A
Revision as of 16:12, 18 July 2009 by Admin (talk | contribs)
Leitz "Binoculars" data courtesy of Peter Abrahams
ABCOO Nickel cutting blade for Leica 250 film 1937 -used with ANZOO template
ABFOO Snap-shot Leica, never sold 1935 -
ABLON Film trimming template ? -
ABOOT Leica II (model D) with Elmar (I) f= 5 cm 1:3.5 1934-1948 -
ACEDU Micro Lens No. 2 for the micro-projection approach VIII projectors -
ACHOO Leica III (model F) black lacquer with Summar f= 5 cm 1:2 1933-1939 - see also ACOOS, AFOON
ACHOOCHROM Leica III (model F) chrome with Summar f= 5 cm 1:2 1933-1935 - see also ACOOS, AFOONCHROM
ACOOS Leica III (model F) black lacquer with Elmar (I) f= 5 cm 1:3.5 1933-1939 - see also ACHOO, AFOON
ACOOSCHROM Leica III (model F) chrome with Elmar (I) f= 5 cm 1:3.5 1933-1935 - see also ACHOO, AFOONCHROM
ACUBE Wide band UV filter set for micro-projector VIII -
AFLUU 18x24 sheet of glass with lower opening for AKTUU -
ADKOO Leica IIIa (model G) with Summar 2.0/5 cm 1935-1948 LIOON in US Catalog
ADOOR Leica IIIa (model G) with Elmar (II) f= 5 cm 1:3.5 1935-1948 LEOOR in US Catalog
ADFIK Hood with filter holder engraved for 50,90,127,135mm lenses ? -
ADR50 Focotar enlarger 1:4.5/50 mm ? -
ADR65 Focotar enlarger 1:3.5/65 mm ? -
ADSUM Adapter for Summitar filter thread A 36 ? -
ADVOO Close up set for [Leica IIIg] 1959 - also 16503
AFLOO Film Charger for Leica 250 ? -
AFLUN Changed version ? -
AFOON Leica III (model F) black lacquer 1933-39 - see also ACOOS, ACHOO
AFOONCHROM Leica III (model F) chrome 1933-35 - see also ACOOS, ACHOO
AFUUV Lower glass for AKTUU with 18x24mm opening -
AGIIU Adjustment ring for microscopes with a diameter of 32 mm ? -
AGITA Electric Tank / film development with DC ? -
AGOTU Electric Tank / film development with AC ? -
AGNOO Leica IIIa (model G) chrome ? LUOOB in US Catalog
AGNOO-SW Leica IIIa (model G) black paint ? -
AGNUU Slide changer with 24 x 36 mm film gate -
AGRIF Hand film loader for cassettes ? -
AGULI Timer for tanks ? -
-AHOOT Waist level viewfinder for 5cm use with a swivel mask for 2.8cm ca. 1935
AIUUS Slider for 18x24 film strips, projector VIII -
AKGBMI Underwater housing for Leica IIIf If up and Summicron ? -
AKGBSU Underwater Housing for Leica If llf or lllf -
AKGRSU Underwater housing for Leica IIIf If up and Summitar ? -
AKGRMI Underwater Housing for Leica If, IIf or IIIf ? -
AKTOO High-power AKTINA Lamp for Focomat II enlarger ? -
AKTUU Film gate with semi-automatic film movement for 24x36mm Projector VIII ? -
AKUUR Slide changer with circular opening of 43 mm. diameter for 5x5 cm ? -
ALVOO Standard Leica (model E) black enameled, without spool chamber and without lens 1932-1948 - see also AROOG
ALVUU Slide changer for 2x2 in glass slides ? -
AMPLIVID Binoculars - 6 x 24 - 12 deg 1956-1962 -
AMTOM Electric timer for bayonet cameras ? -
AMTOO Electric timer for screw cameras ? -
ANZOO Trimming template for Leica 250 film 1937 - used with ABCOO blade
AMUUP 750 w projector lamp ca. 1937 - also AMUUP-E
AMXOO -
ANIIO -
ANUUO -
ANZUU -
APDOO Self-timer ca. 1937-46 -
AQOOT Extra long release button for screw mount cameras ? -
ARHOO Leica I (model C) with Elmar (I) f= 5 cm 1:3.5 1930-1933 -
ARMST Stereo Prism Holder for Leica IIIb ? -
AROOG Standard Leica (model E) black lacquer, with attached horizontal rangefinder 1932-1948 - see also ALVOO
AROOGCHROM Standard Leica (model E) chrome, with attached horizontal rangefinder 1934-1935 - see also ALVOOCHROM
AIROO Late version Leica II (model D) black lacquer 1934 -
AIROOCHROM Late version Leica II (model D) chrome housing 1934 -
ALVOO Standard Leica (model E) black paint 1932-1950 -
AROOGCHROM Standard Leica (model E) chrome 1938 -
ASKOO APDOO self-timer with leather case ca. 1937 -
ASPUL Manual Hand Film Loader ? -
ASUUI -
ATMUU -
ATTAC -
ATOOH Leica IIIb chrome 1938-41 -
AUFSU Reflecting (waist level) viewfinder for 50mm lens ca. 1932-1945 -
AUTAS Prism for Mikas microscope ? -
AUXWI -
AVIODIX Binoculars - 10 x 50 1919-1931 - military version 1917
AVIODIXIT Binoculars - 10 x 50 - 5 deg - CF type 1931 -
AVIOSEPT Binoculars - 7 x 50 - 7.3 deg 1919-1931 -
AVIOSEPTIT Binoculars - 7x50 - 7.3 deg - CF type 1930-1931 -
AVIOFORTE Binoculars - 12 x 60 - 4.3 deg 1919-1930 -
AVIONAR Binoculars - 15 x 60 ? -
AVOOF -
AVQUU -
AWOOE -
AWSUU -
AWUUE Slide changer with circular opening of 50 mm. diameter for Leica diapositives 3x4cm between 5x5cm glass plates pre 1937 -
AXUOO -
AYOOC] Waist-level 3.5cm/5cm finder ? -
AYOOK Reflecting (waist level) viewfinder AUFSU / AHOOT for 35 + 50mm lens ? - also AYOOC
AYUUK Reflecting (waist level) viewfinder AYOOK with New York Engravings ? -
AYUUL Reflecting (waist level) viewfinder AHOOT with New York Engravings ? -
AYUUN Reflecting (waist level) viewfinder without the 2.8 cm swivel lens ? -
AYUUO Reflecting (waist level) viewfinder for 35 mm lens ? -
AZOOB -
AZUUB -
