Geovid 8 /10 x 42 HD-B
Revision as of 15:04, 6 November 2014 by Tdavis (talk | contribs)
  • Names - GEOVID 8 x 42 HD-B /GEOVID 10 x 42 HD-B
  • Order nos. - 40047 / 40049
  • Magnification - 8 x / 10 x
    • Lens diameter - 42 mm
    • Exit pupil - 5.2 mm / 4.2 mm
    • Twilight factor - 18.3 / 20.5
    • Field of view at 1,000 m - 130 m / 114 m
    • Objective angle of view - 7.3° / 6.5°
    • Close focusing distance - 5 m / 16.5 ft
    • Diopter compensation - +/– 4 dpt.
  • Distance measurement
    • Range - 10 m to approx. 1,825 m (10 yds to approx. 2000 yds)
    • Measuring accuracy
+/– 1 m to 500 m
+/– 2 m to 1,000 m
+/– 0.5 % beyond 1,000 m
  • Display - 4-digit LED display and ambient light based brightness adjustment
    • Eyecups with twist-and-pull action - Yes, detachable, with four click-stop settings
    • Eyepiece for spectacle wearers - Yes
    • Focusing - Internal focusing unit using center spindle
    • Lens coating - HDC® multilayer coating AquaDura® coating
    • Prism system - Perger-Porro prism
  • Body - Die cast magnesium, nitrogen-filled, non-slip rubber jacket
    • Dimensions (W /D /H) - 125 × 174 × 70 mm / 125 × 178 × 70 mm
    • Weight - 945 g / 980 g - including battery
    • Waterproofing - Waterproof to 5 m (16.5 ft)
  • Laser - Eye-safe, invisible light laser compliant with EN and FDA Class 1
    • Measuring function - Scanning mode
    • Ballistics - Equivalent horizontal range (EHR), point-of-aim correction /holdover number of clicks required on elevation turret
    • Bullet trajectories - 12 fixed pre-installed curves - Integration of custom data using microSD card
  • Power supply - 1 × 3V CR-2 lithium button cell
    • Battery life - ~ 2,000 measurements at 20°C / 68°F
  • Scope of delivery - Contoured neoprene strap, lens caps, eyepiece covers, Cordura case, Battery, microSD memory card
Manufacturer's data as of January 2013
