90mm f/2.5 Summarit-M
- Leica Order No. - 11 646
- Production era - 2007-Current
- Lens mount - Leica M quick-change bayonet with 6 bit lens identification bar code for digital M models
- Number of lenses/groups - 5 /4
- Aperture range - f/2.5-f/16 setting/Function Preset, with click-stops, half values available; 11-blade
- Focusing range - 1 m / 3.28 ft to ∞
- Smallest object field/Largest reproduction ratio - For 35 mm, approx. 213 x 320 mm /1:8.9 = for LEICA M8, approx. 160 x 240 mm /1:8.9
- Angle of view (diagonal, horizontal, vertical) - For 35 mm (24 x 36 mm) : 27 deg, 22.6 deg, 15.2 deg, - for LEICA M8 (18 x 27 mm) : 20.4 deg, 17.1 deg, 11.4 deg, corresponds to a focal length of approx. 120 mm with 35 mm-format
- Position of entrance pupil - (from apex of 1st lens element) 54.8 mm
- Filter mount/Lens hood - Non-rotating, internal thread for screw-on filters size E46, external thread for lens hood, protection ring for external thread included in delivery, lens hood available as accessory
- Accessories - Hood: 12460 - Leica M Viewfinder Magnifiers 1.25x & 1.4x 12004 - 12006
- Material - Anodized aluminum, brass and optical glass
- Length to bayonet flange - approx. 66.5 mm / 2.8 in
- Largest diameter - approx. 55 mm / 2.17 in
- Weight - approx. 360 g / 12.7 oz
- Inscription - LEICA SUMMARIT-M 1:2.5/90 E 46 4XXXXXX
- Leica Tech Data - [Summarit-M_90_mm_Technical_Data_en.pdf Summarit-M_90 pdf]
- On the street - $US 1,595 in 2008
90mm f/2.5 Summarit-M Serial Numbers
Serial numbers compiled from known lenses| SN Start | SN End | Product | Year | Total |
| -4046300 | 4046302- | 90mm f/2.5 Summarit-M | 2007 | unknown |
| -4059505 | 4059879- | 90mm f/2.5 Summarit-M | 2008 | 375+ |
| -4125801 | 4134462- | 90mm f/2.5 Summarit-M | 2009 | 8662+ |
| -unknown | unknown- | 90mm f/2.5 Summarit-M | 2010 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2007-2012 | unknown |
