Geovid 8 x 56 HD-R
Revision as of 15:40, 3 November 2014 by Tdavis (talk | contribs)
  • Production era - 2014-Current
  • Name /type - Geovid 8 x 56 HD-R
  • Order no. - 40060 (meter version) - 40061 (yard version)
  • Magnification - 8 x
    • Front lens diameter - 56 mm
    • Exit pupil - 7 mm
    • Twilight factor - 21.2
    • Field of view at 1,000 yds /m - 357 ft / 118 m
    • Close focus range - approx. 18.4 ft / 5.6 m
    • Diopter compensation - ± 4 dpt
  • Distance measurement - Range 10 yds / 10 m to approx. 1,400 yds / 1,340 m
    • Measuring accuracy
± 1 yd / m to 400 yds / 366 m
± 2 yds / m to 800 yds / 732 m
± 0.5 % beyond 800 yds / 732 m
  • Display - LED display with 4 characters and ambient-light-controlled brightness
    • Eyecup with twist-and-pull action - yes, detachable, with 2 click-stops
    • Eyepieces for eyeglass wearers - yes
    • Focusing - internal focusing with center focusing barrel
    • Coating - HDC® multicoating, AquaDura® lens coating
  • Body
    • Construction - aluminum, nitrogen-filled
    • Dimensions (W x H x D) - 5.3 x 7.2 x 2.7 in /135 x 182 x 68 mm
    • Weight - approx. 38.8 oz / 1,100 g incl. battery
    • Waterproof - to 16.5 ft / 5 m
  • Laser - eye-safe, invisible light laser compliant with EN and FDA Class 1
    • Measuring mode - scan mode, single measurement
    • Ballistic system - yes, equivalent horizontal distance, range ballistic function up to 600 yds /550 m
  • Power supply - 1 x 3 V / CR2 lithium button cell
    • Battery life - approx. 2,000 measurements at 68° F / 20°C
  • Package includes - contoured neoprene carrying strap, front lens caps, eyepiece caps, battery, Cordura case
  • Optional accessories
    • 42220 - tripod adapter
    • 42163 - floating carrying strap
Manufacturer's tech data as of Feb 2014
  • MSRP - £BP 2,150 - $US 2,949 in 2014
