Leica Tripods and Heads
Revision as of 18:09, 30 October 2014 by Tdavis (talk | contribs)
Name
Order no.
Production era Type Construction Manufacturer's description Exchange plate Rotation /pan Tilt movement Weight Height Max. load capacity Accessories included Optional accessories MSRP
DH 1
2009-2012 Compact, low-profile, pan-tilt fluid head with a built-in counterbalance system Light-weight polymer body As soon as the right position is found, gentle tightening of two locking screws fixes the tripod head precisely in the vertical and horizontal plane. . . The construction guarantees flexible movement in all directions . . . fine-tuned for use with medium sized spotting scopes, but is also ideal for DSLRs with long lenses and or compact DV camcorders. with 1 /4 in connector 360 degrees + 90 degrees to - 90 degrees 570 g /1.3 lb 8.5 cm /3.3 in approx. 4 kg /8.8 lb draw-string cloth bag aluminum balance plate
42225
DH 1 sold with Trima or Trica legs (see below)
Ball Head 24
14113
2013-Current 24 mm /0.94 in, pan-lock quick-release ball head Light-weight polymer body As soon as the right position is found, gentle tightening of two locking screws fixes the ball head precisely in the vertical and horizontal plane. . . The construction guarantees flexible movement in all directions. with 1 /4 in connector
3 /8 in bottom thread
360 degrees + 90 degrees to - 90 degrees 227 g /0.5 lbs 8.1 cm /3.2 in approx. 12 kg /26.5 lbs draw-string cloth bag 3x set quick release plates 14115 $US 285 at Oct 2013 announcement
Ball Head 38
14114
2013-Current 38 mm /1.5 in, pan-lock quick-release ball head Light-weight polymer body As soon as the right position is found, gentle tightening of two locking screws fixes the ball head precisely in the vertical and horizontal plane. . . The construction guarantees flexible movement in all directions. with 1 /4 in connector
360 degrees + 90 degrees to - 90 degrees 436 g /~1.0 lb 9.0 cm /3.5 in approx. 24 kg /53 lbs draw-string cloth bag 3x set quick release plates 14115 $US 285 at Oct 2013 announcement
Video Head VH1
42230
2014-Current Swing-arm video head Light-weight polymer body . . . particularly light and ideal for observation with a spotting scope or binoculars, or for photography with cameras like the Leica M and the Leica compact cameras. Despite its small size, it guarantees shake-free observation and unique insights into the natural world. with quick-release 1 /4 + 3 /8 in connector plate 360 degrees + 90 degrees to - 90 degrees draw-string cloth bag $US 249 at Oct 2014 announcement
Video Head VH2
42231
2014-Current Light-weight polymer body . . . provides a stable and secure platform for digiscoping and photography with larger lenses. Its smooth and fluid action with a panning handle makes panorama filming jerk-free and ensures smoothly flowing video recordings. with quick-release 1 /4 + 3 /8 in connector plate 360 degrees + 90 degrees to - 90 degrees draw-string cloth bag $US 299 at Oct 2014 announcement
Name
Order no.
Production era Type Construction Manufacturer's description Max. tripod height Min. tripod height Carrying length Weight Max. load capacity Accessories included Optional accessories MSRP
Trima 1
42224
2009-2012 3-section legs Magnesium w/ foam padded upper leg segments 160 cm
63 in
37 cm
14.6 in
69 cm
27.2 in
1.92 kg
4.2 lbs
DH 1 head (see above)
zip-up padded case
£BP 385 in 2010
$US 534 in 2012
Trica 1
42223
2009-2014 3-section legs Carbon fiber w/ foam padded upper leg segments A stable tripod is essential for a calm and steady view. . . Erecting and folding up is quick and effortless. 175 cm
68.9 in
38 cm
15.0 in
70 cm
27.6 in
zip-up padded case
£BP 539 in 2010
$US 699 in 2014
Traveller Tripod
14101
2013-Current 3-section legs w/ removeable center column 8-layer carbon fiber legs The three tripod legs ensure stable placement in any situation and offer simple and flexible usage. Eight layers of top-quality carbon fibers guarantee maximum stability, and with a weight of merely 1.2 kg, the Leica Traveller [sic] Tripod is as light as a feather. . . When collapsed, it's especially small and handy. 151 cm
59.4 in
10 cm
3.9 in
52 cm
20.5 in
1.2 kg
2.65 lbs
10 kg
22 lbs
Limited 2-Year Warranty 14116 Cordura
zip-up padded case
$US 525 at Oct
2013 announcement
C-170 Tripod
42229
2014-Current 3-section legs w/ 32 cm center column carbon fiber legs w/ magnesium fittings + foam padded upper leg segments . . . ideal in combination with Leica spotting scopes, binoculars and Leica cameras and are optimised for outdoor use. 195 cm
74.8 in
? cm
? in
63 cm
24.8 in
1.4 kg
3.1 lbs
? kg
? lbs
zip-up padded case w/ removeable strap $US 549 at Oct
2014 announcement
