HP
Revision as of 15:34, 11 January 2014 by Tdavis (talk | contribs)
  • Physical specifications
    • Dimensions (H x W x D)
      • Unpacked w/stand - 4,890 to 5,890 x 6,940 x 2,760 mm (19.3 to 23.3 x 27.3 x 10.9 in)
      • Unpacked w/o stand (head only) - 4,540 x 6,940 x 8,70 mm (17.9 x 27.3 x 3.4 in)
      • Packaged - 3,830 x 5,600 x 7,880 mm (15.1 x 22.0 x 31.0 in)
    • Weight
      • Head only - 9.5 kg (20.9 lb)
      • Unpacked - 13 kg (28.6 lb)
      • Packaged - 17 kg (37.5 lb)
    • Tilt range - -5° to + 35° vertical
    • Swivel range - 45°L /45°R
    • Height adjustable - Yes, 100 mm
    • Detachable stand - Stand ships detached and easily attaches with the HP Quick Release.
  • Panel specifications
    • Type - 30-inch Wide-Aspect Active Matrix TFT (thin film transistor)
    • Viewable image area - 762 mm (30 in) widescreen; diagonally measured
    • Screen opening (W x H) - 644 x 403 mm (25.4 x 15.9 in)
    • Resolution - 2560 x 1600
    • Aspect ratio - 16:10
    • Viewing angle (typical) - Up to 178° horizontal/178° vertical (10 : 1 minimum contrast ratio)
    • Brightness (typical) - 370 nits (cd /m2)
    • Contrast ratio (typical) - 1000 : 1
    • Dynamic contrast ratio (typical) - 3,000 : 1
    • Response time (typical) - 7 ms (gray to gray); 12 ms (On /Off)
    • Pixel pitch - 0.2505 mm
    • Backlight lamp life (to half brightness) - 40,000 hr
    • Color gamut
    • Size vs. NTSC - 102 % (CIE 1931)
    • Coverage of sRGB - 100 % (CIE 1976)
    • Coverage of Adobe RGB - 99 % (CIE 1976)
  • On Screen Display (OSD)
    • Buttons or switches - Input select, brightness up, brightness down, power
    • Languages
    • User guide languages - English, B. Portuguese, French, LA Spanish, Korean, S. Chinese, T. Chinese, Bahasa, Japanese, Danish, Finnish, German, Norwegian, Spanish, Swedish, Greek, Polish, Russian, Slovenian, Turkish
    • Warranty languages - English, Canadian French, LA Spanish, Brazilian Portuguese, Danish, German, Castilian Spanish, French, Italian, Dutch, Norwegian, Finnish, Swedish, Bahasa Indonesian, Korean, T. Chinese, S. Chinese
  • User controls
    • Horizontal frequency - 100 kHz
    • Vertical frequency - 60 Hz
    • Native resolution - 2560 x 1600 @ 60 Hz
    • Preset VESA graphic modes (non-interlaced) - 2560 x 1600 @ 60 Hz
    • Text mode - Not supported
    • Maximum pixel clock speed - 275 MHz
    • User programmable modes - No
    • Anti-glare - Yes
    • Anti-static - Yes
    • Default color temperature - 6500 K
    • Plug and play - Yes
    • Input connectors - 1 DisplayPort connector, 1 DVI-D connector, HDCP support on DisplayPort and DVI
    • Input impedance - Not applicable
    • Sync input - Separate synch
    • Video cable - (1) Dual-Link DVI-D to DVI-D, (1) DisplayPort
    • Video cable lengths - 1.8 m (5.9 ft)
  • Electrical specifications
    • Input power - 100 to 240 V AC, 50 or 60 Hz
      • Typical power consumption - 130 W
      • Maximum - 185 W
      • Power saving < 2 W
      • Power cable length - 1.8 m (5.9 ft)
  • Environmental specifications
    • Operating temperature - 5° to 35°C (41° to 95°F)
    • Non-operating temperature - -20° to 60°C (-4° to 140°F)
    • Operating humidity - 10 % to 80 % non-condensing
    • Non-operating humidity - 5 % to 95 %
    • Operating altitude - +0 to 5,000 m (16,404 ft)
    • Non-operating altitude - +0 to 12,192 m (40,000 ft)
  • Manufacturer's tech specs as of 10 Jan 2014
