V35 AF
Revision as of 14:02, 19 August 2015 by Tdavis (talk | contribs)
  • Production era - 1978-1995 - name change from Leitz to Leica in 1989
  • Variants - Black & white, multigrade or color
  • Format - 35 mm *
  • Baseboard - 21 1/4 x 27 1/2" *
  • Head - Diffusion*
  • Focusing - Cam-driven collapsing tube mechanism per Forum discussion [4] below
  • Autofocus - Yes*
  • Column - Single post*
  • Original bulb - 75W Philips 6604 bulb (current version Philips 13139)
    • Fotohuis RoVo alternatives
      • Osram HLX bulb 75W with an adapter for the reflector, which is made by Kienzle (Germany).
      • Heiland LED light source for V35 (Around Eur. 600,-)
      • Heiland LED light source with Split Grade (Around Eur. 1200,-)
    • see also Bruce Robbins bulb-fix
  • Provided lens - WA Focotar 1:2.8 / 40 mm
  • Other lenses - Focotar - 2 1:4.5 / 50 mm
  • Accessories
    • 17009 - Negative holder, glassless, 24 x 36 f.
    • 17011-17012 - 25 x 37 mm full-frame negative carriers (2 types) ". . . slightly bigger than the 35mm negative frame, allowing for printing of the natural black border around the image." -pv
    • 17428 - Color-Modul
    • 17440 - Red filter
    • 17441 - Variocontrast module
  • Manuals & brochures
  • Reviews
  • Forum discussion
