Vario-Elmarit-SL 24–90 mm f/2.8–4 ASPH.
Revision as of 15:47, 1 November 2015 by Tdavis (talk | contribs) (→Leica Vario-Elmarit-SL 24–90 mm f/2.8–4 ASPH. Serial Numbers)
- Order no. - 11176
- Production era - 2015-Current
- Angle of view (diagonal, horizontal, vertical) - at 24 or 90mm: approx. 82.4°, 72.1°, 51.8° or 27.8°, 23.3°,15.7°
- Number of lenses /groups - 18 /15
- Aspherical surfaces - 4
- Position of entrance pupil - at 24 or 90mm: 103.9 or 92.6mm (in the direction of light incidence in front of the bayonet fitting contact area)
- Image stabilization - Multiple axis system, stabilization performance 3.5 shutter speed stages in accordance with CIPA testing conditions
- Distance setting - Setting either automatic (Auto-focus) or manual, modes are set on the camera
- Focusing range - at 24 or 90mm: 0.3 or 0.45m to ∞
- Smallest object field/biggest scale - at 24 or 90mm: approx. 173 x 260mm /1:7.2 or 92 x 137 mm /1:3.8
- Aperture - Setting/Function electronically controlled aperture, setting via turn/push wheel on camera, half values can also be set
- Bayonet fitting - Leica L bayonet fitting with contact strip
- Filter mount /lens hood - External bayonet fitting for lens hood (included), internal thread for E82 filters, filter mount does not rotate
- Finish - Black anodized
- Dimensions and weight - Length of the bayonet fitting contact surface: at 24 or 90 mm, (without/with lens hood) approx. 138 /170 mm or 182 /212 mm
- Largest diameter approx - 88 mm
- Weight approx - 1,140 g
- Warranty - 2 years
- Leica Tech Data - Vario-Elmarit-SL 24–90 mm f/2.8–4 ASPH.pdf
- MSRP - €EU 4,300, £BP 3,150, $US 4,950 in 2015
Serial numbers compiled from known lenses| SN Start | SN End | Product | Year | Total |
| -4517225 | 4518308- | Vario-Elmarit-SL 24–90 mm f/2.8–4 ASPH. | 2015 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2015- | unknown |
