Red River Ultra Pro Gloss Plus
- Type - bright blue white · double-sided poly-cast coated
- Manufacturer's description - This custom made inkjet paper is a first - true high glossy on both sides that is compatible with all printers including pigment ink printers such as the Epson R800, R1800, and R2400. It has a bright blue-white glossy surface on both sides, and sturdy double weight card feel.
- OBAs high - will produce easily noticeable change (yellowing) in media color and image highlight appearance per Aardenburg Status.
- Weight - 240 gsm /65 lb
- Thickness - 12.5 mil
- Size range - 4 x 6 /17 x 22 in
- Test labs
- Archival Rated Printers for the Specified Paper
- Epson Stylus Photo R1800 > 260 Mlux hrs
Notes
- Mlux hrs indicates the amount of light exposure (expressed in megalux hours of exposure) that the sample has received to date in test. Testing typically continues well beyond the exposure dose required to establish the Conservation Display Ratings and until high levels of easily noticeable fade have occurred. Aardenburg Status
