Black and White Slide and Print Film
Revision as of 16:19, 7 July 2014 by Tdavis (talk | contribs) (→BLACK & WHITE "35 mm" NEGATIVE FILM)
The following tables are adapted from Photon Detector courtesy of Nicolai Morrisson.
| Brand Name | Trade Name | ISO | Other Available Film Sizes |
Largest Sheet Size |
Mfgr Data | ||||||
| ADOX | Bluefire Police | 80-100 | 2010 | ||||||||
| CMS 20 Forum discussion [1] | 6-25 | 2010 | |||||||||
| Pan 400 Forum discussion | 400 | 110 - 120 | 8 x 10 in | 2010 | |||||||
| AGFA | Agfapan APX 100 | 100 | 9.5 - 120 | 18 x 24 cm | 2003 | ||||||
| Agfapan APX 400 Forum discussion [2] | 400 | 9.5 - 120 | 2003 | ||||||||
| BERGGER | BPF / BRF 200 | 200 | 120 | 20 x 24 in | 2006 | ||||||
| BPF / BRF 400 | 400 | 120 | 20 x 24 in | ||||||||
| CLASSIC | Classic Pan 100 eco | 100 | 120 | ||||||||
| Classic Pan 200 | 200 | 120 | 8 x 10 in | 2010 (de) | |||||||
| Classic Pan 400 | 400 | 120 | 8 x 10 in | 2010 (de) | |||||||
| EFKE | efke KB25 (Discontinued) Forum discussion [3] | 25 | 100 ft roll | 2010 | |||||||
| efke KB50 (Discontinued) | 50 | 100 ft roll | 2010 | ||||||||
| efke KB100 (Discontinued) | 100 | 100 ft roll | 2010 | ||||||||
| efke KB400 (Discontinued) | 400 | 100 ft roll | 2010 | ||||||||
| efke IR820 (Discontinued) | 100 | 120 - 127 | 8 x 10 in | 2010 | |||||||
| FOMA | Fomapan 100 Classic Arista.EDU Ultra 100 Forum discussion |
100 | 120 | 18 x 24 cm | 2009 | ||||||
| Fomapan 400 Action Forum discussion | 125 | 120 | 2009 | ||||||||
| Fomapan 400 NIR 730 (Infrared) |
400 | 2004 | |||||||||
| FUJIFILM | Neopan 100 Acros Forum discussion | 100 | 120 (Discontinued) | 4 x 5 in | 2001 | ||||||
| Film Range PDF | Neopan 400 Professional (Discontinued) Forum discussion [4] [5] | 400 | 120 | 1995 | |||||||
| Neopan 1600 Professional Forum discussion [6] [7] | 1600 | 100 ft roll | 1995 | ||||||||
| GIGIBITFILM | 135 / 36 | 40 | 2004 | ||||||||
| Sheet Film | 25 | 4 x 5 in | 2002 | ||||||||
| ILFORD | Delta 100 Professional Forum discussion [8] [9] [10] | 100 | 9.5 - 120 - 30.5 m roll | 13 x 18 cm | 2010 | ||||||
| Delta 400 Professional | 400 | 120 - 30.5 m roll | 2010 | ||||||||
| Delta 3200 Professional Forum discussion | 1200 | 120 | 2010 | ||||||||
| FP4 Plus Survey Results (Discontinued) | 125 | 120 - 30.5 m roll | 20 x 24 in | 2010 | |||||||
| HP5 Plus Forum discussion | 400 | 120 | 20 x 24 in | 2010 | |||||||
| Pan F Plus Forum discussion [11] [12] | 50 | 120 - 30.5 m roll | 2004 | ||||||||
| SFX 200 (Infrared) | 200 | 120 | 2007 | ||||||||
| KODAK | Professional Tri-X 320 and 400 Forum discussion [13] [14] (Discontinued) | 320 | 120 - 220 | 35 & 70mm rolls | 2007 | ||||||
| Professional Plus-X 125 | 125 | 120 - 220 | 2007 | ||||||||
| Professional Tmax 100 Forum discussion | 100 | 120 | 8 x 10 in | 2007 | |||||||
| Professional Tmax 400 Erwin Puts | 400 | 120 | 2007 | ||||||||
| Professional Tmax 3200 Forum discussion (Discontinued) | 1000 | 120 | 2007 | ||||||||
| KONICA | Infrared 750 | 120 | 2001 | ||||||||
| LUCKY | SHD 100 | 100 | 120 | 2010 | |||||||
| SHD 400 | 400 | 2010 | |||||||||
| MACO | Rollei Pan 25 (Discontinued) Forum discussion | 400 | 120 - 30.5 m roll | 8 x 10 in | 2005 | ||||||
| Rollei ATP 1.1 | 32 | 120 - 30.5 m roll | 2007 | ||||||||
| Rollei Infrared 400 Forum discussion | 400 | 120 - 115 m roll | 4 x 5 in | 2005 | |||||||
| Rollei Ortho 25 (Discontinued) | 25 | 120 - 40 m roll | 8 x 10 in | 2009 | |||||||
| Rollei RPX 25 | 25 | 2014 | |||||||||
| Rollei Superpan 200 | 200 | 120 - 30.5 m roll | 2004 | ||||||||
| Rollei Retro 80S | 25 | 120/ 7 - 30.5 m roll | 2004 | ||||||||
| Rollei Retro 100 (Discontinued) Forum discussion [15] | 100 | 30.5 m roll | 2008 | ||||||||
| Rollei Retro 400S | 400 | 120 - 30.5 m roll | 2008 | ||||||||
| Rollei RPX 25 | 25 Forum discussion | 2014
ULTRAFINE | Ultrafine B & W Plus 100 | 100 | 120 - 100 ft roll | 2010 | ||||
| Ultrafine B & W Plus 400 | 400 | 120 - 100 ft roll | 2010 | ||||||||
| UltraMax T-Grain 400 | 400 | 100 ft roll | 2010 |
BLACK & WHITE "35 mm" C-41 PROCESS FILM
Mfgr Data |
| ILFORD | XP2 Super Forum discussion [16] [17] [18] [19] | 400 | 120 - 30.5 m roll | 2001 | |
| KODAK | BW400CN Forum discussion [20] [21] [22] | 100 - 200 | 120 | 2004 | |
| C-41 Black & White | 400 | 2003 |
BLACK & WHITE "35 mm" SLIDE FILM
Mfgr Data |
| AGFA | Scalla 200x | 200 | 120 | 2003 | |
| FOMA | Fomapan R | 100 | 620 | 2009 | |
| MACO | Rollei Slide Direct | 10 | 4 x 5 in | 2010 |
NOTES
- Data is for "35 mm" = 135 mm (width) camera film.
- Other film formats are listed (if available): 9.5 mm sub-miniature film - 120 mm - 127 mm - 220 mm - 640 mm - roll = bulk film (longest available length is shown).
- If the largest available film roll or sheet size is listed smaller sizes may be purchased - check with the manufacturer.
- Latest year of manufacturer's data is shown in English language (if available) or otherwise noted in German (de).
