M-A 127
- Camera - Leica M-A (type 127)
- Order nos. - 10370-black, 10371-chrom
- Type - compact, 35 mm rangefinder system camera with a mechanically controlled shutter
- Production era - Oct 2014-
- Lens mount - Leica M-Bayonet
- Lens system - Leica M-Lenses, 16 – 135 mm
- Exposure control - Manual setting of shutter speed and aperture with values from an external exposure meter or by estimation
- Flash exposure control
- Flash connection - Hot shoe – accessory shoe with center contact
- Synchronization - On first shutter curtain
- Flash exposure control - Computer control by the flash unit or guide number calculation and manual setting of the required aperture value
- Viewfinder
- Viewfinder principle - Large, bright, combined bright-line viewfinder with automatic parallax compensation
- Eyepiece - Adjusted to –0.5 diopters; correction lenses available for –3 to +3 diopters
- Image field framing - By projection of pairs of bright-line frames for 28 and 90 mm, 35 and 135 mm, 50 and 75 mm lenses; automatic display of corresponding frames when lenses are locked into the bayonet mount
- Frame selector - Lever enabling alternative frame pairs to be displayed in the viewfinder without changing lenses (e.g. for framing comparisons)
- Parallax compensation - The horizontal and vertical differences between the viewfinder and lens axes are automatically compensated for in relation to the focusing distance
- Concordance of viewfinder and film image - The bright-line frame size corresponds to an image size of approx. 23 × 35 mm at the minimum focusing distance for all focal lengths; focused at infinity, and depending on the focal length, approx. 9% (28 mm) to 23% (135 mm) more will be captured on the film than is shown in the corresponding brightline frame
- Magnification - 0.72 × (for all lenses)
- Long-base rangefinder - Coincident and superimposed image rangefinder, shown as a bright field at the center of the viewfinder image
- Effective rangefinder base - 49.9 mm (mechanical rangefinder base 69.25 mm × viewfinder magnification 0.72 ×)
- Shutter and shutter release
- Shutter - Horizontal rubberised-cloth focal plane shutter; extremely low noise; mechanically controlled
- Shutter speeds - From 1 s to 1 /1000 s in one-stop increments, B for exposure times of arbitrary length
- Shutter release - Standard internal thread for remote-release cables
- Film loading, advance and rewinding
- Loading - Manual loading after removal of the base and opening the rear flap
- Film advance - Manually, with rapid wind lever or Leicavit M; motorised, with Leica Motor-M, Leica Winder-M, Leica Winder M4-P or Leica Winder M4-2 (from article number 10 350)
- Rewinding - Manual, pull-out rewind knob after disconnecting the advance mechanism with the R-lever on the front of the camera
- Frame counter - On camera top plate; automatically reset when camera baseplate removed
- Camera body
- Material - One-piece full-metal body with rear flap; top deck and baseplate in brass with black or silver chrome finish and leather jacket
- Tripod bush - Thread A 1 /4, DIN 4503 (1 /4")
- Rear flap /features - Reminder dial for film sensitivity
- Dimensions (length × depth × height) - Approx. 138 × 38 × 77 mm
- Weight - Approx. 578 g
- Manufacturer's technical data as of September 2014
- On the street - £BP 3,100 . €EU 3,850 . $US 4,750 in 2014
- Brendan Nystedt - ". . . goes against the grain in a carefree, fearless way."
Leica M-A 127 Serial Numbers
Serial numbers compiled from known M-A 127 cameras| SN Start | SN End | Product | Year | Total |
| -4915590 | unknown- | Leica M-A 127 | 2014 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2014-Current | unknown |
