projectors VIIIa and VIIIb | 1932-19?? | - |
| UBENO | Slide projector lamp housing for projector VIIIb with film intent UKEFI including lens milar | 1932-1936 | - |
| UBEOL | 19??-19?? | - | |
| UBEPU | 19??-19?? | - | |
| UBFKU | 19??-19?? | - | |
| UBIKU | Projector VIIIa for lenses from 12 to 15 cm | 1932-1936 | - |
| UBILADAKI | 19??-19?? | - | |
| UBIRN | Mirrored special 500 W bulb for 100 to 130 volts in 5 volt steps usd with IVb slide projector | 19??-1932 | - |
| UBMWU | Extra heat protection filter with 250 v socket for Prado slide projectors | ca.1955 | - |
| UBODI | Slide projector VIIIb with lamp housing and picture slide intent UBAHO including lens milar | 1932-1936 | - |
| UBODIMAX | 19??-19?? | - | |
| UBRGU | 19??-19?? | - | |
| UBSIU | 19??-19?? | - | |
| UBTLU | 19??-19?? | - | |
| UCDEU | 19??-19?? | - | |
| UCEGU | Pradovit I slide projector with Dimaron 2.8/100mm | 1960 | - |
| UCFIU | 19??-19?? | - | |
| UCFKU | Pradovit I slide projector with Colorplan 2.5/90mm | 1960 | - |
| UCHRU | Protective metal hood for Pradovit I slide projector | 1960 | - |
| UCMVU | 19??-19?? | - | |
| UCNXU | Pradovit f slide projector with Dimaron 2.8/100mm | 1960 | - |
| UCPBU | 19??-19?? | - | |
| UCPLU | Pradovit f slide projector with Colorplan 2.5/90mm | 1960 | - |
| UCSHU | Remote control 4 m cable | 1960 | - |
| UCWQU | 1960 | - | |
| UDAKI | Slide projector VIIIa to VIIIs for lenses 7.3, 8, 8.5 and 9 cm | 1932-1936 | - |
| UDALU | Image slide for 24 x 36 mm slides between 3.5 x 12 cm glass plates for type VIII slide projectors | 1932-19?? | - |
| UDAMY | Leica-film unit for Leica lenses on the non-Leica projectors with take-up spool, fire drums and film guide for 24 x 36 mm film slides | 1932-1936 | - |
| UDANO | VIIIa projector housing, similar to UDIMO, with UBAFE | 19??-19?? | - |
| UDANOBIKU | 19??-19?? | - | |
| UDANODAKI | 19??-19?? | - | |
| UDANODOKO | 19??-19?? | - | |
| UDAOB | Projection milar f = 8 cm for VIIIa and similar slide projectors | 1932-1936 | - |
| UDAPA | Cassette with a circular cutout for 5 x 5 cm lantern slides for VIIIa and other slide projectors | 1932-19?? | - |
| UDAPTA | 19??-19?? | - | |
| UDAVI | 19??-19?? | - | |
| UDCBU | Pradovit f slide projector with Dimaron 2.8/150mm | 1960 | - |
| UDEJO | Small slide projector UDIMO (VIIIa) with UBAFE and UDAMY removable cassettes | 1932-1936 | - |
| UDGKU | Plywood case for projector plus accessories and 150mm lenses | 1960 | - |
| UDIAS | Diavorsatz with Lens Dimar 250mm and two alternating frames made of wood for 8.5 x 8.5, 8.5 x 10, 9 x 12 slides for the IVb L. slide projector | 1932-19?? | - |
| UDIMO | VIIIa slide projector, lamp housing with 100-watt lamp for mains cinema, reflector and cassette | 1932-1936 | - |
| UDKQU | Second heat protection filter, including 500-watt lamp | 1960 | - |
| UDLSU | 1960 | - | |
| UDOKO | Condenser for small VIIIa projector including Elmar and Hektor 5 cm lenses | ca.1955 | - |
| UDOYU | Prado 250 complete with 10 cm Dimaron projector lens | ca.1955 | - |
| UDOZU | Front assembly for VIIIa and others slide projectors | 1932-1936 | - |
| UDREU | 10 cm Hector lens for Prado 250 projector | 19??-1955 | - |
| UDRUK | Pressure switch for short connection cord to slide projector | 1932-19?? | - |
| UDUHS | 19??-19?? | - | |
| UDWPU | Transparent container for 2 slide magazines | 1960 | - |
| UDXRU | Transparent containers with 2 magazines | 1960 | - |
| UEOOK | Adaptor ring for UZEOO 36 mm front lens mount | 19??-19?? | 16568 |
| UEOXU | Slide magazine for 30 slides | 1960 | - |
| UEPOO | Adaptor ring for UZEOO 42 mm front lens mount | 19??-19?? | 16566 |
| UFBXU | 5 magazine cassette | 1960 | - |
| UFTGU | 2 slide magazines for 50 slides incl. cardboard | 1960 | - |
| UGHIU | 110 film strip carrier for Leitz 110 slide projector, complete with its removable vertical mask Forum /Fontenelle discussion | 19??-19?? | - |
| UGPXU | Remote control cable 10m long | 1960 | - |
| UGQZU | Remote control cable 15m long | 1960 | - |
| UGRBU | Remote control cable 20m long | 1960 | - |
| UHPWU | Multiple connector for tape device and cable | 1960 | - |
