Summicron-S 100mm f/2 ASPH.
Revision as of 13:16, 15 October 2014 by Tdavis (talk | contribs)
  • Order no. - 11056
  • Variants - Limited 100 Edition Set (100-ES) with Leica S camera
  • Optical design
Number of lenses /groups - 7 /5
Aspherical surfaces - 2 Floating Element Design
Position of entrance pupil (at infinity /closest focusing distance) - 13 mm /38 mm (in light impingement direction in front of the bayonet flange)
Luminous intensity - 1 : 2 (equiv to 1.6 KB format.)
Focal length - 100 mm (equivalent to 80 mm 35 mm format)
Angle of view (diagonal, horizontal, vertical) - Approx. 29°, 24.7°, 16.4, equivalent to a focal length of approx. 80 mm in 35 mm format
  • Focusing range
Working range - 0.7 m to ∞
Scales - Combined meter /feet graduation
Smallest object field /Largest reproduction ratio - Approx. 144 × 217 mm /1 : 5
  • Aperture
Settings/function - Electronically controlled aperture settings
Aperture Range - f/2 - f/22
  • Construction details
Lens mount - Leica S quick-change bayonet with contact strip for Leica S-Models
Filter mount - Outer bayonet mount for lens hood (included), threaded mount for E82 filters, non-rotating filter mount
Material - Dust & Water-Sealed anodized aluminum
Length to bayonet flange - Approx. 102 /146 mm (with /without lens hood)
Largest diameter - Approx. 91 /104 mm (with /without lens hood)
Weight - Approx. 910 /965 g (with /without lens hood)
  • Scope of delivery - Lens with lens hood, rear cap, lens front cap E82, carrying bag, manual, warranty card, certificate and optical cleaning cloth.
  • On the street - $US 7,995 in 2014
  • Forum discussion
Leica Summicron-S 100mm f/2 ASPH. Serial Numbers
Serial numbers compiled from known Summicron-S 100mm f/2 ASPH. lenses
-4235402 4235402- Summicron-S 100mm f/2 ASPH. 100-ES 2014 100
-4235402 unknown- Summicron-S 100mm f/2 ASPH. 2014 unknown
TOTAL ASSIGNED SERIAL NUMBERS 2014-Current unknown
