A
Revision as of 17:43, 6 July 2009 by Admin (talk | contribs)
AYOOC Waist-level 3.5cm/5cm finder ? -
AKTOO High-power AKTINA Lamp for Focomat II enlarger ? -
ABCOO Nickel cutting blade for Leica 250 film 1937 -used with ANZOO template
ABFOO Snap-shot Leica, never sold 1935 -
ABLON Film trimming template ? -
ABOOT Leica II (model D) with Elmar 3.5/50 1934-1948 -
ACEDU Micro Lens No. 2 for the micro-projection approach VIII projectors -
ACHOO Leica III (model F) with Summar 5 cm 1933-1939 -
ACOOS Leica III (model F) with Elmar 5 cm 1933-1939 -
ACUBE Wide band UV filter set for micro-projector VIII -
AFLUU 18x24 sheet of glass with lower opening for AKTUU -
ADKOO Leica IIIa (model G) with Summar 2.0/5 cm 1935-1948 LIOON in US Catalog
ADOOR Leica IIIa (model G) with Elmar 3.5/5 cm 1935-1948 LEOOR in US Catalog
ADFIK Hood with filter holder engraved for 50,90,127,135mm lenses ? -
ADR50 Focotar enlarger 1:4.5/50 mm ? -
ADR65 Focotar enlarger 1:3.5/65 mm ? -
ADSUM Adapter for Summitar filter thread A 36 ? -
ADVOO Close up set for [Leica IIIg] ? -
AFLOO Film Charger for Leica 250 ? -
AFLUN Changed version ? -
AFOOF Leica III (model F) chrome ? -
AFUUV Lower glass for AKTUU with 18x24mm opening -
AGIIU Adjustment ring for microscopes with a diameter of 32 mm ? -
AGITA Electric Tank / film development with DC ? -
AGOTU Electric Tank / film development with AC ? -
AGNOO Leica IIIa (model G) chrome ? LUOOB in US Catalog
AGNOO-SW Leica IIIa (model G) black paint ? -
AGNUU Slide changer with 24 x 36 mm film gate -
AGRIF Hand film loader for cassettes ? -
AGULI Timer for tanks ? -
AIUUS Slider for 18x24 film strips, projector VIII -
-AHOOT Waist level viewfinder for 5cm use with a swivel mask for 2.8cm ca. 1935
AKGBMI Underwater housing for Leica IIIf If up and Summicron ? -
AKGBSU Underwater Housing for Leica If llf or lllf -
AKGRSU Underwater housing for Leica IIIf If up and Summitar ? -
AKGRMI Underwater Housing for Leica If, IIf or IIIf -
AKTUU Film gate with semi-automatic film movement for 24x36mm Projector VIII -
AKUUR Semi-automatic film movement for Small Projectors 89, 9; Slide changer with circular opening of 43 mm. diameter for 5x5 cm -
ALVOO Standard Leica (model E) black enameled, without spool chamber and without lens -
ALVUU Slide changer for 2x2 in glass slides ? -
AMPLIVID 6x24 - Binoculars 1956-1962 -
AMTOM Electric timer for bayonet cameras ? -
AMTOO Electric timer for screw cameras ? -
ANZOO Trimming template for Leica 250 film 1937 -used with ABCOO blade
APDOO Self-timer ca. 1937 -
AQOOT Extra long release button for screw mount cameras ? -
AMUUP 750 w projector lamp ca. 1937 - also AMUUP-E
AMXOO -
ANIIO -
ANUUO -
ANZUU -
ARHOO Leica I (model C) with Elmar 3.5/50 1930-33 -
ARMST Stereo Prism Holder for Leica IIIb ? -
AROOG Standard Leica (model E) with attached horizontal rangefinder -
AIROO Late version Leica II (model D) black paint 1934 -
AIROOCHROM Late version Leica II (model D) chrome housing 1934 -
ALVOO Standard Leica (model E) black paint 1932-50 -
AROOGCHROM Standard Leica (model E) chrome 1938 -
ASKOO APDOO self-timer with leather case ca. 1937 -
ASPUL Manual Hand Film Loader ? -
ASUUI -
ATMUU -
ATTAC -
ATOOH Leica IIIb chrome 1938-41 -
AUFSU Reflecting (waist level) viewfinder for 50mm lens ca. 1932-45 -
AUTAS Prism for Mikas microscope ? -
AUXWI -
AVIODIX Leitz 10x50 binoculars 1917 -
AVIODIXIT Leitz 10x50 binoculars, 5 deg 1931 -
AVIOSEPT Leitz military version 7x50 binoculars, 7.3deg 1919-31 -
AVIOSEPTIT Leitz 7x50 binoculars, 7.3deg 1930-31 -
AVIVFORTE Leitz 12x60 binoculars ? -
AVOOF -
AVQUU -
AWOOE -
AWSUU -
AWUUE Slide changer with circular opening of 50 mm. diameter for Leica diapositives 3x4cm between 5x5cm glass plates pre 1937 -
AXUOO -
AYOOK Reflecting (waist level) viewfinder AUFSU / AHOOT for 35 + 50mm lens ? - also AYOOC
AYUUK Reflecting (waist level) viewfinder AYOOK with New York Engravings ? -
AYUUL Reflecting (waist level) viewfinder AHOOT with New York Engravings ? -
AYUUN Reflecting (waist level) viewfinder without the 2.8 cm swivel lens ? -
AYUUO Reflecting (waist level) viewfinder for 35 mm lens ? -
AZOOB -
AZUUB -
