Leica T
- Lens Connection - Leica T bayonet fitting with contact strip for communication between lens and cameras
- Lens System - Leica T lenses
- Sensor - CMOS sensor, size APS-C (23.6 x 15.7 mm) with 16.5/16.3 million pixels (total/effective), format aspect ratio 3:2
- Resolution - JPEG:4928 x 3264 (16 megapixels), 4272 x 2856 (12.2 megapixels), 3264 x 2160 (7 megapixels), 2144 x 1424 (3 megapixels), 1632 x 1080 (1.8 megapixels), DNG: 4944 x 3278 pixels
- Picture data file formats / compression rates - Selectable: JPG Superfine, JPG Fine, DNG + JPG Superfine, DNG + JPG Fine
- Video Recording Format - MP4
- Video resolution / frame rate - Selectable: 1920 x 1080 p, 30 fps or 1280 x 720 p, 30 fps
- Storage media - 16 GB internal memory; SD /SDHC /SDXC memory cards, multimedia cards
- ISO range - Automatic, ISO 100 to ISO 12500
- White balance - Automatic, presets for daylight, cloud, halogen lighting, shadow, electronic flash, two manual settings, manual color temperature setting
- Autofocus system - Contrast based
- Autofocus metering methods - Single point, multiple point, spot, face detection, touch AF
- Exposure modes - Automatic program, aperture priority, shutter speed priority, manual setting, scene exposure modes: Fully automatic, sport, portrait, landscape, night portrait, snow/beach, fireworks, candlelight, sunset
- Exposure metering - Multiple field, center weighted, spot
- Exposure compensation - 3 EV in 1 /3 EV increments
- Automatic bracketing - Three pictures in graduations up to 3 EV, adjustable in 1/3 EV increments
- Shutter speed range - 30 s to 1 /4000 s
- Picture series - Approx. 5 FPS, 12 pictures with constant picture frequency, then depending on memory card properties
- Flash modes - Automatic, automatic / red eye reduction, always on, always on / red eye reduction, slow sync, slow sync / red eye reduction
- Flash exposure compensation - 3 EV in 1 /3 EV increments
- Flash synchronization - Sync time: 1 /180 s
- Guide number of built-in flash unit - for ISO 100
- Recovery time of built-in flash unit Approx. 5 s with fully charged battery
- Monitor - 3.7’ TFT LCD, 1.3 million pixels, 854 x 480 per color channel
- Self timer - Selectable delay time 2 or 12 s
- WLAN - Complies with IEEE 802.11b/g/n standard (standard WLAN protocol), channel 1-11, encryption method: WiFi compatible WPA / WPA2, access method: Infrastructure operation
- Power supply - Leica BP-DC 13 lithium ion battery, rated voltage 7.4 V, capacity 1040 mAh (based on CIPA standard); approx. 400 pictures, charging time (after total discharge); approx. 160 min
- Connections - Micro USB port (2.0 High Speed), Leica flash interface with integrated connection for optional accessories; battery charging via USB connection with possible with max. 1A
- Charger - Leica BC-DC13, input: AC 100-240V, 50/60Hz, automatic reversing, Output: DC 8, 4V 0, 65A, Weight: approx. 90g, Dimensions: approx. 96 X 68 X 28 mm
- Body - Leica unibody solid aluminum design, two removable dummy plugs for carrying strap and other accessories, ISO flash shoe with center and control contacts for connection of more powerful external flash units, e.g. Leica SF 26 or for attaching the Leica Visoflex electronic viewfinder
- Tripod thread - A 1/4 DIN 4503 91/4”
- Dimensions - 134 x 69 x 33 mm
- Weight - Approx. 384 g / 339 g (with / without battery)
- Items supplied - Camera body, carrying strap, 2 carrying strap release pins for detaching the carrying strap, battery (Leica DP-DC13), charger (Leica BC-DC13) with 6 adapter plugs, USB cable
- Software - Adobe Photoshp Lightroom (free download after registration of camera), Leica T app for iOS (remote control and image transfer, free download from Apple App-Store
- Warranty - 2 years
- Technical Accessories
- Visoflex
- M-Adapter
- SF 26 Flash
- BP-DC 13 Li-ion Battery
- Audi Design Accessories
- T-Snap
- F-Flap
- Carrying Strap
- Hand Strap
- Leather Holster
- Leather Protector
- Manufacturer's data as of 24 Apr 2014
