Crane Museo Max
Revision as of 16:53, 4 January 2014 by Tdavis (talk | contribs)
  • Type - 100% cotton · acid-free · double-sided semigloss "velina" finish
  • Manufacturer's description - Using a breakthrough coating technology, Museo® Max™ produces visually superior prints in B&W and color— you can see the difference. Museo® Max™ enables you to extract the best performance from your printer to generate bold, bright colors with fine, crisp details.
  • Optical Brightening Agents - none
  • Weight - 250 (also available "Museo II" - 365 gsm)
  • Thickness - 5.3 mil
  • Brightness - 91.0
  • pH - 7.9 - 8.5
  • Manufacturer's data sheet - pdf
  • Test labs
  • Archival Rated Printers for the Specified Paper
Notes
Mlux hrs indicates the amount of light exposure (expressed in megalux hours of exposure) that the sample has received to date in test. Testing typically continues well beyond the exposure dose required to establish the Conservation Display Ratings and until high levels of easily noticeable fade have occurred. Aardenburg Status
