Leica SL
Revision as of 15:14, 25 October 2015 by Tdavis (talk | contribs)
  • Order no. - 10850 (Type 601)
  • Production era - 2015 - Current
  • Lens compatibility w/ Leica L-Mount
Vario-Elmarit-SL 24–90 mm f/2.8–4 ASPH. - APO-Vario-Elmarit-SL 90–280 mm f/2.8–4 - Summilux-SL 50 mm f/1.4 ASPH.
Leica T lenses: Summicron-T 23 mm f/2 ASPH. - Vario-Elmar-T 18-56 mm f/3.5-5.6 ASPH. - Super-Elmar-Vario-T 11-23 mm f/3.5-4.5 ASPH. - APO-Vario-Elmar-T 55-135 mm f/3.5-5.6 ASPH.
Leica M-Lenses with Leica M-Adapter T, Leica S-Lenses with Leica S-Adapter L, Leica R-Lenses with Leica R-Adapter L, Leica Cine lenses with Leica PL-Adapter L
  • Sensor - 24-MP-CMOS-Sensor (24 x 36 mm)
Resolution - Full Frame (24 MP): 6000 x 4000 Pixel, APS-C (10 MP): 3936 x 2624 Pixel
Filter - IR-Filter, no Lowpass Filter
ISO - ISO 50–ISO 50000
Sensor Cleaning - Ultrasonic self-cleaning CMOS sensor
  • Processor - Leica Maestro II series
Internal RAM - 2 GB: 33 DNGs or 30 JPEGs and DNGs
Image Data Format - JPEG, DNG
Color depth - 14 bit (DNG), 8 bit (JPEG)
JPEG - Color Space Adobe RGB, ECI RGB, sRGB
  • Video - MP4, MOV - V-Log L gamma selectable
Resolution
4K (4096 x 2160) @ 24 fps
4K (3840 x 2160) @ 25 and 30 fps
1080 @ 24, 25, 30, 50, 60, 100 and 120 fps
720 @ 24, 25, 30, 50, 60, 100 and 120 fps
Bit rate
8 bit (recording)
10 bit (HDMI not recording)
Color sampling
4:2:2/10 bit (HDMI only)
4:2:0/8 bit (recording on SD card)
Audio - Manual/Auto; Stereo microphone, 48 kHz, 16 bit; Wind elimination
Audio external via Audio-Adapter - Audio-In (3.5 mm phone jack), Audio-Out (3.5 mm phone jack)
Movie Length - Max. duration: 29 min, Max. size: 4 GB
  • EVF
Resolution - SXAG, 4.4 MP
Size - 0.66"
Eye Point - 20 mm
Field of View - 37°
Magnification - x 0.80 (With 50 mm lens at infinity, −1 dpt)
Frame coverage - 100 %
Diopter correction - −4 to +2
Eye Sensor - Yes
  • Live View
Operating Modes: Video- and Photo-Live-View separated; Frame rate: up to 60 fps; Exposure simulation available
Optional information: Focus Peaking, Histogram, Clipping /Zebra, Level, Grid Overlay (3 x 3, 6 x 4), Aspect Ratio (1.33:1; 1.66:1; 1.78:1; 1.85:1; 2.35:1; 2.4:1), Safe Area (80 %; 90 %; 92.5 %; 95 %)
  • Storage - SD 1 slot (UHS II) with maximum writing speed 100 MB/s, SD 2 slot (UHS I) with maximum writing speed 30 MB/s
  • Focusing
Type - Contrast AF
Focus Modes - AF-S (focus priority), AF-C (shutter priority), MF, Touch-AF
AF Modes - Static, Dynamic (tracking), Auto (face detection)
AF Size - Point, Field, Zone (9 Fields)
AF Steps - 37 or 49 Fields
AF Assist Lamp - Built in
  • Exposure
Exposure Modes - Program Mode (P), Shutter speed priority mode (T), Aperture priority mode (A) and manual mode (M
Exposure Metering Modes - Center weighted, Multi zone, Spot
Exposure Compensation - ±3 EV in 1/3 or 1/2 EV-steps
Exposure Bracketing - 3/5/7 images in 1/2/3 aperture steps; additional direct JPEG-HDR
  • White Balance - Preset Auto, Daylight 5200 K, Cloudy 6000 K, Shade 7000 K, Tungsten 3200 K, HMI 5600 K, Fluorescent warm 4000 K, Fluorescent cool 4500 K, Flash 5400 K, Greycard, Manual color temperature 2000 K to 11500 K
  • Shutter
Type - Focal plane shutter
Drive Modes - Single, Continuous slow S (4 fps), Continuous medium M (7 fps), Continuous fast F (11 fps), Self timer 2 s, Self timer 12 s, Interval, Exposure Bracketing, Time exposures up to 30 min
Shutter speed - 1/8000 s to 60 s, time exposures up to 30 min, Max. frame rate 11 fps
  • Flash
Interface - Standard X-jack, Hot shoe with Sync. and TTL-Mode contacts
X-Synchronization - 1/250 s
  • Wi-Fi - Built in, IEEE 802.11 b/g/n (2.5 GHz)
  • GPS - Built in, Automatic time and date, Sensitivity < 1°
  • Power supply - Rechargeable Lithium-Ion battery, Nominal voltage 8.4 V, Capacity at least 1860 mAh; Lifetime per charge (CIPA): approx. 400 shoots; Charging time: approx. 180 min; Charger: 100–240 V 50/60 Hz 0.25 A with adapters
  • Touch Screen - 2.95" Touch Back light LED with Anti-fingerprint and Anti-scratch coating; 1.04 Mio. pixels; Format 3:2; View angle: 170°; Colors: 16 Million; Frame coverage: 100 %
  • Top Display - 1.28" highly reflective monochrome LCD; 128 x 128 dots; View angle 120°; Anti-fingerprint coating
  • Housing
Material - Milled Aluminum
Dust /Spray water sealing - Provided
Interfaces - USB 3.0 Micro Type B; HDMI Type A; Multi connector adapter for Audio-Out 3.5 mm /Audio-In 3.5 mm; Multi Connector cable release; ISO accessory shoe with center and control contacts for flash units; Standard X-jack; Multifunctional interface in baseplate for optional handgrip
Tripod thread - A 1/4 DIN 4503 (1/4") with anti-twist locking pin
Dimensions /Weight - 147 x 104 x 39-67 mm (W x H x D-D+Grip) approx. 741 /847 g (without /with battery)
Working conditions - Approx. 0°– 40°C, max. 85 % humidity
  • Scope of delivery - Camera body, Camera strap, Lens mount cap, Battery, Battery Charger with international adapter, USB 3.0-cable, Manual, Warranty Card, Leica lens cleaning tissue
  • Software - Remote Control (USB): Leica Image Shuttle SL; Remote Control (Wi-Fi): Leica SL app (Android/iOS)
  • Warranty - 2 years or 200,000 releases
Manufacturer's data as of October 2015
Leica SL 601 Serial Numbers
Serial numbers compiled from known Leica SL cameras
-4964037 unknown- Leica SL 601 (black) 2015 unknown
TOTAL ASSIGNED SERIAL NUMBERS 2015-Current unknown
