35mm f/2.4 Summarit-M ASPH.
Revision as of 20:42, 17 February 2015 by Tdavis (talk | contribs) (→‎Comment)
  • Leica Order No. - 11671-black - 11679-silver - red indicates change from 35mm f/2.5 Summarit-M
  • Production era - 2014-Current
  • Lens mount - Leica M quick-change bayonet with 6 bit lens identification bar code for digital M models
  • Number of lenses /groups - 6 /4
  • Focusing range - 0.8 m / 2.6 ft < ∞
  • Aperture - f/2.4 - f/16 - Setting/Function Preset, with click-stops, half values available; 9-blade
  • Smallest object field /Largest reproduction ratio - For 35 mm, approx. 490 x 735 mm /1:20.4 = for LEICA M8, approx. 367 x 551 mm /1:20.4
  • Angle of view (diagonal, horizontal, vertical) - For 35 mm (24 x 36 mm) : 63 deg, 54 deg, 38 deg, - for LEICA M8 (18 x 27 mm) : 50 deg, 42 deg, 29 deg, corresponds to a focal length of approx. 47 mm with 35 mm-format
  • Position of entrance pupil - (related to the first lens surface in light direction) 9.3 mm
  • Scales - Combined meter /feet graduation
  • Filter mount/Lens hood - Non-rotating, internal thread for screw-on filters size E46, external thread with stop for lens hood.
  • Accessories - Replacement hood 12439-black, 12440-silver
  • Materials - Anodized aluminum, brass and optical glass
  • Length to bayonet flange - approx. 34 mm
Leica 35mm f/2.4 ASPH. Summarit-M Serial Numbers
Serial numbers compiled from known lenses
-unknown 4302424- 35mm f/2.4 ASPH. Summarit-M (black) 2014 unknown
-4302427 unknown- 35mm f/2.4 ASPH. Summarit-M (silver) 2014 unknown
TOTAL ASSIGNED SERIAL NUMBERS 2014- unknown
