DELL
- MODEL - UltraSharp 30 PremierColor Monitor - U3014
- DISPLAY
- Diagonal Viewable Image Size - 75.6 cm /29.8 in (30-inch wide )
- Aspect Ratio - 16 : 10
- Panel Type, Surface - AH In-plane switching, anti glare with hard coat 3H
- Optimal resolution - 2560 x 1600 at 60 Hz
- Contrast Ratio - 1000 to 1 (typical)
- Dynamic Contrast Ratio - 2 Million : 1 (Max)
- Brightness - 350 cd /m2 (typical), 50 cd /m2 (minimum)
- Response Time - 6 ms (gray to gray)
- Viewing Angle - (178° vertical /178° horizontal)
- COLOR SUPPORT
- Color Gamut (typical) - Adobe RGB 99%, sRGB 100% and 120% (CIE 1976)
- Color Depth - 1.07 billion colors
- Pixel Pitch - 0.25 mm
- Backlight Technology - LED
- Display Type - Widescreen Flat Panel Display
- CONNECTIVITY
- 1 Dual Link Digital Visual Interface connectors (DVI-D) with HDCP
- 1 DisplayPort 1.2 (DP)
- 1 Mini DisplayPort 1.2 (mDP)
- 1 High Definition Multimedia Interface (HDMI)
- 1 USB 3.0 upstream port
- 4 USB 3.0 downstream ports
- 1 DisplayPort out (MST)
- 1 Audio out
- DC power connector for Dell Soundbar (AX510)
- ADJUSTABILITY - Height adjustable stand, tilt , swivel and built in cable-management, capacitive touch OSD controls
- Flat Panel Mount Interface - VESA
- BUILT-IN DEVICES
- USB 3.0 Hi-Speed Hub (with 1 USB upstream port and 4 USB downstream ports)
- DC-out
- SECURITY
- Security lock slot (security lock sold separately)
- Anti-theft stand lock slot (to panel)
- SIZE AND WEIGHT
- Dimensions with stand (H x W x D) - 19.00 ~ 22.55 in (482.7 ~ 572.7 mm) x 27.15 in (689.7 mm) x 7.93 in (201.4 mm)
- Dimensions without stand (H x W x D) - 17.69 in (449.2 mm) x 27.15 in (689.7 mm) x 2.40 in (61.0 mm)
- Viewable Image Dimension (H x W) - 641.3 x 400.8 mm /25.25 x 15.76 in
- Weight (panel only - for VESA mount) - 10.84 kg (23.89 lb)
- Weight (with packaging) - 13.65 kg (30.09 lb)
- ELECTRICAL
- Voltage Required - 100 to 240 VAC / 50 or 60 Hz + 3Hz / 1.8 A (typical)
- Power Consumption (Operational) - 60W (typical) / 120W (maximum)10
- Power Consumption Stand by / Sleep - Less than 0.5 W
- ENVIRONMENTAL
- Temperature Range Operating - 0° to 40°C (32° to 104°F)
- Temperature Range Non-operating
- Storage - -20° to 60° (-4° to 140° F)
- Shipping - -20° to 60° (-4° to 140° F)
- Humidity Range Operating - 10% to 80% (non-condensing)
- Humidity Range Non-operating
- Storage - 5% to 90% (non-condensing)
- Shipping - 5% to 90% (non-condensing)
- Altitude Operating - 5000 m (16,500 ft) max
- Altitude Non-operating - 10,668 m (35,000 ft) max
- COMPLIANCE AND STANDARDS
- Energy Star
- EPEAT Gold
- TCO Certified Displays
- Product Safety, EMC and Environmental Datasheets
- Dell Regulatory Compliance Home Page, Dell and the Environment, Dell Pixel Policy
- WHAT'S IN THE BOX
- Monitor with stand (Monitor includes Dell UltraSharp Color Calibration Solution)
- Power Cable
- DVI-D Cable (Dual Link)
- DisplayPort Cable (Mini DP to DP)
- USB3.0 upstream Cable
- Cable Tie
- Drivers and Documentation media
- Factory Color Calibration Report
- Quick Setup Guide
- Safety Information
- WARRANTY - 3 Years Advanced Exchange Service & Limited Hardware Warranty, Premium Panel Guarantee
- Service / Support Details - 3-Year Advanced Exchange Service and Premium Panel Guarantee
- Manufacturer's tech specs as of 10 Jan 2014
