Leica Tripods and Heads
| Name Order number |
Production era | Type | Materials | Manufacturer's description | Exchange plate | Pan and tilt movement |
Weight | Height | Max. load capacity | Accessories included | Optional accessories | MSRP |
| DH 1 ( Gitzo G2180) |
2009-2012 | Compact, low-profile, pan-tilt fluid head with a built-in counter- balance system | Light-weight polymer body | . . . fine-tuned for use with medium sized spotting scopes, but is also ideal for DSLRs with long lenses and or compact DV camcorders. | with 1 /4 in connector | 360 degrees + 90 to - 90 degrees |
570 g 1.3 lb |
8.5 cm 3.3 in |
approx. 4 kg 8.8 lb |
draw-string cloth bag | aluminum balance plate 42225 |
DH 1 sold with Trima or Trica legs (see below) |
| Ball Head 24 14113 |
2013-Current | 24 mm 0.94 in pan-lock quick-release ball head |
Light-weight polymer body | As soon as the right position is found, gentle tightening of two locking screws fixes the ball head precisely in the vertical and horizontal plane. | with 1 /4 in connector 3 /8 in bottom thread |
227 g 0.5 lbs |
8.1 cm 3.2 in |
approx. 12 kg 26.5 lbs |
draw-string cloth bag | 3x set quick release plates 14115 |
$US 285 at Oct 2013 announcement |
| Ball Head 38 14114 |
2013-Current | 38 mm 1.5 in pan-lock quick-release ball head |
436 g ~1.0 lb |
9.0 cm 3.5 in |
approx. 24 kg /53 lbs | draw-string cloth bag | 3x set quick release plates 14115 |
| Video Head VH1 42230 |
2014-Current | Swing-arm video head | Light-weight polymer body | . . . Despite its small size, it guarantees shake-free observation and unique insights into the natural world. | with quick-release 1 /4 + 3 /8 in connector plate |
draw-string cloth bag | $US 249 at Oct 2014 announcement | ||||
| Video Head VH2 42231 |
2014-Current | Light-weight polymer body | . . . provides a stable and secure platform for digiscoping and photography with larger lenses. | with quick-release 1 /4 + 3 /8 in connector plate | 360 degrees + 90 to - 90 degrees | draw-string cloth bag | $US 299 at Oct 2014 announcement |
| Name Order number |
Production era | Type | Construction | Manufacturer's description | Max. tripod height | Min. tripod height | Carrying length | Weight | Max. load capacity | Accessories included | Optional accessories | MSRP |
| Trima 1 42224 |
2009-2012 | 3-section legs | Magnesium w/ foam padded upper leg segments | 160 cm 63 in |
37 cm 14.6 in |
69 cm 27.2 in |
1.92 kg 4.2 lbs |
DH 1 head (see above) zip-up padded case |
£BP 385 in 2010 $US 534 in 2012 | |||
| Trica 1 42223 |
2009-2014 | 3-section legs | Carbon fiber w/ foam padded upper leg segments | A stable tripod is essential for a calm and steady view. . . Erecting and folding up is quick and effortless. | 175 cm 68.9 in |
38 cm 15.0 in |
70 cm 27.6 in |
£BP 539 in 2010 $US 699 in 2014 | |||
| Traveller Tripod 14101 |
2013-Current | 3-section legs w/ removeable center column | 8-layer carbon fiber legs | The Leica Traveller [sic] Tripod is as light as a feather. . . When collapsed, it's especially small and handy. | 151 cm 59.4 in |
10 cm 3.9 in |
52 cm 20.5 in |
1.2 kg 2.65 lbs |
10 kg 22 lbs |
Limited 2-Year Warranty | Cordura zip-up padded case 14116 |
$US 525 at Oct 2013 announcement |
| C-170 Tripod 42229 |
2014-Current | 3-section legs w/ 32 cm center column | carbon fiber legs w/ magnesium fittings + foam padded upper leg segments | . . . ideal in combination with Leica spotting scopes, binoculars and Leica cameras and are optimised for outdoor use. | 195 cm 74.8 in |
? cm ? in |
63 cm 24.8 in |
1.4 kg 3.1 lbs |
? kg ? lbs |
zip-up padded case w/ removable strap | $US 549 at Oct 2014 announcement |