| UKGDU | Synchronous circuit with tape | 1960 | - |
| UMHDU | Pradovit f with Dimaron 2.8/100mm, at 60Hz switchable | 1960 | - |
| UMIQU | Pradovit f with Colorplan 2.5/90mm, at 60 Hz. switchable | 1960 | - |
| UMKHU | Pradovit f with Hektor 2.5/120mm, at 60 Hz. switchable | 1960 | - |
| UMLKU | Pradovit f with Dimaron 2.8/150mm, at 60 Hz. switchable | 1960 | - |
| UMNOU | Pradovit f with Hektor 2.5/150mm, at 60 Hz. switchable | 1960 | - |
| UNOOB | Carrying arm with lens holder and variable bellows, known as the lower stage of the universal reproduction apparatus for Elmar (I) f= 5 cm 1:3.5 | 1934-19?? | - |
| UNOOB-YSMOO | Carrying arm with lens holder and variable bellows, known as the lower stage of the universal reproduction apparatus for Summar f= 5 cm 1:2 | 1937-19?? | - |
| UOOND | Adapter ring used to mount Leica M lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used to mount M lens on screw mount extension tube or copy device like Focoslide for close-up work. The screw mount version is UUOYW | 1956-19?? | 16596 |
| UOOPE | Spannungsreduzierer with voltmeter to extend the life of AKTOO projector bulb | ? | - |
| UOORE | Believed to be a typo for UOORF Forum discussion | ? | - |
| UOORF | Adapter ring for the lens head of the rigid Summicron 50 with SOOKY or SOMKY; also for Bellows I /II Forum discussion [1] | 1960 | 17672 (bayonet) - 16508 16469 (screw) |
| UOOST | UOOYW + UOOVH | ? | - |
| UOOVH | Lens adapter ring for the head of Hector and Elmar 135mm and extension tube for HEFAR lens head | ? | 16580 |
| UOOWV | Lens Adapter Ring for heads and the Elmarit 90mm Elmar | ? | 16585 |
| UOOXI | Adapter Ring for the head of the 125mm Hektor with Bellows I /II | 1958 | 16572 |
| UOOYW | Bellows connecting ring for I and II Fontenelle archive | ? | 16590 N |
| UOOZK | Adapter ring for the head of the Summicron 90 mm with Bellows I /II Forum discussion | 1960 | 16598 |
| UOSWU | Horizontal slider for Prado S and SM | ? | - |
| UPOOZ | Yellow very light no. 0 filter; screw-on type E58 | ca.1951 | 13235 |
| UQMOO | Yellow light no. 1 filter; screw-on type E58 | ca.1951 | 13235 |
| UQOOY | Yellow medium no. 2 filter; screw-on type E58 | ca.1951 | - |
| UROOX | Panchromatic green filter; screw-on type E58 | ca.1951 | 13245 |
| USFLA | Kodachrome flash filter; type E58 | 1949-19?? | NY item |
| USOAY | Kodachrome type A filter; type E58 | 1949-19?? | NY item |
| USOOW | Orange filter; screw-on type E58 | ca.1951 | 13250 |
| USQOO | Infra-red light no. 1 filter; screw-on type E58 | ca.1951 | 13255 |
| USSKY | Kodachrome skylight filter; type E58 | 1954-19?? | NY item |
| UTOOV | Infra-red medium no. 2 filter; screw-on type E58 | ca.1951 | - |
| UTSOO | Infra-red dark no. 3 filter; screw-on type E58 | ca.1951 | 13265 |
| UUOYW | Adapter ring used to mount screw-mount lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used for mounting extension tube or copy device like Focoslide for close-up work. The M-mount version is UUOND | 1956-19?? | - |
| UVOOF | UVa filter; screw-on type E58 | ca.1951 | 13270 |
| UVWOO | 4-way lamp socket with cable and plug | 1951-19?? | 16760 |
| UWOOS | Arm connector for copy stand Focoslide | 19??-19?? | 16601 |
| UWYOO | Adaptor plate for using focusing bellows on carrying arms ROONP and ROOFU | 1951-19?? | 16600 |
| UXOOR | Universal focusing bellows; early version had smaller diameter thread for the lens mount and was supplied with an adaptor ring UOOYW and tube UOOVH for Hektor f= 13.5 cm 1:4.5 ; later version has thread for universal focusing bellows II with interchangable adaptor rings Forum discussion Fontenelle archive | 1951-19?? | 16555 |
| UYCOO | Interchangeable bayonet adapter for 50mm f3.5 Elmar for use with Bellows I /II Forum discussion | 1951-1960 | - |
| UYOOQ | Fiber case with Visoflex I, bellows and accessories | ? | see JCB Bellows |
| UZEOO | Large extending bellows lens hood with changeover mask frame for upright and horizontal shots for 36 mm front lens mount Forum discussion | 1951-19?? | 16565 |
| UZEOO-M | Bellows lens hood for 42 mm front lens mount | 1960-19?? | 16567 |
