90mm f/4 Macro-Elmar-M
Revision as of 16:11, 8 February 2015 by Tdavis (talk | contribs)
  • Leica Order No. - 11633-black - 11634-silver - 11629-black set MACRO-ADAPTER-M - 11670-black "big top" version
  • Production era - 2004-Current - "big top" version introduced 2014 (shown at right)
  • Variants - Black and chrome versions
  • Lens mount - Leica M quick-change bayonet
  • Compatibility - Unlike other collapsible lenses, 90mm f/4 Macro-Elmar-M can be used on M8 or M9 cameras without restriction, as the extension tube does not extend into the camera.
  • Number of lenses/groups - 4 /4
  • Focusing range - 0.77 m / 2.5 ft < ∞ (with Leica MACRO-ADAPTER-M: 0.5 < 0.76 m / 1.6 < 2.5 ft)
  • Aperture - f/4-f/22 - with click-stops, half values available
  • Diaphragm setting /type - 10-blade
  • Smallest object field/Largest reproduction ratio - 160 mm x 240 mm (with LEICA MACRO-ADAPTER-M: 72 x 108 mm)/1:6.7 (with LEICA MACRO-ADAPTER-M: 1:3)
  • Angle of view (diagonal, horizontal, vertical) - 27°, 23°, 15°
  • Position of entrance pupil - 32.3 mm / 1.27 in - ("big top" version 22 mm / 0.67 in) related to the first lens surface in light direction
  • Filter mount - Non-rotating, internal thread for screw-on filters size E39
  • Accessories
  • Viewfinder - Camera viewfinder
  • Materials - Anodized aluminum and optical glass / Chrome-plated brass and optical glass
  • Focal length - 90.0 mm / 3.54 in
  • Length to bayonet flange - 41 < 59 mm / 1.61 < 2.32 in
  • Largest diameter - 52 mm / 2.05 in
  • Weight - 230 g - 8.11 oz black anodized aluminum / 320 g - 11.29 oz chrome plated brass
  • Inscription - LEICA MACRO-ELMAR-M 1:4/90 E39 3XXXXXX
  • Leica Tech Data
90mm f/4 Macro-Elmar-M Serial Numbers
3968791 3969170 90mm f/4 Macro-Elmar-M 2003 380
3969171 3970170 90mm f/4 Macro-Elmar-M (black+silver) 2003 1000
3971486 3972485 90mm f/4 Macro-Elmar-M (silver) 2003 1000
3975089 3976588 90mm f/4 Macro-Elmar-M (black) 2003 1500
-4174726 4195710- 90mm f/4 Macro-Elmar-M (black) 2006-2013 20,958+
-4195710 unknown- 90mm f/4 Macro-Elmar-M ("big top" version) 2014 unknown
TOTAL ASSIGNED SERIAL NUMBERS 2003-2013 24,838+
