135mm f/3.4 ASPH Apo-Telyt-M
- Leica Order No. - 11 889 / LLC - 184
- Production era - 1998-Current 4,500+ lenses
- Photokina 2012 - "Will there be a 6 bit code for the 1:3.4 /135mm lens?" Jesko v. Oeynhausen: "Yes, we will repair this oversight."
- Number of lenses/groups - 5 /4
- Focusing range - 1.5 m / 4.9 ft < ∞
- Extension factor - 1:33
- Aperture - f/3.4-f/22 - Setting/Function Preset, with click-stops, half values available, manual diaphragm
- Smallest object field/Largest reproduction ratio - 220 mm x 330 mm / 1:9
- Angle of view diagonal, horizontal, vertical - 18°, 15°, 10.2°
- Position of entrance pupil - 68 mm (related to the first lens surface in light direction)
- Filter mount/Lens hood - Internal thread for screw-on filters size E49 / built-in, telescopic
- Accessories - Leica M Viewfinder Magnifiers 1.25x & 1.4x; Polfilter M 14418
- Focal length - 136 mm / 5.35 in
- Length to bayonet flange - 104.7 mm / 4.1 in
- Largest diameter - 58.5 mm / 2.3 in
- Weight - approx. 450 g / 15.9 oz
- Inscription - APO-TELYT-M 1:3.4/135
- Leica Tech Data - 135mm f/3.4 ASPH Apo-Telyt-M.pdf - courtesy Summilux.net
- On the street - $US 3,195 in 2008 - 1,600 in 2010
135mm f/3.4 ASPH Apo-Telyt-M Serial Numbers
| 3838125 | 3838624 | 135mm f/3.4 ASPH Apo-Telyt-M | 1998 | 500 |
| 3842000 | 3842499 | 135mm f/3.4 ASPH Apo-Telyt-M | 1998 | 500 |
| 3853100 | 3853599 | 135mm f/3.4 ASPH Apo-Telyt-M | 1998 | 500 |
| 3874167 | 3875166 | 135mm f/3.4 ASPH Apo-Telyt-M | 1999 | 1000 |
| 3910126 | 3911125 | 135mm f/3.4 ASPH Apo-Telyt-M | 2000 | 1000 |
| 3956061 | 3956560 | 135mm f/3.4 ASPH Apo-Telyt-M | 2002 | 500 |
| 3985534 | 3986033 | 135mm f/3.4 ASPH Apo-Telyt-M | 2004 | 500 |
| -4060649 | 4060788- | 135mm f/3.4 ASPH Apo-Telyt-M | 2006-2010 | 140+ |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1998-2005 | 4,500 |
