Traveller Tripod
Revision as of 21:21, 17 October 2013 by Tdavis (talk | contribs)
  • Production era - 2013-current
  • Type - Light-weight, carbon fiber tripod
  • TRAVELER TRIPOD
    • Code no. - 14101
    • Manufacturer's description - design: the three tripod legs ensure stable placement in any situation and offer simple and flexible usage. Eight layers of top-quality carbon fibers guarantee maximum stability, and with a weight of merely 1.2 kg, the Leica Traveller [sic] Tripod is as light as a feather. . . When collapsed, it's especially small and handy. A 1/4" to 3/8" screw adapter is included.
    • Material - Eight layers of carbon fiber
    • Number of leg segments - three, with removable center column
    • Extended height - 151 cm
    • Max. Height w/o center column - 121 cm
    • Min. Height - 10 cm
    • Packing dimension - 52 cm
    • Weight - 1.2 kg
    • Maximum load-bearing capacity - 10 kg
  • BALL HEAD 24
    • Code no. - 14113
    • Ball diameter - 24 mm
    • Camera connection - 1 /4 inches
    • Bottom thread - 3 /8 inches
    • Dimensions diameter x height - 35 x 81 mm
    • Weight - 227 g
    • Maximum load-bearing capacity - 12 kg
  • BALL HEAD 38
    • Code no. - 14114
    • Ball diameter - 38 mm
    • Dimensions diameter x height - 50 x 90 mm
    • Weight - 436 g
    • Maximum load-bearing capacity - 24 kg
  • 3x set exchangeable MOUNTING PLATES for BALL HEAD 24 & 38
    • Code no. - 14115
  • CORDURA BAG FOR TRAVELER TRIPOD SET
    • Code no. - 14116
