28mm f/2.8 Elmarit-M IV
- Leica Order No. - 11809 . LLC - 146
- Production era - 1992-2006 < 10,130 lenses
- Variants - With or without 6 bit coding
- Number of lenses/groups - 8 /7
- Focusing range - 0.7 m / 2.3 ft < ∞
- Aperture - f/2.8 - f/22 - with clickstops (including half values), manual 8-blade diaphragm
- Smallest object field/Largest reproduction ratio - 533 mm x 800 mm / 1:22.2
- Angle of view (diagonal, horizontal, vertical) - 75°, 65°, 46°
- Position of entrance pupil - 15.2 mm (related to the first lens surface in light direction)
- Filter mount/Lens hood - Internal thread for screw-in filters size E46 / separate, clip-on type, lockable
- Focal length - 28.2 mm / 1.1 in
- Length to bayonet flange - 41.4 mm / 1.6 in
- Largest diameter - 53 mm / 2.1 in
- Weight - approx. 260 g / 9.2 oz
- Inscription - LEICA ELMARIT-M 1:2.8/28 E46 (Serial No.)
- Leica Tech Data
- 28mm f/2.8 Elmarit-M IV.pdf - courtesy Summilux.net
- Erwin Puts (2002) Leica M-Lenses.pdf - pgs. 31 - 33
- On the street - $US 1,095 in 2008 - 1,150 in 2010
28mm f/2.8 Elmarit IV Serial Numbers
Serial numbers compiled from known lenses and Puts Pocket Pod.pdfSN Start | SN End | Product | Year | Total |
3585865 | 3586379 | 28mm f/2.8 Elmarit-M | 1992 | 515 |
3608370 | 3608929 | 28mm f/2.8 Elmarit-M | 1992 | 560 |
3617890 | 3617894 | 28mm f/2.8 Elmarit-M | 1993 | 5 |
3633901 | 3634900 | 28mm f/2.8 Elmarit-M | 1993 | 1000 |
3662831 | 3663830 | 28mm f/2.8 Elmarit-M | 1994 | 1000 |
3671031 | 3672030 | 28mm f/2.8 Elmarit-M | 1994 | 1000 |
3708803 | 3709802 | 28mm f/2.8 Elmarit-M | 1995 | 1000 |
3743089 | 3744088 | 28mm f/2.8 Elmarit-M | 1996 | 1000 |
3768220 | 3769219 | 28mm f/2.8 Elmarit-M | 1996 | 1000 |
3793010 | 3794009 | 28mm f/2.8 Elmarit-M | 1997 | 1000 |
3847500 | 3848499 | 28mm f/2.8 Elmarit-M | 1998 | 1000 |
3895051 | 3896050 | 28mm f/2.8 Elmarit-M | 2000 | 1000 |
3979539 | 3979588 | 28mm f/2.8 Elmarit-M | 2004 | 50 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1992-2006 | 10,130 |
