D-Lux 7
Revision as of 23:12, 11 May 2020 by Tdavis (talk | contribs)
Leica D-Lux 7 3952 Specifications
  • Imaging
  • 'Pixels - Actual: 21.77 Megapixel - Effective: 17 Megapixel
  • Sensor
  • Four Thirds (17.3 x 13 mm) MOS
  • File Formats
  • 'Still Images: JPEG, RAW
  • Movies: AVCHD, MP4
  • Audio: AAC, Dolby Digital 2ch
  • Max Resolution - 4736 x 3552
  • Aspect Ratio - 1:1, 3:2, 4:3, 16:9
  • Image Stabilization Optical Optics
  • 'Lens - 11 Elements in 8 Groups (5 Aspherical)
  • Effective Focal Length: 10.9 to 34mm (35 mm Equivalent: 24 to 75mm)
  • Aperture: f/1.7 (W) to f/2.8 (T) to f/16 (T)
  • 'Filter Thread - 43mm
  • Zoom
  • Optical: 3.1x
  • Intelligent Zoom: 6.2x
  • Digital: 4x
  • Extra Optical Zoom (EZ): 4.3x
  • Extra Optical Zoom (EZ): 6.2x
  • Focus Range
  • Normal: 1.64' to Infinity / 50cm to Infinity
  • Wide: 1.18" to Infinity / 3cm to Infinity
  • Telephoto: 11.81" to Infinity / 30cm to Infinity
  • Exposure Control
  • 'ISO Sensitivity
  • Auto, 200 to 25600 (Extended Mode:100 to 25600)
  • Shutter
  • 'Type: Mechanical
  • 'Speed: 60 to 1/4000 Second
  • Type: Electronic
  • Speed: 1 to 1/16000 Second
  • 'Type: Electronic
  • Speed: 30 to 0 Minute in Time Mode
  • 'Type: Electronic
  • Speed: 1/2 to 1/16000 Second in Movie Mode
  • Exposure Metering - Center-Weighted, Multi, Spot
  • Exposure Modes - Modes: Aperture Priority, Manual, Program, Shutter Priority
  • 'Compensation: -5 EV to +5 EV (in 1/3 EV Steps)
  • White Balance Modes
  • 'Auto, Cloudy, Color Temperature, Daylight, Flash, Incandescent, Shade, White Set 1,White Set 2, White Set 3, White Set 4
  • Buffer/Continuous Shooting
  • Up to 11 fps at 17 MP
  • Up to 7 fps at 17 MP
  • Up to 5.5 fps at 17 MP
  • Up to 2 fps at 17 MP
  • Up to 30 fps at 8.3 MP
  • Self-Timer - 2, 10 Sec
  • Flash
  • 'Flash Modes
  • Auto
  • Auto/Red-Eye Reduction
  • First-Curtain Sync
  • 'Forced On
  • 'Forced On/Red-Eye Reduction
  • Off
  • Second-Curtain Sync
  • Slow Sync
  • Slow Sync/Red-Eye Reduction
  • Built-In Flash - No
  • External Flash Connection
  • Hot Shoe
  • Memory
  • 'Memory Card Type - SD, SDHC, SDXC
  • Recording
  • 'Video Recording
  • Yes, NTSC/PAL
  • Resolution
- 3840 x 2160p: 30 fps, 25 fps, 24 fps - 1920 x 1080p: 60 fps, 50 fps, 30 fps, 25 fps, 24 fps - 1280 x 720p: 30 fps, 25 fps
  • Video
  • Video Clip Length - Up to 29 Minutes 59 Seconds
  • Audio Recording
  • Built-In Mic: With Video (Stereo)
  • Viewfinder/Display
  • 'Viewfinder Type
  • 'Electronic
  • Viewfinder Coverage 1 Screen
  • 3.0" LCD Rear Touchscreen (1,240,000 Pixels)
  • Screen Coverage 1
  • Connectivity/System Requirements
  • Connectivity
  • HDMI D (Micro), USB 2.0 Micro-B
  • Wi-Fi - Yes, Wi-Fi 4 (802.11n) Built In
  • Power
  • 'Battery - 1x BP-DC15 Rechargeable Lithium-Ion Battery Pack, 7.2 VDC, 1025 mAh
  • General
  • 'Operating temperature - 0 to 40 deg. C (32 to 104 deg. F)
  • 'Operating humidity - 10 - 80% RH
  • Dimensions (WxHxD) - 4.6 x 2.6 x 2.5" (11.68 x 6.60 x 6.35cm)
  • Weight - 14.22 oz (403.13g)
