SCA Adapter Set
- Order no. - 14498
- Production era - 2014-Current
- Manufacturer's description - The SCA adapter set M is primarily designed for use on the multifunction hand grip M and the Leica M (type240). The SCA socket on this hand grip enables TTL control of a compatible flash unit remotely of the camera (if its not or cannot be used directly on the camera e.g because a viewfinder is fitted to the accessory shoe on the camera.
- Use - The SCA adapter attaches to the bottom of the Leica M-Multi-Functional Handgrip and plugs into the grip’s SCA port, giving you full TTL compatibility with the Leica SF 58 or Leica SF 24D flashes. The Leica SCA-Adapter Set consists of a flash support bar for mounting the flash on the grip, and the external hot shoe mount which can be used without the support bar for off-camera flash.
- On the street - €EU 330, $US 385 in 2014
