C-Lux 2
Revision as of 04:48, 28 September 2008 by Admin (talk | contribs) (→‎Accessories)
Image type/format 1/2.5" CCD sensor with 7.38 million pixels (7.2 m pixels effective in 4:3 format). Resolution In 4:3 format either 3,072 x 2,304 pixels, 2,560 x 1,920 pixels, 2,048 x 1,536 pixels, 1,600 x 1,200 pixels, 1,280 x 960 pixels or 640 x 480 pixels. In Leica 3:2 format either 3,072 x 2,048 pixels or 2,048 x 1,360 pixels. In 16:9 format either 3,072 x 1,728 pixels or 1,920 x 1,080 pixels (corresponds to HDTV standard). Video sequences In 16:9 format 848 x 480 pixels ; In 4:3 format with 640 x 480 pixels, or in 4:3 format with 320 x 240 pixels at either 30fps or 10fps, duration of recording limited by the capacity of the memory card. Recordings with sound. (Duration of recordings for UK/EU/ES-SCAN versions max. 15 min) Data recording File formats : Still pictures JPEG (Fine/Standard) ; Video QuickTime Motion JPEG. Storage media SDHC memory card, SD memory card and MultiMedia card (a 64 MB SD card is supplied with the camera). Film speed setting Either automatic, Intelligent ISO or manual ISO 100, ISO 200, 400, 800 or ISO 1250 (in high-sensitivity mode : 3200). White balance Either automatic, for daylight, overcast sky, halogen light, two manual settings, fine adjustment of white balance in a range of -1500 to +1500 K in 150 K steps (not available for automatic setting). Lens LEICA DC VARIO-ELMARIT f/2.8-5.6/4.6-16.4 mm ASPH. (corresponds to 28-100 mm in 35 mm photography in 4:3 picture format), 3.6 x optical zoom. Change of focal length by conveniently located zoom lever. Optical Image 7 elements in 6 groups (5 aspherical lens elements/6 aspherical surfaces) with optical image stabilization. Stabilizer 2 modes: either for exposure only or for exposure and monitor. Focus range Normal mode : 50 cm (20 in) - infinity, Macro/Simple/Motion Picture : wide-angle 5 cm (2 in)/telephoto 30 cm (12 in) - infinity. Focusing Autofocus, either normal or macro. Autofocus mode/measurement range either 5 fields (full image area), faster autofocus with 3 fields (across the center) or with 1 central field, 1 field, or spot. Exposure Exposure modes Either simple mode, normal image or macro. Exposure metering multi-field measurement, Exposure bracketing +/- 2 EV in 1⁄ 3 EV steps. Shutter speed range In fully automatic mode: 8-1/2000 sec. Starry sky mode : 15, 30, 60 s. Video mode : 1/30 s -1/6400 s. Flash Flash modes either automatic flash on with or without pre-flash (to reduce red-eye), manual flash on (fill-in flash), SLOW for slower shutter speeds (with pre-flash), flash off. Flash range (ISO set at Auto) : 0.6-5.0 m (wide-angle), 0.3-2.0 m (telephoto), in high-sensitivity mode : 0.8-5.7 m (wide-angle), 0.8-2.8 m (telephoto). Scene modes Portrait, soft skin, landscape, sport, night portrait, night landscape, starry sky, fireworks, food, party, candlelight, baby 1, baby 2, pets, sunset, high sensitivity, beach, snow, aerial, underwater. Function key For direct control of : image stabilizer, bracketing speed, white balance, ISO setting, picture size, compression. Toning effects Natural, standard, lively, blueish, reddish, black-and-white or sepia. LCD monitor 2.5" polycrystalline TFT color display with 207,000 pixels. Field of view : almost 100 % Power LCD mode, wide-angle viewing mode. Self timer Either 2 s or 10 s countdown. Live histogram yes Power supply Lithium-ion battery (LEICA BP-DC6), 3.6 V, 1000 mAH or optional mains unit (LEICA ACA-DC4). Ports USB 2.0 (Full speed), DC in (power supply) and AV out. Printer compatibility PictBridge Battery capacity (approx.) 300 pictures (CIPA Standard) Dimensions (W x H x D) approx. 94.9 x 51.9 x 22 mm (3.7 x 2 x 0.9 inches) Weight approx. 132 g (4.6 oz) without battery and memory card ; approx. 154 g (5.4 oz) with battery and SD memory card. Scope of delivery Battery charger, battery, 64 MB SD memory card, AV cable, USB cable, AC cable, wrist strap, CD ROM with software (Adobe Photoshop Elements 3/4/5, Quicktime Movieplayer). Body color Available in Black or Silver
Accessories
Leather case Choice of three colors. Wrist carrying strap Furnished Carrying strap Available Neoprene case Available Charger/mains unit (replacement) ACA-DC4 with mains cable Lithium-Ion Battery (replacement) LEICA BP-DC6 Digital adapter Digital Adapter 2 for all Leica Televid
LEICA C-LUX 2 - manufacturer's data as of February 2007
