Elmarit-S 45mm f/2.8 ASPH.
Revision as of 18:03, 8 January 2015 by Tdavis (talk | contribs)
  • Order numbers - 11077 - 11078 (CS version with Central Shutter)
  • Production era - 2013-
  • Lenses/groups - 12 /9 (1 aspherical surface)
  • Optical design - Rear group focusing
  • Image angle (diagonal, horizontal, vertical) - approx. 62°, 53°, 37°, approx. corresponds to 36 mm in 35 mm-format
  • Aperture range - 2.8 to 22
  • Shortest distance - 0.6 m
  • Largest image scale - 1:10.1
  • Flash sync speed - 1/125 s (CS: 1/1000 s)
  • Filter thread size - 82 mm (non-rotating)
  • Dimensions (diameter /length) - 88 mm /136 mm
  • Dimensions w/ hood (diameter /length) - 132 mm /163 mm
  • Weight: 1030 g (w/ hood: 1110 g)
  • Accessories included - Lens Hood 12400: - Rear lens cover 16020: - Lens cover S 16019
  • Leica Tech Data - Elmarit-S 45mm f/2.8 ASPH.pdf
  • Forum discussion
Elmarit-S 45mm f/2.8 ASPH. Serial Numbers
Serial numbers compiled from known Elmarit-S 45mm f/2.8 ASPH. lenses
-4119204 4215526- Elmarit-S 45mm f/2.8 ASPH. 2013 unknown
TOTAL ASSIGNED SERIAL NUMBERS 2013-Current unknown
